Need Help: Retractable Bed Covers
Discussion in 'Tonneau Covers, Caps and Shells' started by tbrown, Feb 28, 2019.
  1. Feb 28, 2019 at 8:43 AM
    tbrown
    tbrown [OP] 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    I am wanting to do an overbed rack with a retractable tonneau cover. I currently have an oem tri fold cover that has its own rails and brackets that relocate the bed track system lower. I have some accessories that mount into my track system, so I can’t give up use of that. Does anyone know of a retractable bed cover that has its own mounting rails and brackets that relocated the track system lower? Everything I’m seeing either says I have to remove the track system or use it to mount the cover.
    HELP!
  2. Mar 20, 2019 at 12:31 PM
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    Truck Covers USA has a retractable cover, the American Roll, that they sell with a kit to lower the OEM bed rails. I just installed the cover a couple weeks ago, it is very very nice! Lowering the rails wasn't difficult, just took some time and I ended up having to spray some bedliner on the metal where the rails were as the bedliner was done after the OEM rails were installed. The rails end up being about 3" lower than the OEM installed height.
    The cover install took about 2 hours, probably could've gone more quickly but I was taking my time so I didn't mess anything up. Fit and finish is superb, looks fantastic and functions perfectly. It has yet to rain since I installed it, but I think it'll be pretty close to water tight.
    The cover can be ordered with Yakima tracks pre-installed or they can be installed after the cover goes on the truck. I am in the process of installing the Yakima tracks and rack system sold by Truck Covers USA, just waiting on the parts to arrive. You'll need a rivnut tool to install the Yakima tracks, once those are on, the rest is easy, same as installing Yakima rack on top of vehicle. Here's a couple pics of the cover. Once I have the tracks and rack installed I'll add some new pictures.
    Mater and tbrown[OP] like this.
  3. Mar 20, 2019 at 12:47 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Are you able to keep you're current relocation brackets? If so you can just order a roll-up cover for a non-cargo rail system
  4. Mar 20, 2019 at 12:51 PM
    dlos
    dlos Truckin'
    Mods Mods Mods....
    Not 100% sure I understand the question but yes, you can order the same cover for an installation that does NOT have the bed rails, or you can remove the rails and not reinstall them if you don't think you'll use them. The kit they sent to lower the rails consisted of 6 black rectangular pieces of steel with holes drilled to match the original mount points for the deck rails and holes to reinstall the rails lower. It also came with the screws/bolts to use to remount rails.
    Simply put, the relocation kit just drops the rails 3" so that you can then mount the tonneau cover rails on the bed using the clamps.
  5. Mar 20, 2019 at 12:57 PM
    belanger9
    Edmonton, AB
    A bunch
    OP said they already have a tri-fold with the relocation brackets, so was asking if they could keep those brackets or do they have to sell those brackets with the cover. If they can keep them then they can just order a cover for non-cargo rails trucks like you said.
  6. Mar 20, 2019 at 1:00 PM
    dlos
    dlos Truckin'
    Mods Mods Mods....
    Ah, thanks for the clarification! So, to answer the OP's question, if the kit that lowered your rails dropped them at least 3" then you should be fine. You need at least 3" to work the clamps into place and tighten the cover's rails.
  7. Mar 20, 2019 at 2:25 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    The Retrax cover will mount without using the rail, allowing you to do whatever you like with the railing location.
    tbrown[OP] likes this.
  8. Mar 21, 2019 at 10:01 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Haven't installed it (yet), but it seems the TracRac SR system only uses 1 bolt that goes through each of the stake pockets. Should not be affected by any retractable cover. As dlos said, the american roll cover from truck covers usa has an add on from Yakima that works directly with their rails. I put the american roll cover on this weekend but cant justify spending the money on their rack. Will be looking on CL for a TracRac TracOne system (there are lots) and swapping the feet out to work with TracRac SR rails. Replacement feet that work with TracRac SR rails can be purchased on e trailer.
  9. Mar 21, 2019 at 10:03 AM
    dlos
    dlos Truckin'
    Mods Mods Mods....
    What cost are you seeing for the rack system from Truck Covers? I purchased all of it directly from them for $225+$40 shipping.
  10. Mar 21, 2019 at 3:28 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Everywhere I've seen (real truck and auto anything) have the rack for ~$975. I misunderstood earlier. I was describing a full rack (Truck Covers USA American Truck Rack) not the yakima rack. I guess the original poster will have the clarify if he is looking for a small rack that only goes about the cover or a full rack that clears the roof.
  11. Mar 21, 2019 at 3:31 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Looking back, not even sure if the OP is looking for a rack, but this should serve as good information for someone else looking.
    dlos likes this.
