Has anyone pulled a U-Haul Trailer?
Discussion in 'Towing & Hauling' started by FirstGenVol, Mar 25, 2019.
  1. Mar 25, 2019 at 8:37 AM
    FirstGenVol [OP] Recovering mangler
    Looking for feedback on towing one of these bad boys. I have very limited towing experience. I've towed a Jet Ski a few times and that's it.
    I'm trying to figure out what I should expect, knowing my first gen doesn't have the power that the newer Tundras have.
    Specifically, how effective are the brakes? They are listed as automatic hydraulic surge brakes.
  2. Mar 25, 2019 at 8:39 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Just take it slow, and know that those trailers get beat to shit.
    You’ll be able to pull it fine.
    YeeYeeTundra and 15whtrd like this.
  3. Mar 25, 2019 at 9:42 AM
    That was my concern. I doubt they even test the brakes in between rentals.
  4. Mar 25, 2019 at 9:59 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    You should be fine towing that 6x12. The surge brakes aren't like electric brakes where they work when you step on the brakes in the truck. The surge brakes only work if the trailer jumps the ball and decides to go it's own direction. Follow the loading guide inside the trailer as far as how to position the weight front to back and you'll be just fine.
  5. Mar 25, 2019 at 10:07 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    This is false. The neck of the trailer is in two pieces, with a master cylinder in between. When you slow the truck, the momentum of the trailer pushes against the master cylinder, which squeezes the brakes.
    This also means you cannot back these trailers up without inserting a pin into the master cylinder section to stop it activating, otherwise you lock the brakes when trying to back up.
    They work fine, you just can't fine-tune it or have manual control of the trailer brakes. I pulled a 4k lb car on a UHaul auto transport across the country and they worked just fine.
    Bprose, WNY PAT, lsaami and 9 others like this.
  6. Mar 25, 2019 at 10:15 AM
    Does U-Haul supply this pin?
    This is good info BTW. I found a similar explanation for the brakes. I was just curious how well they actually performed. I've always heard "don't out-tow your brakes". The first gen Tundras are not known for having great braking power.
  7. Mar 25, 2019 at 10:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    correct on the operation of the brakes but possibly wrong on backing up. If you have a 7 way plug and the trailer is wired with a reverse light circuit the powering of the reverse lights will lock up the master cylinder and keep it from applying pressure to the brakes. At least this is how the surge brakes on my trailer work. Others may have a pin.
    scpete24 and ChrisTRDPro[QUOTED] like this.
  8. Mar 25, 2019 at 10:41 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I towed one with my Tacoma a while back, didn't have any issue with it. First Gen will be even better. Didn't have any issue with brakes on my 05 Tacoma either, trailer brakes worked just fine. The only time I had an issue is when I tried to back it up a hill. Locked the brakes up on it.
    FirstGenVol[OP] likes this.
  9. Mar 25, 2019 at 10:48 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I have towed the 6x12 many time with many trucks and have never had a issue with them. The trailer brake is hydrolic and I can't tell if the brakes work or not all i know every time i slow down the trailer never pushed any of my trucks. I have towed with full size 90's suburban, current Tundra and even an 90's Chevy blazer no issues at all.
  10. Mar 25, 2019 at 10:48 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I just towed a 6x12 last week moving furniture. I had no issues backing up, but correct on the stopping. The mechanism is inertia driven. Truck towed it completely fine. And Uhaul sends trailers out to a regional mechanics for inspection. They patented their design to take the abuse people put on these things. So find a good location and rent from them. They will have done all the required maintenance. Good luck!
  11. Mar 25, 2019 at 10:59 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    ecobust :rofl:
    NewImprovedRon and 15whtrd like this.
  12. Mar 25, 2019 at 11:01 AM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    I agree with the others. Take it slow at first until you get used to it. Also when I towed the smallest uhaul trailer with my tacoma a while back, it felt like it had zero suspension. Once loaded it did tow better.
  13. Mar 25, 2019 at 11:07 AM
    ChrisTRDPro
    MT
    Yes, if I remember correctly it was a metal latch that you latched in place to reverse instead of a pin (on the auto hauler, the other ones may be different). They explain it to you when you pick up the trailer.
    The brakes work fine, I never had a single issue. They make it as idiot-proof as possible so that pretty much anyone can tow.
  14. Mar 25, 2019 at 11:18 AM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Pulled this on a 6+ hour trip with a Touareg (7,700lb tow capable). One way unloaded then back loaded (to weight capacity...). They're stupid proof for the most part, but again: take it easy and load equally not too much front or back. Most likely been beat half to death by renters of these units. There is a reason you always see uhauls alongside the road abandoned. Mine had a slow leak in one of the tires so I stopped to check mutiple times to replenish/check air psi. (Always carry a tire pressure guage)
  15. Mar 25, 2019 at 11:23 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    You are right, but sometimes the trailers dont have a 7-way instead they have a 4-pin. On my boat trailer it used to have a 4-pin and I would have to hook it up differently when reversing and turn on my headlights to bypass the brakes. Either that or insert the pin that would not allow the neck to compress master cylinder. I've since re-wired my trailer and added a 7 way round plug and I dont have to do anything but put it in reverse to bypass the brakes. Depends on how the trailer is wired and what connections the truck has especially being a 1st gen
    Watt maker likes this.
  16. Mar 25, 2019 at 7:25 PM
    Liquid unlucky
    Liquid unlucky New Member
    North east Texas
    2019 Toyota Tundra
    None....yet few decals and a five star dragon Ball. Lift 4.5" in two years is the plan
    I hold a call A load the front heavy and if the trailer starts to wobble slow down. That's the basics, can you back up?
