45mph max speed when towing...really?
Discussion in '1st Gen Tundras (2000-2006)' started by Red913, Mar 26, 2019.
  1. Mar 26, 2019 at 7:19 PM
    Red913
    Red913 [OP] New Member
    Todd
    Fullerton, CA
    06 Tundra Double Cab
    Stock is fine
    Toyota says not to tow faster than 45mph. Has anyone here towed a large trailer(say 4000lb or higher) and experienced swaying, like they say? Is this necessary, or just lawyer, playing it safe stuff? I've never towed with this truck before and don't know what to expect.
  2. Mar 26, 2019 at 7:42 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  3. Mar 26, 2019 at 7:50 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Death wobble.
  4. Mar 26, 2019 at 8:02 PM
    Red913
    Todd
    Fullerton, CA
    Stock is fine
    Owners manual addresses that too. They say to slowly decelerate and try and hold the steering wheel straight.
  5. Mar 26, 2019 at 8:03 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Answer: Yes. No.
    Small camper trailer, 20' on 12 hr. trip. Single axle trailer approx 5k pounds with a '14 CM. Easily forgot it was back there at times and had to ease off the gas when I saw the speedometer at 70+ (tried to keep it around 67mph or so). It was set up with an anti-sway hitch, but it was crazy easy to tow.
    I am not concerned, which is why I bought a 24' (28 and change total length/7,500lb) double axle camper with anti-sway hitch. Plan on doing some sight seeing this springs/summer. And slaying some Kings this Fall in MI! :fingerscrossed:)
  6. Mar 26, 2019 at 8:06 PM
    Red913
    Todd
    Fullerton, CA
    Stock is fine
    That was done with a much bigger truck though. This is 1st Gen. So it might be different for a much newer and bigger truck.
    ColoradoTJ likes this.
  7. Mar 26, 2019 at 8:09 PM
    YeeYeeTundra
    Ohio
    I don't disagree, which is why I listed description. On a side note, I camped with a guy who had an '08 DC (I believe) and towed approx '26 camper with smaller engine. Also no issues according to him (anti-sway set up as well). "Tows like a dream..." I believe his quote was. The truck was blue though, and mine was white, so that may have made mine tow better too.... ;)
    Ludogg808 likes this.
  8. Mar 26, 2019 at 8:28 PM
    Could you screenshot the whole page?
    I’ve never towed with a 1st gen, or even been inside one. Not a lot of help here. Sorry.
    With a LDH, a properly loaded trailer, I see no reason 55-65 mph isn’t doable.
  9. Mar 26, 2019 at 8:41 PM
    Red913
    Todd
    Fullerton, CA
    Stock is fine
    Whats a LDH?
  10. Mar 26, 2019 at 9:10 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Load distribution hitch.
    I've towed heavy with my 1st gen I had previously. Lawyer stuff in my opinion, but you definitely know you are towing. Use your best judgement. You will feel the grades. Make sure you have trailer brakes and that they work properly.
  11. Mar 26, 2019 at 10:51 PM
    K-Large
    K-Large New Member
    Kevin
    04 White Tundra Limited
    Leveling kit
    I have a 04 and tow a trailer for work often 3k lbs dry and up to 7k fully loaded no issues going 55 not sure I would push it much past 60 but tows easy . I do have a brake controller and the trailer has brakes so that helps with stopping
  12. Mar 27, 2019 at 3:53 AM
    Professional Hand Model
    Fred
    Hand Protectors
    The 02’ tows comfortably up to 3500lbs. Over that weight, you need to pay attention to your speed and distance to stopping points. The 1st Gens are a small nimble power house perfect for towing up to 3500-4k range. Slow acceleration/deceleration are key.
    Other things to consider are tire quality and stock vs. lifted when towing.
  13. Mar 27, 2019 at 4:43 AM
    Haven't towed anything more than about 2500 lbs, but if the weight is properly distributed it will be fine.
    With my E-250 I towed a 12,000 pound trailer at about 60. It was fine until one of our dumbasses loaded the bobcat too far back. Then it started swaying at about 50. I just let off the gas and coasted down. If it starts swayin DO NOT PUSH THE BRAKES! All this was before I did research into GVWR and how to tow properly. Now I refuse to pull it with my van. We have an ext cab f-250 4x4 v10 at the shop i pull it with now and will do 70 with it no problem. Again, if the weight is distributed properly.
