New here
Discussion in 'New Member Introductions' started by Dpy, Mar 19, 2019.
  1. Mar 19, 2019 at 6:15 AM
    Dpy
    Dpy [OP] New Member
    Hey folks , new here. I have owned a 2006 Tundra sr5 double cab 2wd since 2008. I got lucky bought it from my dad with 24,000 miles for $10,000. Anyway, in the last few years I have bought a class A motor home diesel pusher and a 2012 Jeep liberty to tow behind the MH also from my dad. I decided that since I am paying ins and taxes on the Tundra and the Jeep Liberty I needed look for a truck that I can tow behind the MH and also use on a normal bases being I only use the jeep as a tow. I would need a 4x4 truck that has a neutral selection on the transfer case. After checking out all the trucks for sale and having heart palpitations over the prices of even older used trucks . I decided to fix up the ole Tundra and add a driveshaft disconnect so I can flat tow it. Here is what I am doing, first I removed the interior and carpet. I scrubbed and pressure washed the carpet, got it really clean but not perfect. I looked for a replacement and really got sticker shock when the only carpet I could find for the double cab that could be bought was from a oem parts dealer for around $900.00 ( Factory list was $1300.00 plus) . I scrubbed the leather seats, have ordered leather dye to touch the seats where they were the leather was worn , ordered a drivers seat bottom because it had a worm through place . I ordered a new cable for the defrost damper control which had was not functioning properly. I will replace the shocks, with some sort of upgrade and redo all brake pads and finally I will do the timing belt /water pump . which is way over due ( 150,000 miles on truck) and upgrade the stereo. Oh and I did order a set of weather tech floor mats for front and back. I figure I will spend around 2500.00 on this truck . Compared to the cost of even a 2010 to 2012 I will save a ton of money and have a good reliable truck. I realize that pickup trucks have become sort of like a farm tractor, they are holding their value and are worth spending money on to keep them going rather that trading in every couple of years.
    OR18TRD, Black Wolf and Pinay like this.
  2. Mar 19, 2019 at 6:16 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  3. Mar 19, 2019 at 6:17 AM
    Welcome from Ohio.
  4. Mar 19, 2019 at 6:28 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Welcome!
    From Cleveland, Ohio
  5. Mar 19, 2019 at 6:29 AM
    Welcome from NY.
  6. Mar 19, 2019 at 6:33 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Sound like a nice project. We need pictures! I can't read fast, so type slow. Welcome from NEPA
    Black Wolf likes this.
  7. Mar 19, 2019 at 6:57 AM
    Dpy
    Dpy [OP] New Member
    I will do some pics but forgot to take pics of carpet before, duh. It was nasty.
  8. Mar 19, 2019 at 7:04 AM
    Welcome from CO. Yep...you have been busy fixing up that 06. Lots of 1st gen Tundra members here. Great trucks.
  9. Mar 19, 2019 at 7:14 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Wel0cme from SE PA!
  10. Mar 19, 2019 at 7:16 AM
    Tempest
    Tempest You feel lucky??!!
    2015 Limited TRD
    Welcome from AZ! :tumbleweed:
  11. Mar 19, 2019 at 7:25 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA .....;)
  12. Mar 19, 2019 at 7:26 AM
    Welcome from Texas
  13. Mar 19, 2019 at 7:31 AM
    Dpy
    Dpy [OP] New Member
    Thanks for the reply's, I have learned in recent years joining a forum has great advantages . I have joined several other forums after owning certain vehicles for long periods of time and have learned a lot. I have done my own mechanical work for 4 decades and I still am learning from others experience . BTW, Grey Wolf , I actually just started on this project this past Sat. I usually jump in on something wide open.
  14. Mar 19, 2019 at 8:08 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  15. Mar 20, 2019 at 4:36 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  16. Mar 20, 2019 at 4:43 AM
    Mnorris1206
    08 tundra
    Welcome from Indiana.
    Fyi rockauto has rubber floor instead of carpet for our trucks. Have not seen it how they look but did notice they had it.
  17. Mar 20, 2019 at 4:47 AM
    Mnorris1206
    08 tundra
  18. Mar 20, 2019 at 5:06 AM
    Ericsopa
    Ericsopa Old man and the sea
    Welcome.
  19. Mar 20, 2019 at 6:37 AM
    Welcome
  20. Mar 20, 2019 at 6:39 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    T-Rex266[QUOTED] likes this.
  21. Mar 20, 2019 at 6:44 AM
    Dpy
    Dpy [OP] New Member
    Mnorris, thanks I looked but the only have acess cab not double cab just like everybody else.
  22. Mar 20, 2019 at 5:33 PM
    Dpy
    Dpy [OP] New Member
    First try loading pics . This is carpet reinstalled after removal and cleaning. Poor lighting.
  23. Mar 20, 2019 at 5:34 PM
    Dpy
    Dpy [OP] New Member
    Front drivers area.
    Watt maker likes this.
  24. Mar 20, 2019 at 5:36 PM
    Dpy
    Dpy [OP] New Member
    I Wish I had taken pic before cleaning but it was bad.
  25. Mar 20, 2019 at 5:38 PM
    Dpy
    Dpy [OP] New Member
    Lighting is weird . Oh new pioneer bluetooth/ dvd/cd .
  26. Mar 20, 2019 at 6:35 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego
  27. Mar 21, 2019 at 4:35 AM
    Dpy
    Dpy [OP] New Member
    I love to visit New Mexico. One of my favorite states to take my motor home.