    Boerseun likes this.
  17. Mar 25, 2019 at 7:26 PM
    Liquid unlucky
    North east Texas
    2019 Toyota Tundra
    Class A CDL auto correct
    NewImprovedRon likes this.
  18. Mar 25, 2019 at 7:29 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    pulled a medium box with my i4 Camry from CA to TX. never again.
  19. Mar 25, 2019 at 7:30 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Just towed one across British Columbia with no issues. Barely felt it out back and had to remember to back off on tight corners haha
  20. Mar 25, 2019 at 7:32 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    You will be just fine; won't even know it's behind you. Until you do 80 MPH and look in your rearview mirror and see the "max 55MPH" sticker on the trailer. Ask me how I know.
    In all seriousness, these trailers are stout but not extremely heavy. You will pull that with no issues.
    YeeYeeTundra likes this.
  21. Mar 26, 2019 at 3:20 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Thinking about this Uhaul trailers probably utilize a pin to accommodate vehicles without a 7way and make wiring easier.
  22. Mar 26, 2019 at 6:47 AM
    Not like a pro but I'll get it done. I've backed a boat into the water a few times. Slow and steady. Call me Terrapin.
  23. Mar 26, 2019 at 7:31 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Towed one with my 2nd gen when moving across town. Towed just fine and backing it up was no issue as well on flat surfaces. Uphill I'm sure would have engaged the trailer surge brake. Not once has U-Haul ever mentioned the latching pin to me for backing up, I'll have to check that out! As others have said, they tow pretty good because of how much they weigh empty. When you go to pick it up, I always check the master cylinder to make sure it at least has brake fluid in it. If not, I mention it to the U-Haul guys. In town, not really a big deal. If I was going a large distance I'd ask for another trailer if possible, that is verified to have brake fluid in it and "ok" looking tires.
    My uncle towed one from CA to MT with his Tahoe for us when we moved up here ( I didn't have my truck yet). No real issues except around 60-65mph it would start to wag so he just kept it under that and was fine. We indeed loaded it "approx" 60/40 (no stranger to trailers, he's towed a 39' trailer to every state in the US and I've loaded a Boy Scout troop trailer hundreds of times) it just wanted to wag. We believe it may have been the tires contributing and probably could have gotten a little more weight forward, but eh it worked.
    Hitch up and safe travels! It'll be fine!
  24. Mar 26, 2019 at 8:16 AM
    Outbound
    Aaron
    Northern Alberta
    I towed one of those with my old 94 yota pickup that had a 4cyl engine. Made it over the Pine Pass in northern BC in a March blizzard. You'll be fine. :D
  25. Mar 26, 2019 at 12:02 PM
    Liquid unlucky
    North east Texas
    2019 Toyota Tundra
    Easiest way to back up for beginners. Hand at the six oclocknposition and move your hand in the direction you want the trailer to go. Watch the tires more that the rear of the trailer. Slow and steady and you'll be a pro in no time.
  26. Apr 5, 2019 at 9:06 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Pulled one 700 miles to Florida with my Gen2. Zero problems. Only issue I had was a small UHAUL charge showed up on my credit card well after the trip. I wish to god I could remember what it was for, this was a few years ago and I honestly can't remember. But it was something I had to call and argue to get taken off. So monitor your charges after the trip, in case they try to slip something like that past you.
  27. Apr 5, 2019 at 9:35 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You’ll be just fine pulling this 6x12. I’ll done some long trips using this same Uhaul 2 axle trailer and its much more stable than towing the same size single axle with no brakes. Most of these 6x12 Uhauls have a 4 pin connector which is perfect on our tow packages. I’ve never had a brake problem reversing, as noted by another poster.
    Just pay attention to loading distribution inside the trailer and you’ll be fine.
    Worst part about towing is the other drivers that like to dart pass (then brake) around and in front of you in a hurry to their next coffee house meeting. Stay right and maintain your speed and distance.
    Your truck is made for this towing trailer. Stay off CC and watch the O/D button with headwinds/inclines.
    FirstGenVol[OP] and Watt maker like this.
  28. Apr 5, 2019 at 5:41 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I pulled one similar to that with my old Tacoma on a 7 hour trip. The Tacoma did well it was just a little slow and in 4th gear pretty much the whole time...But I would NOT tow it across country with a Tacoma. With a Tundra you will be fine.
  29. Apr 5, 2019 at 6:10 PM
    Westside_cook
    Westside_cook New Member
    2018 Double Cab in Superwhite
    Stock
    I just want to throw this out there. I wouldn't have high expectations of any Uhaul equipment. I once rented a 26' boxtruck from them for a 350mile one way drive. Honestly the worst drive of my life. The vehicle shook violently past 40 mph. As I was driving I lost all power (2x) once almost causing accident. And for a few minutes I had to pull over because the headlights shut off (while driving) and didnt want to come back on. It was terrible. Just my .02.
  30. Apr 5, 2019 at 7:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You’ll be fine. Drove that exact uhaul when moving from here to Memphis (5 hour trip made twice with a full load - between 5-6k of weight)
    Just be cautious, load distribution should be about 80/20 (80% of weight should be before front midline of trailer), go slower than most traffic, take your time and keep a healthy distance between you and vehicle in front of you at all times. If trailer starts to sway, never slam on your brakes, keep control and slowly apply brakes. (This is possible either with bad weight distribution, going too fast, or windy conditions)
