My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Feb 1, 2019 at 11:33 AM
    #181
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    Installed the JDM ASTAR's today and no hyper flash. Nice and bright. Problem solved
    Now, let's see how long they last
  2. Feb 1, 2019 at 12:47 PM
    #182
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Installed the JDM ASTAR's today and I have Hyper Flash. This is on a 17 with 19 Pro LED HL's and iHacker harness.
  3. Feb 1, 2019 at 1:31 PM
    #183
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I saw a new TRD Pro turning right in front of me the other day at an intersection and after reading this thread paid attention to his turn signals. They were definitely weak.
    I've stopped in front of a lot of store mirrors lately looking at mine but mine seem really bright. However, I have a '16 with the '18 LED headlights. I kept my '16 turn signal bulbs when adding the new lights. My guess is the '16 setup is different than the '18's as mine don't seem weak.
  4. Feb 1, 2019 at 1:41 PM
    #184
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    I completely agree Jeremy ... it seems like the newer models with the DRL strip above and below (18' - 19') have weak turn signal lights. My incandescent bulb on my 16' is pretty bright!!! ... but then it is also used as a DRL.
  5. Feb 3, 2019 at 7:35 PM
    #185
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Installed JDM Astar and I have hyperflash on my 16 with stock fronts, reason could be because I have siriusLED bulbs for my rear blinkers - siriusLEDs supposed to have resistors built in.
  6. Feb 4, 2019 at 8:26 AM
    #186
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Does anyone have documented steps and pics how you installed resistors on the rear housing? Thanks
  7. Feb 4, 2019 at 9:09 AM
    #187
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I just installed them in the front on my 13' Avalon (TAH). Hyperflash… I ordered some LEDs for the rear to see if they still hyperflash. Is so, I will install the 6 ohm resistors I also purchased. lol
  8. Feb 4, 2019 at 12:42 PM
    #188
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Installed the Lasfits with NO hyper flash on an 18 SR5.
  9. Feb 12, 2019 at 9:19 AM
    #189
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    So it appears some with ‘18 SR5 had no issue, and a few did..? I have ‘18 SR5 with halogen headlight, single LED DRL (the strip on bottom edge). I’m about to swap out with 2019 TRD pro headlights + iHacker harness.
    Has anyone done this and ran into the hyper flashing issue?
  10. Mar 11, 2019 at 7:32 PM
    #190
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    To those that installed the V6 Tritons, did any of you use the rubber spacers that came in the kit for a better seal? Also any use for the gel? Mine didn’t come with any instructions what so ever. Sure it should be plug and play just want to me sure I’m not missing something here that may bite me in the butt later.
    Hatwsneezing likes this.
  11. Mar 16, 2019 at 4:18 PM
    #191
    pmcgeorge1964
    pmcgeorge1964 New Member
    Paul
    2018 Tundra TRD Quicksand
    The gel is supposed to be water repellent. I used it and the rubber spacers, spacer to get a good seal and limit vibe. Gel to seal up the connector along with the heat shrink.
    Travo60 likes this.
  12. Mar 22, 2019 at 11:28 AM
    #192
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Ok,
    so anyone want to sum up how I can replace my brake lights and all 4 blinkers without hyperflash and without spending an arm and a leg if possible?
  13. Mar 22, 2019 at 11:59 PM
    #193
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Well, Well, ..this afternoon/evening a guy in his new little mercedes (at eye level) was waiting a block away for me to pass on by... I definitely had my turn signal on, signaling I was turning in to where he was leaving.
    As I get closer, I see him mouthing, raising his hands , shaking his head.
    I’m thinking, “dude, it’s on” ... I think he saw it last moment, and then I remembered reading this thread. Gassing up, I turned on the blinker, went up front -and it is hard to see in the daylight.
    JohnLakeman likes this.
  14. Mar 23, 2019 at 4:47 AM
    #194
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Pretty sure hyperflash only occurs when you replace turn signal incandescent bulbs with LEDs. The LEDs have much less resistance than the stock incandescent bulbs, and when you install them, the flasher thinks the lower resistance indicates a burned out turn signal bulb.
