Adding a Sub
Discussion in 'Audio & Video' started by MJ_19Tundra, Mar 24, 2019.
  1. Mar 24, 2019 at 1:40 PM
    MJ_19Tundra
    MJ_19Tundra [OP] Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    All i want to do is add some thump. So I want to add 1 or 2 subs in my 19 crewmax. I'm curious on what I need other than sub, box, and amp. I have installed plenty of subs and amps but never to a stock head unit with stock amp. I know I need something else to hook to the stock wires at the stock amp to power sub amp via rca cables.
    Really want to jump on this but need some insight.
    NON JBL
  2. Mar 24, 2019 at 1:48 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Jbl or non-jbl?
  3. Mar 24, 2019 at 1:48 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Non JBL ....knew I forgot something
  4. Mar 24, 2019 at 1:48 PM
  5. Mar 24, 2019 at 2:02 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    2nd tech12volts . You can get a complete package in whatever price range you want to stay in or he can build you what you want .
    To keep the stock headunit you will need a digital sound processer. I believe James sets it up so it's good to go once you get it . Add an amp of your choice and you should be in business. There are some affordable 5 channel amps that fit well under the passenger seat .
    There are some great builds in the audio video threads.
    MJ_19Tundra[OP] likes this.
  6. Mar 24, 2019 at 2:08 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    @james@tech12volts what is the price on a sound processor that's ready to go?
  7. Mar 24, 2019 at 2:19 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Would the LC2i 2-channel line out converter work?
    I would tap into one of the speakers output side of the factory amp and tie it into the lc2i. Then run RCA cables to new amp. Is this correct?
  8. Mar 24, 2019 at 2:21 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
  9. Mar 24, 2019 at 2:25 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Audio Control LC7I is a good option since it’s has the option to keep your bass from falling off with the volume increase from your factory head unit, $150 ish. Also if you want descent bass without building a box then the kicker hideaway works pretty well when you get it tuned in and it’s super simple to install.
  10. Mar 24, 2019 at 2:27 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    NON-JBL. DC
    I added a sub with dual JL 10'S and single channel 500 watt JL amp from JRT. I had to run power to the amp that I placed right next to the OEM amp and run speaker wire from the amp to the sub, but JRT makes plugs for every thing else, even adding the RCA jacks to the factory amp for the new amp. ZERO factory wires cut, leaving amp power wires I could remove everything in 10 min and have back to factory. best pic I got of amp.
    PS- JRT is on vacation per Facebook with family in Daytona right now.
  11. Mar 24, 2019 at 2:32 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    @DCB500 @TomC843
    I'm wanting to leave everything and just add a new amp that powers the sub only. So am I correct that I need to get a line out converter and tap in to the outgoing +/- wires for one speaker and connect it to the LOC? Then run RCA cables to the new amp along with power from the battery to new amp.
  12. Mar 24, 2019 at 2:34 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    MJ_19Tundra[OP] and TomC843 like this.
  13. Mar 24, 2019 at 2:35 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    2014-Up Toyota Tundra LOC w/Entune Harness
    Be the first to write a review
    This LOC/wiring setup is specifically made with a custom harness to plug-n-play with your 2014 and newer Toyota Tundra (except JBL). Choose from a 2-Channel or a 4-Channel LOC to connect your stock Entune stereo to an amp.
    Scosche's LOC80 line output converter allows you to connect a receiver with no preamp outputs to an amplifier without speaker-level inputs. The LOC80 handles a speaker-level signal up to 80 watts RMS per channel, and converts it to a line-level signal you can plug into your amp's input.
    I think you are correct. 40 dollars on tech12's site
  14. Mar 24, 2019 at 2:37 PM
    TomC843
    Tom
    Charleston, SC
    This is what you will need to cut nothing BUT talk with JRT during the week, this is from is web site.
    https://www.shop.tech12volts.com/product.sc?productId=521&categoryId=32
    this is what is under my seat. BUT need power kit from anywhere.
  15. Mar 24, 2019 at 2:38 PM
    TomC843
    Tom
    Charleston, SC
    lol, what Eric said faster than me.
    Eric104 and MJ_19Tundra[OP] like this.
  16. Mar 24, 2019 at 2:40 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
  17. Mar 24, 2019 at 2:45 PM
    TomC843
    Tom
    Charleston, SC
    Yes I felt better about it than cutting OEM amp wires, even though there are people that will show you what to cut to add the LOC80 that cost about $10 with out the amp harness. Will also help with quick removal if traded because you dont get that back, I can pull and reuse or sell.
  18. Mar 24, 2019 at 2:45 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    Tom my copy paste skills on fire today!!
    It looks like the LOC plugs into the headunit and makes an RCA out you would plug into your new amp. I'm curious how this will turn out. The stock system suffers so badly from the lack of bass, but the vocals seem to be good enough to wait on a complete upgrade.
  19. Mar 24, 2019 at 2:48 PM
    TomC843
    Tom
    Charleston, SC
    no, the plugs you see are the two plugs going into the factory amp. My system hits nice and hard enough for anyone over 25 years old.
  20. Mar 24, 2019 at 3:12 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    68FAA403-4B8C-4AE1-AF6D-23C96F522715.jpg 68FAA403-4B8C-4AE1-AF6D-23C96F522715.jpg
    Yes you can tap into the factory harness or taco tunes makes a harness that’s plugs into the factory plugs at the factory amp. I unfortunately did not know about this option before I had the converter and amp installed and apparently the installer was not either so my plug wires were cut but this should work.
  21. Mar 24, 2019 at 3:27 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    I think this only works with their amps tho.
  22. Mar 24, 2019 at 3:28 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    How does your new amp know when to turn on?
  23. Mar 24, 2019 at 3:31 PM
    TomC843
    Tom
    Charleston, SC
    Has wire from harness that I connected to new amp. Blue I think.
  24. Mar 24, 2019 at 3:31 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Yes if you want to use the plugs on the ends but if you are not using one of their amps then you can just clip those off and hardwire.
  25. Mar 24, 2019 at 3:32 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Ahhh I see it!!!!!
    There is thy remote wire!!!! Hell yea!
    TomC843 likes this.
  26. Mar 24, 2019 at 3:35 PM
    TomC843
    Tom
    Charleston, SC
  27. Aug 18, 2021 at 4:46 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Guys, I’m in need of some help. So am I understanding correctly that I can buy the Taco tunes harness, and connect it directly to my new amp/sub?
    I’m looking at a amp/sub combo from JL audio. do I literally need to plug in the harness to the factory amp, run it to the new sub/amp combo, run a power wire, and I’m good to go?
    I don’t have to mess with the stock HU at all?
  28. Aug 18, 2021 at 5:07 PM
    AZBoatHauler
    So.Arizona
    Get in touch with James from Tech12Volts. He will provide you the harnesses you’ll need and the gear you want. You have a few options but you’ll either need to do a DSP, LOC, or pick an amp that can accept high voltage inputs. Or replace the HU and skip all those which is what I ended up doing.
  29. Aug 18, 2021 at 6:42 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    o, it looks like I can get the LC2i, with a harness from either Tech12 or Taco Tunes As long as I have both the harness and the LC2i, and can connect those into the new amp/ sub combo and be good to go?
  30. Aug 18, 2021 at 7:44 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Are you just adding the powered sub and leaving everything else stock?
