+25mm vs -25mm offset
Discussion in 'Wheels & Tires' started by Texan25, Aug 26, 2016.
  1. Sep 23, 2016 at 9:39 AM
    jay131866
    jay131866 New Member
    Thanks Im probably just going to go with the wheel I like and call it a day, I'm sick of researching rims haha. It would basically be your setup with 6mm higher offset from the 8.5" wheel, but from what I can tell it looks pretty nice on your truck. Thanks for posting the pics!
  2. Sep 23, 2016 at 9:41 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    No problem, be sure to post pics of how everything turns out. I used all the build threads and pictures on this site to make decisions and found the resources here very helpful.
  3. Sep 23, 2016 at 10:41 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    +20
  4. Sep 24, 2016 at 1:48 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I am not sure how you got 41. I am comparing the offset to 9 inch wide wheels (which is the most common size in the after-market arena). 8.5 inch width is 1/2 inch narrower than the 'standard' wheel. Half of this difference will be affecting the outer edge of the wheels (about 6 mm). So the outer edge of the 8 inch wide wheel with 25 mm offset will be at the same place with 9 inch wide wheel with 31 mm offset.
    Clear as mud, haha.
  5. Sep 26, 2016 at 5:39 PM
    jay131866
    Dumb question for everyone...the stock dodge ram wheel offset is +25. Should I expect a +25 offset wheel on my Tundra to have the same stance as the stock ram pictures, or is it totally dependent on the specific truck body design?
