Stock wheels with a lift
Discussion in '2nd Gen Tundras (2007-2013)' started by dcon374, Sep 19, 2016.
  1. Sep 19, 2016 at 4:49 AM
    dcon374
    dcon374 [OP] New Member
    Dustin
    2012 Silver Crewmax Platinum Tundra
    Stock
    Hey guys. It is my first time in the forums and looking forward to connecting with other Tundra fans. I want to lift my 2012 Tundra Platinum Cremax but want to keep the stock wheels. Does anyone have pictures if this set up? I would like to get a feel for how the truck would look.
    Thanks
  2. Sep 19, 2016 at 5:09 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    I'm not lifted, but howdy and welcome!
  3. Sep 20, 2016 at 8:26 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Something like this?
  4. Sep 20, 2016 at 10:39 PM
    Asutton
    Asutton New Member
    Andrew
    2008 Tundra Limited
    3" level in the front
  5. Sep 20, 2016 at 10:42 PM
    Asutton
    Asutton New Member
    Andrew
    2008 Tundra Limited
    This is my 2008 tundra with 3" leveling kit in the front, no lift in the back. I have 35x12.50x20. I have 1.5" bora wheel spacers on all 4 wheels. I can get you some more pics if you want
  6. Sep 21, 2016 at 7:00 AM
    dcon374
    Dustin
    Stock
    That looks great. A few more pics would be awesome.
    Thanks
  7. Sep 23, 2016 at 12:56 PM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    2008 with 3/1.5 Rough Country .. 20" limited wheels with 275/65/20 Cooper Zeon's and 1.25 spacers
    Jackfrost likes this.
  8. Sep 23, 2016 at 2:55 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    2012 with rough country 3/1, 275/70r18 toyo AT2's no wheel spacers.
    Noeyes, digdug and CaptTyler like this.
  9. Sep 26, 2016 at 3:06 AM
    dcon374
    Dustin
    Stock
    Thanks guys. I noticed some guys are using wheel spacers and some are not. What is the advantage of using spacers?
  10. Sep 26, 2016 at 4:33 AM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Makes the tires stick out a little more since most/all stock wheels don't provide that aesthetic look. Essentially provides the offset an after market wheel might have. I suppose having a wider stance it might help the truck to handle a little better. I've noticed a little difference but not much. I really like mine. No vibration at all. If you do get them just be sure to tighten them to the manufacture specs (mine were 85 ft lbs) and then recheck after your first drive.
  11. Sep 26, 2016 at 10:44 PM
    Asutton
    Asutton New Member
    Andrew
    2008 Tundra Limited
    With some of the stock rims you will have to use spacers because the wider tires will rub the upper A-arm. I did 1.5 because the guys on this site said that's what you had to do with my rims. I could have gotten away with 3/4" or and 1". With the spacers my truck is very loose and I'm not really sure why
