What is the biggest size tire I can put on my truck after I have it leveled??
Discussion in 'Wheels & Tires' started by Angelbunch1, Mar 21, 2019.
  1. Mar 21, 2019 at 6:15 PM
    Angelbunch1
    Angelbunch1 [OP] New Member
    Angel
    2015 tundra SR 4x4 Double cab
    I heard a 33 will fit, but I've also heard that a 34 MIGHT fit.
  2. Mar 21, 2019 at 6:23 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Depends on the amount of level, wheel offset, wheel width, tire width, tire OD.
    More to it than just will it fit or not.
    OR18TRD, zcarpenter92 and Watt maker like this.
  3. Mar 21, 2019 at 6:31 PM
    Angelbunch1
    Angel
    It's a 2.5 to 3 inch leveling kit. I havent bought the tires and rims yet. My boyfriend also said after the leveling I need a +20 offset to make the tires stick out about 4 inches. The guy that's doing it said i needed a -12 offset, so I'm confused.
  4. Mar 21, 2019 at 6:34 PM
    33” is like stock tires. With the right offset you can stuff 35” in there or maybe more
    zcarpenter92 likes this.
  5. Mar 21, 2019 at 6:34 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    7millionx12.5x20.
    ... too many variables man! 18s, 20s, stock wheels, offsets, mods? Conservatively a 33. Max with a saw and hammer "Put 35s on it Kinfolk "
  6. Mar 21, 2019 at 6:38 PM
    Angelbunch1
    Angel
    Sorry, I dont know what I'm doing. Never got to do this before. They are 18" rims
    Boerseun and Therin7 like this.
  7. Mar 21, 2019 at 6:44 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    295/55/20 is what I’d do
    Angelbunch1[OP] likes this.
  8. Mar 21, 2019 at 6:48 PM
    Therin7
    Therin7 New Member
    West Tennessee
    They have 18 inch wheels, im assuming stock. Personally I will be going with 33s or 275/60r20s when I upgrade. I wont have anything more than a level done to mine.
  9. Mar 21, 2019 at 7:55 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Your boyfriend is confused, The more negative wheel offset you have, the more your tire will stick out.
  10. Mar 21, 2019 at 8:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Definitely do a search. this is the most commonly asked question here and there are probably a hundred threads about it. And why do you want your tires to stick out 4 inches?
    33s fit on stock suspension.
    T-Rex266 and Law323 like this.
  11. Mar 21, 2019 at 8:33 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
  12. Mar 21, 2019 at 8:41 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Sounds like your boyfriend is this kinda guy...
    Cmilla25 and plumber802 like this.
  13. Mar 21, 2019 at 8:53 PM
    Angelbunch1
    Angel
    Brian, not to offend anyone, but I do not like that white truck at all with the tires sticking out like that. Hahaha... so if I done a -12 how much would they stick out?
  14. Mar 21, 2019 at 9:01 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    A -12 would waayy out there. You don’t want that. A +20 with a 12.50 wide tire will stick out about an inch. And you could fit 34 inch tall tires with some trimming. Like others are saying it all depends on the tire size, wheel offset etc.
  15. Mar 21, 2019 at 9:04 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    -12mm will stick out a lot! Here is my truck with 18x9 with +25mm offset and 305/65-18 tires. 33.6" x 12". They stick out about 1.25"
    Offset is the measured distance between the hub mounting surface and the wheels center line.
    With X being the determined offset, the hub mounting surface on positive offset wheels is X amount forward from the wheel center line. The hub mounting surface on negative offset wheels is X amount backwards from the wheel center line. The hub mounting surface on 0 offset wheels is the wheel center line.
  16. Mar 21, 2019 at 9:20 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    When I had my 6100 level kit installed I mounted 275-70-18 At 33’s. I only had to heat the small front flap and bend it forward about a half inch. Otherwise all good with OEM rims. A fellow member predicted it and that’s exactly what happened.
  17. Mar 21, 2019 at 9:27 PM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    Years ago I owed a 78 Bronco that I put wide tires on with a + offset rims, that was the worst thing I've ever done, that thing would follow every grove in the highway, scared my wife half to death while towing a small travel trailer, she said she almost put the Bronco sideways many times. Most rigs will steer the best with no offset.
  18. Mar 21, 2019 at 9:38 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    2 +2 =4 then 4+4 is 4? Just messing with you. I had the same trouble with offset figuring. Look over this see web site and you will figure it out.
  19. Mar 22, 2019 at 12:41 AM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    A 33 will fit with stock suspension and +25 offset. If you have wide flares, 0 offset will bring you to the edge of the flare. You just have to decide how far out you want your tire to extend. Every 13mm is around a 1/2”.
    “-“ extends farther out. “+” sucks it back in.
    You can do 35s with that kit with only minor modifications, if any....unless you have a high positive offset.
  20. Mar 22, 2019 at 9:49 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    +25 seems to be the sweet spot.