    If you use LEDs for brighter turn signals, then you may have to replace the lost resistance with a resistor. If you're using LEDs only in front, then 6 ohm at each front corner MAY be necessary (sometimes not necessary depending on the LED). If you're using LEDs front and rear, you can KISS by using only 3 ohm each side behind tail lights.
    Resistance is counter intuitive by not being additive. Something about adding the reciprocals or something like that, but understanding the electric theory is not important here...it works, others have said so.
  15. Mar 23, 2019 at 5:41 AM
    #195
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    Put the Amber JDM astars in the front of my 18 about 4 months ago. Work perfect, no hyperflash in the 18+ w stock led headlights. Also have the red ones for the brake lights. Have 921 bulbs for the rear but was too lazy to do the resistor thing, plus the LEDs didn't look that much brighter than the stock halogen bulbs
  16. Mar 23, 2019 at 6:41 AM
    #196
    JohnLakeman
    Thanks @davescarp. That is excellent information on both topics, hyperflash and brightness. If you added the 921 LEDs in the rear, you probably would need the resistors.
    Those LEDs are exactly what I was planning to try based on my evaluation and referrals here (maybe yours). But, your input regarding brightness being about the same is not encouraging. In fact, your observation seems to call the JDM astar rating of 1260 lumens into question. The stock 2018+ 7444NA incandescent signal bulb is only rated at 265 lumens (high level filament), 21 lumens (low level filament). The LEDs should be nearly 5X brighter than the stock bulbs. :confused:
    Not sure what's up with these lumen ratings, but I'll see when I finally get to try them. :thumbsup:
  17. Mar 23, 2019 at 6:48 AM
    #197
    davescarp
    Massachusetts
    '18 DC TRD OR
    In the front the JDM astars were a huge improvement, and noticable for the brake lights too. I bought red 921s from super bright LEDs for the rear blinkers and 1) they absolutely hyperflash, 2) we're brighter than stock but not enough to motivate me to add resistors. In fact that's the only light in my truck that I didn't update to leds
  18. Mar 23, 2019 at 7:05 AM
    #198
    JohnLakeman
    Did you do the amber DRL delete, or did you keep them? Motive for question: To assess what temperature your housings are being subjected to with continuous operation of amber LED DRL if you have them. (I think the JDM Astars have two power levels just like the stock bulb, but they don't specify low level lumens, only the high level 1260 lumens.)
    You don't happen to have an infrared thermometer gun do you? Would really like to see some housing temp readings near the Astars after 30 minutes to an hour of DRL operation.
  19. Mar 23, 2019 at 7:14 AM
    #199
    CCLJ03
    Craig
    I ordered the JDM ASTAR fronts - https://www.amazon.com/dp/B00PHVUWR8/ref=cm_sw_r_cp_api_i_n3JLCbNYRC6V6
    And these ANTLINEs for the rear brake lights - https://www.amazon.com/dp/B07MYX6Z2N/ref=cm_sw_r_cp_api_i_14JLCb1PK0DZH
    By what I’ve read I shouldn’t need resistors. I’m still working on finding a suitable rear blinker replacement bulb, and I’ll probablY need resistors for that but we’ll see. Resistors make me nervous for some reason...? Probably because I don’t know what TF I’m doing.
    I’ll report back on Monday when I get these thinks installed with before and afters.
  20. Mar 23, 2019 at 7:30 AM
    #200
    JohnLakeman
    Your fronts are exactly what I ordered. I should have clarified for @davescarp...JDM astar makes many 7443/7444 base LEDs.
    I ordered these for the 921s for the rear: https://www.amazon.com/Nakobo-Backu...YLXX&qid=1553351199&s=gateway&sr=8-1-fkmrnull
    I would prefer the 921 base on the LED I ordered for the front, but JDM astar doesn't offer it. These are not ideal, but the best I could find in 921 with a metal casing to absorb the heat and a projector lens.
