Window Trim Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by PapaGrizz, Mar 17, 2019.
  1. Mar 17, 2019 at 4:32 PM
    PapaGrizz
    PapaGrizz [OP] MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
    Has anyone experienced a separation of the window trim? Any suggested fixes?
    OR18TRD likes this.
  2. Mar 17, 2019 at 4:38 PM
    derkks
    derkks New Member
    Oregon
    Just noticed this on my truck this morning.
    OR18TRD likes this.
  3. Mar 17, 2019 at 4:39 PM
    TundraDude4x4
    TundraDude4x4 New Member
    2010 Pyrite Mica V8 4x4 DC
    This is on my truck as well.
  4. Mar 17, 2019 at 4:39 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Yes, my neighbor did on his new 18. He took it back and they replaced it.
    OR18TRD likes this.
  5. Mar 17, 2019 at 4:50 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you're out of warranty, 3M weatherstrip adhesive (black) applied liberally. If you eventually have to replace the trim, the weatherstrip adhesive will be tough to clean up. I would cross that bridge when I came to it. :proposetoast:
    myt1, Black Wolf and PapaGrizz[OP] like this.
  6. Mar 17, 2019 at 4:57 PM
    PapaGrizz
    Derek
    Spokane Valley, WA
    Perfect! Thank you!
  7. Mar 17, 2019 at 5:11 PM
    JohnLakeman
    MGM Crue gotta stick together. ;)
  8. Mar 17, 2019 at 5:16 PM
    JohnLakeman
    Use some duct tape from hell to pull it flat until the adhesive cures. It's going to be tough to get it to lay down perfectly flat at the edges. Tension in the elastomeric door trim is causing it to lift and curl at the corner. I've seen it before on old Yotas.
    PapaGrizz[OP] likes this.
  9. Mar 17, 2019 at 7:51 PM
    Buse
    Buse New Member
    Chad
    Happy Valley, Oregon
    2017 Tundra SR5 QS
    Zone T5 Lift, Black Rhino Wheels, N-Fab bars, Blackout kit, Tint
    Same issue on mine. Double sided tape.
  10. Mar 18, 2019 at 6:03 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Same issue here lol
  11. Mar 18, 2019 at 6:04 AM
    War Machine
    War Machine SSEM # 5 3MW
    I ordered replacement window trims for my daughter’s Tundra and my wife’s Sequoia from @Roman . Very easy to change out.
    Roman, NewImprovedRon and Black Wolf like this.
  12. Mar 18, 2019 at 7:16 AM
    15whtrd
    15whtrd Mr. Blonde
    It looks like it’s the same weatherstripping on our front windows. DC46B831-7675-4A1F-9CF4-63EDFE672D31.jpg
  13. Mar 18, 2019 at 7:20 AM
    15whtrd
    15whtrd Mr. Blonde
    Hahaha I literally drove over to my truck just to make sure it wasn’t doing it. So far everything looks OK, both sides.
    PapaGrizz[OP] and NewImprovedRon like this.
  14. Mar 18, 2019 at 7:24 AM
    War Machine
    Don’t forget the plastic molding on top of the cab. That’s either coming out, or it’s going to.
  15. Mar 18, 2019 at 7:26 AM
    15whtrd
    15whtrd Mr. Blonde
    I have the typical gap that’s been there since day one. But it hasn’t come off yet. I do have 100 K warranty bumper-to-bumper. Hopefully it reveals itself during that time if it’s going to.
    Watt maker likes this.
  16. Mar 18, 2019 at 7:34 AM
    War Machine
    It hasn’t come loose on my 17 yet, but on my 2011 it came loose while I was cruising down the freeway. It started slapping the window and scared the hell out of me.
    NewImprovedRon likes this.
  17. Mar 18, 2019 at 7:37 AM
    15whtrd
    15whtrd Mr. Blonde
    So did you just glue it down? Or do they now make a revised version?
  18. Mar 18, 2019 at 7:39 AM
    War Machine
    I glued it back down. I don’t remember what I used. Something from an auto parts store.
    15whtrd[QUOTED] likes this.
  19. Mar 18, 2019 at 7:49 AM
    JohnLakeman
    Similar thing happened on my 86 4Runner. Funny how engineering f'ups transfer through the automotive DNA; thankfully Toyota has fewer than others.
    The rear slide window channel pulled out the upper rear corner on both sides. Became visible after 5-10 years, presumably because the rubber shrinks with heat and UV exposure. Since there was really no flat surface to cement to the body surface, it stayed that way, in between fix attempts, for the next 20 years. But...it never leaked through.
  20. Mar 18, 2019 at 7:55 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    If you're going to use weather strip adhesive (and I highly recommend that you do...3M), READ the instructions as it is a contact cement and requires a specific technique to use correctly!
    JohnLakeman[QUOTED] likes this.
  21. Mar 18, 2019 at 8:03 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    You guys are serious troll masters (goes outside to check truck, nope)
  22. Mar 18, 2019 at 8:06 AM
    JohnLakeman
    :rofl:We are not making this stuff up...would we troll a fellow Tundraphile?
  23. Mar 18, 2019 at 8:20 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I totally believe, it's just funny how often I get lured outside lol
    On a serious note, I'd probably pull it out some more, drape something over to protect the metal frame and take a heat gun so the plastic trim bends towards the truck, then 3M it down.
    OR18TRD and JohnLakeman[QUOTED] like this.
  24. Mar 18, 2019 at 9:21 AM
    Ericsopa
    Ericsopa Old man and the sea
    I have the same thing on the front of the right rear door. I'll probably use the corner of the front loader on my tractor to push on it till the glue's dry. I'd use a D4 Cat, but I don't have one of those.
  25. Mar 18, 2019 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Just roll your truck over on its side until the glue dries. Or you could throw rocks at it with pinpoint accuracy. That should do it
    Inquiringone, bvia, JoshuaA and 5 others like this.
  26. Mar 18, 2019 at 9:45 AM
    JohnLakeman
    Trolls!!! :cookiemonster::broccoli::dancingbacon::bananadance:
  27. Mar 18, 2019 at 9:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Dude I was crying when I wrote that! It made me laugh so much. Maybe it’s the hangover, but I just envisioned someone throwing rocks at the truck to fix it.
    I think this may be my next go to quote for people who post questions and never come back for a follow up. Having electrical problems? Throw rocks at it. What size tires will fit? Throw rocks at it. Knock over 40 mailboxes? Throw more rocks at it with pinpoint accuracy. That should do it.
    Sorry for getting off track everybody
  28. Mar 18, 2019 at 9:52 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m pretty sure Ron is serious though. It’s actually not a bad idea. Would probably hold much better than just duck tape while the glue dries.
  29. Mar 18, 2019 at 11:00 AM
    JohnLakeman
    :rofl:HaHaHa...Yeah, I could maybe see what you talking about up until he started talking about throwing rocks with pinpoint accuracy. Then, I knew I was being conned.
    NewImprovedRon and 15whtrd like this.
  30. Mar 18, 2019 at 11:19 AM
    15whtrd
    15whtrd Mr. Blonde
    :sorry: I had a little too much fun this weekend