  14. Mar 27, 2019 at 4:47 AM
    @Red913, I would consider this expert advise from a 1st gen owerser extensive experience.
    For me, I would get a good LDH, adjust properly, and see how your personal tow experience is. The CA experience might be a lot different from the “Rocky mountain” experience.
    If you feel safety is an issue, drop speed, maybe change load (I have needed to do this on multiple occasions), and make a decision after that.
    In my own personal opinion, the truck you have is more than capable with the loads you want to
    tow.
  15. Mar 27, 2019 at 5:03 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I don't tow much, but when I do I certainly don't do 45 MPH. Most of the time I forget that I have a trailer behind me.
    Regarding the 1st gen: My brother in law had a first gen and now also have a first gen Sequoia which is very similar to the 1st gen tundra. He used both to pull a big (20'±) enclosed utility trailer between Maryland and Florida and did the speed limit or slightly more the whole way, every time. MPGs are not good, but that's expected. He also noted that he forget about the trailer behind him until he looks in his rear view mirror.
    Make sure you load it correctly - have a little tongue weight rather than heavier behind the axles - that will get you in trouble fast.
  16. Mar 27, 2019 at 5:07 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
  17. Mar 27, 2019 at 6:28 AM
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    I had a 2001 4 cyl Nissan Frontier. I would tow 5000 plus pounds all over the state of FL. No trailer brakes. Key is stopping distance, I didn't have any. I'd keep weights like this under 55 to 60 on hwy. You must pay great attention to your driving environment. Granted we are pretty flat here.
    With my Tundra and the power /brakes it has I can't see that being an issue.
  18. Mar 27, 2019 at 8:31 AM
    Dpy
    Dpy New Member
    Have towed just about everything with various vehicles and the above post about not braking when starting to sway is correct but if you have brakes on trailer and a brake controller in truck you can hit the controller and brake the trailer (only) a bit otherwise with no brakes on trailer you gotta slow down gradually and for Pete's sake , get that load corrected. One thing that is important is to load properly, always favor your load toward the front but not excessively . If I'm hauling my tractor , I know from experience how far to pull up on trailer. Need to get some weight on that tongue but again not too much, def need more load in front of trailer axles than in rear . As far as the 45 mph tow speed, that is a bit excessive , IN my 2006 dc Tundra, have towed a load of shingles from Kentucky to North Carolina which I guess was 7000 lbs and probably hit low 60's on 4 lane and interstate.
    jewsNbrews likes this.
  19. Mar 27, 2019 at 9:16 AM
    fwtexguy
    fwtexguy New Member
    2017 tundra crewmax
    Leveling kit, bullbar, ARE bed cover,leather seats,
    Been towing my 35' travel trailer 10000/lbs with my
    Tundra without issue. I am at the max payload and towing cap and I have been very happy so far. The mpg did drop to 8-9mpg but power and braking have been awesome. I did add a weight distribution hitch (a must) with sway control. Air bags, which don't do much except level it out a little and aid if If I get in a clearance situation. I plan on adding better shocks. I suggest watching this video if you plan to do much towing. https://www.youtube.com/watch?v=XBZu39pQ8Gg Also, the trailer brake controller SUCKS on the Tundra. There is a TSB that Toyota will do on your truck to help with this but it ain't free. ~$70. I am disappointed in Toyota for not making a more robust truck and for charging to fix their issue with the controller. I do give them credit for making a very strong factory trailer hitch.
  20. Mar 27, 2019 at 9:48 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I tow all the time with my first gen. Mostly my 19 foot boat at 3500 lb dry probably closer to 4500 lb with a full tank of gas in the boat and all my gear. I try to do only 55 but I catch myself speeding often will Towing especially downhill. I've even towed my boat through the Salt Flats in Utah I remember hitting 80 mph with no issues. I think a lot of it has to do with weight distribution over the trailer.
  21. Mar 27, 2019 at 7:54 PM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    I pull a 26 ft camper with my 06 DC that is 5200 dry. 60 down the interstate is not bad, but definitely suggest anti sway hitch. Like most said, plan your stops! Also occasionally pull a 7yard dump trailer for work, and it doesn't like that much because it is tounge heavy and doesn't have anti sway.