    CCLJ03[QUOTED] likes this.
  21. Mar 23, 2019 at 7:37 AM
    #201
    CCLJ03
    Craig
    So you ordered those for the blinker spot right? Because I think the top (blinker) bulb is the only 921. I had about 14 tabs open on my internet last night freaking out about the damn number codes...
    Does 921 fit all these exterior lights on the Tundra?
  22. Mar 23, 2019 at 7:42 AM
    #202
    JohnLakeman
    No, not at all. Only rear signal, and high mount stop and cargo. Good thing too, I wouldn't want to use these cheapazz replacement LEDs anywhere that didn't need a lot of lumens/high visibility. In fact, not sure I will use them if they're too hot. Conversion to LEDs is not a mod thing for me...it's all about visibility and safety. I will use the stock incandescents anywhere they will work for me.
    WZ KTM and CCLJ03[QUOTED] like this.
  23. Mar 23, 2019 at 7:52 AM
    #203
    JohnLakeman
    Keep in mind that service life in the rear housing is irrelevant...the rear housings are easy to remove. If one of these cheap LEDs fails in a month, you can replace it , or try another brand, or replace with the stock bulb easily. On the front housings, not so much...I wanted to see the manufacturer claiming 20K-30K hours.
    I examined the negative reviews pretty closely to see how many "failed in a month" reports there were, and how many one star reviews. As I recall, the Nakobo were ultra cheap but got great reviews. But...you know how that goes...YMMV.
  24. Mar 23, 2019 at 10:55 AM
    #204
    Fireman/68W
    Fireman/68W New Member
    J
    S/E Wyoming
    2018 White SR5 Tundra
    A lot in progress!
    I have 2018 SR5 as well, Amazon says the 7443 Amber is not going to fit. Is Amazon site just being dumb? I'll buy these. I just wanna make sure it's the right ones.
  25. Mar 23, 2019 at 11:09 AM
    #205
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Those JDM Astars are exactly what I ordered for my front turns and they work perfectly without adding resistors. And they are plenty bright.
    Still going strong, although I may order a second set just in case one goes bad.
    I remember seeing that Amazon says they are incompatible. They work fine.
    TWJLee and Fireman/68W[QUOTED] like this.
  26. Mar 23, 2019 at 11:10 AM
    #206
    JohnLakeman
    I don't always trust the Amazon compatibility check. In the case of LEDs, it should always say an LED doesn't fit because the trucks didn't come with LEDs.
    I suspect that the Amazon software is looking for a 7444NA bulb to be right for your 2018 truck, and it's finding that you ordered a 7443 base LED. The 7444NA incandescent bulb, which is two function bulb (DRL/Turn signal) is what my 2018+ headlights have pre-installed. The 7443 base and the 7444 base are both two element bulbs and they are interchangeable. There may be a same difference in the incandescent spec, but for the LEDs I doubt that it matters. The 7440 base is not an exact replacement since it is a single element bulb, but some LED manufacuturers lump it in with the 7443 and 7444. The 7440 base LED will work, but it will always be at the same brightness. The others may be too, I dunno.
    Fireman/68W[QUOTED] likes this.
  27. Mar 23, 2019 at 3:31 PM
    #207
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    I installed Lasfits LED bulbs for the turn signals that I bought from @darkknight2014 and no hyper-flashing. They worked perfectly! Much better than OEM bulbs.
    By the way, I have a 2018 with OEM LED headlights
    darkknight2014 and Fireman/68W like this.
  28. Mar 25, 2019 at 6:50 PM
    #208
    CCLJ03
    Craig
    plumber802 and JohnLakeman like this.
  29. Mar 25, 2019 at 6:58 PM
    #209
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    When I have my headlights on the drl goes to white. But when I drive and have just drl on they are amber. How do I make it white with just drl on. It already turns amber when I use blinker.
  30. Mar 25, 2019 at 7:00 PM
    #210
    CCLJ03
    Craig
    So you want it white all the time except for when you turn your blinker on?
