15 mph impact = new frame?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Mar 7, 2019.
  1. Mar 8, 2019 at 2:23 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    My frame bent in and down in my '14. I believe the frame cost was about $3500-4000... But I hit a concrete median barrier and then a guardrail, neither of which slid even a little. (I had airbag deploy etc...) I wouldn't consider it a total loss depending on your other damage. I do agree with the Stig --> work with your collision shop. They'll should be your advocate and give you the real scoop. Good luck.
    15whtrd and Black Wolf like this.
  2. Mar 8, 2019 at 2:35 PM
    Good advice.
  3. Mar 27, 2019 at 2:43 PM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Subscribing.....