  22. Mar 27, 2019 at 10:14 PM
    Slp82
    Slp82 New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    I have towed a 16 foot tandem axle trailer with a 99 Jeep Wrangler 4.0L 4x4 on it (I believe the trailer was about 1,500 lbs, Wrangler is about 3,500 lbs) with my 2005 Toyota Tundra Reg Cab Long bed 4x4 with no weight distribution hitch or sway controller, and no trailer brakes. I am not saying this is the smartest thing on earth to do, but I also have been driving 18 wheelers (tractor/trailers) for a decade, many with overweight permits so I am use to stopping WAYYYY earlier and watching WAYYYY further ahead than the average driver who drives only a class C vehicle everyday. A little commonsense goes a long way. I also did this late at night when most people were not on the road.
    I have also towed that same 16 foot trailer many times with a Massey Ferguson small 4x4 diesel tractor (2,800 lbs) with a 60" brush hog (500 lbs) attached, 5,000 watt generator (120 lbs), 900 lbs of deer feed, probably another 250 lbs of ice chests, few 55 gallon drum deer feeders (200 lbs) and a Honda Foreman 4x4 in the bed of the truck. Yes I intentionally put the ATV in the bed to put more weight over the rear axle to help keep it stable and less likely to jerk the rear end around (sort of like the concept of a 5th wheel vs a bumper pull). Again, no weight distribution hitch, sway controller, or trailer brakes... just a whole lot of common sense (should be called uncommon sense because it is in fact not common for many people). Oh and again I usually drive up to the deer camp at night when nobody is on the road. Keep in mind I live in Texas where is also super flat, and we don't get a ton of high winds either, like say in Kansas. Also I know how to properly load the weight in a trailer as well.
    The time I towed the Wrangler I didn't go over 60 mph, and the times I towed the trailer with the tractor and equipment, I didn't go over 70 mph.
    I would always recommend you have brakes on your trailer if you are towing over 3,000 lbs, and a weight distribution hitch and sway bar are cheap insurance. You can literally get a weight distribution hitch at Harbor Freight for $210 (or on Amazon for around $200) and a sway control bar/kit for $30 (or on Amazon for $42).
    Cacoleman2014 likes this.
  23. Mar 28, 2019 at 1:37 PM
    Cacoleman2014
    Louisiana
    Mine pulls better with the 4 wheeler in the back also
  24. Mar 30, 2019 at 5:41 PM
    Red913
    Todd
    Fullerton, CA
    Stock is fine
    Thanks for all the input everyone. I ended up not rending a travel trailer, and just stayed at a hotel instead. It was a cheaper route for my family. But next time I think we're going to rent the trailer. One thing I should mention, is that Toyota says any trailer over 2000lb should have a "sway control device". So I definitely would make sure I have one of those installed on a large travel trailer.
    I was skeptical of going up a hill with a 5000lb + trailer, but after hearing from you guys, I think it'd be fine.
  25. Mar 31, 2019 at 12:05 AM
    Aerindel
    Aerindel New Member
    Montana
    I didn't make the drive myself but the very first thing the previous owner did when he bought the truck (like ten minutes after he bought it) was hook it up to a U-haul car hauler trailer 2200ish lbs....and put a 4runner on it and towed that five hundred miles through Montana.
    Yeah, he warped the rotors going down a pass but other than it did fine.
  26. Apr 1, 2019 at 4:49 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    :rofl:I suppose over 90 mph surpasses their requirement. I was going through Nebraska 2 years ago with my 2001 towing a dual axle trailer with my 240z on it, speed limit was 80 mph and tires were rated at 84 mph, so I just had to see what she can do, and smooth as silk it peeked over 90 mph, and then I brought it down to my safe 65-70 mph and continued on. :mudding:
  27. Apr 12, 2019 at 9:26 PM
    slymule
    slymule New Member
    Scott
    2005 Tundra DC 2x4 SR5
    I tow a 23' camper around for work, it weighs a little over 5k pounds. I use a weight distribution hitch and an anti-sway bar and have no problems towing at 75mph. My vehicle is a 2005 DC 2x4 with the 4.7L motor.
    bmf4069 likes this.
  28. Apr 17, 2019 at 4:40 PM
    koditten
    Kirk
    Midland of the Mitten
    What tires were rated at 84? I don't know any trailer tires rated for those speeds.
  29. Apr 23, 2019 at 3:35 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Town Fair Tire....says it right on the side, but I wouldn't advise doing that speed normally.
    koditten likes this.
