Tundra Rican Build
Discussion in '1st Gen Builds (2000-2006)' started by pacop, May 11, 2018.
  1. May 11, 2018 at 1:26 PM
    pacop
    pacop [OP] New Member
    Paco
    Puerto Rico
    2006 Tundra Limited Double Cab 4WD
    I recently bought a 2006 Tundra limited double cab 4wd. I want to be able to go offroad but have it as a daily driver. This my first truck so I’m new to the world of customization of trucks. As it sits right now it has:
    K&N air intake
    Raceline 17” wheels
    Dick Cepek Mud country 265/70R17
    Future upgrades:
    The first upgrades sre going to be suspension and tires. Right now, when I go over 45 the steering wheel wont stop shaking and the tire are loud. I’m thinking of putting A/T tires. From what I have read the BF Goodridge KO2 are good.
    The lift I have in mind is the bilstein:
    https://bilsteinlifts.com/shop/toyo...0-2-rear-lift-shocks-00-06-toyota-tundra-4wd/
    I’m debating whether to restore the healights and tint them or buy a set of blackout ones. I’m going to tint the taillights and the 3rd brake light. I also want to replace all the light with LEDs.
    I going to powder coat the bullbar matte black and replace the light with a light bar.
    I also want to add and exhaust system that is not to loud but will make some noise when you floor it.
    I am all ears on advice and ideas for any mods.
  2. May 11, 2018 at 1:28 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Jsena likes this.
  3. May 11, 2018 at 2:16 PM
    pacop
    Paco
    Puerto Rico
    Thanks. I have been looking at those build threads for a coupleof days now. There are awesome some builds. Im also debating to level the truck or do a whole lift with bigger tires. I don’t know how much that would affect my mpg.
    Jsena likes this.
  4. May 11, 2018 at 2:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Welcome bro.. make it happen :thumbsup::thumbsup:
  5. May 11, 2018 at 2:48 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Flowmaster 40 series muffler. Single in/out. I have it. It's great. Doesn't drone terribly cruising, loud enough to let you know it's there, but in no way obnoxious.
  6. May 13, 2018 at 4:26 AM
    pacop
    Paco
    Puerto Rico
    Is that a full kit or just the muffler? How will it affect performance?
  7. May 13, 2018 at 9:05 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    Just a muffler. Couldn't really tell a difference in performance except it sounds a lot better. I kept all stock piping. Looks factory, sounds nice.
  8. May 14, 2018 at 7:06 AM
    pacop
    Paco
    Puerto Rico
    I have been looking at the Banks Monster exhaust system. I like the price of it. Does anyone have one on their truck?
  9. May 14, 2018 at 6:18 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Nice wheels. The look good on your truck. I have the same 17inch raptor wheels on my 03.
  10. Jun 15, 2018 at 2:21 PM
    pacop
    Paco
    Puerto Rico
    Update:
    So far I bought new headlights and swapped every light for LEDs. I just need to order a resistor for the headlights since the fog lights don’t work now. Read a couple of threads And I think that should fix the problem.I also change the tints since the old ones didn’t look good.
    Recently I order a bilstein suspension to lift the truck. I want to know if I will have any problems running KO2 285/70r17 with just the 2” lift?
  11. Jun 15, 2018 at 2:25 PM
    pacop
    Paco
    Puerto Rico
    EC2E7DBF-37AD-4EEE-A60F-B4DC99F80FC1.jpg 2E186BC6-5066-484A-9112-4A59D11E348E.jpg
    Y0TA PR0 likes this.
  12. Jun 15, 2018 at 3:07 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Está bien bonito tu tundra! :thumbsup:
    Y azul el mejor color! :thumbsup:
  13. Jun 15, 2018 at 3:19 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  14. Mar 11, 2019 at 7:04 PM
    pacop
    Paco
    Puerto Rico
    It has been a while since I have posted any updates. So this the truck as it sits right now.
    Mods so far:
    -Front Suspension: Bilstein 6112 at the highest point.
    -Rear Suspension: Bilstein 5100 with 2" Blocks
    -Bakflip tonneau cover
    -Tire: KO2 285/70/17
    -Pionner MVH 1400-NEX with Crux Interfacing Solutions Module
    -Back Up Camera
    -Raptor Lined the bed
    I had to remove the mud flaps since I was rubbing on the passenger side when turning the wheel.
    Before replacing the radio I had to fix the dash panel. It had some parts broken off where the radio sit. I used some JB weld for plastics and filled the parts that were missing and then sanded it. I still need to paint all the wooden trim black. IMG_4378.jpg IMG_4376.jpg IMG_4375.jpg IMG_4381.jpg
    For the reverse camera I wanted to install it in the tailgate handle but the wasn't a surface were the camera would have a view of the rear bumper. So I decided to make a small flat surface on the handle with some lexan and the same JB weld. Then a few coats of black paint and it almost look OEM haha.
    The bed was in great shape after removing the plastic cover. I had to remove the bed since the truck didn't fit in the garage and the weather here in Puerto Rico changes very quick and it could not get wet for a couple of days.
    It doesn't look great on the picture but I came out great. Very easy to use product, worst part is the prep.
  15. Mar 11, 2019 at 7:22 PM
    pacop
    Paco
    Puerto Rico
    I still have a few projects that I want to do.
    -Light Bar in the bumper.
    I am looking at the Element LED light bars. Anyone have any experience with them?
    I also want to add some rock sliders but I have gone to couple of places here in Puerto Rico and the quotes are insane. One guy quote me $2400 for the pair. I looking at freight companies to try to get the Brute Force Fab sliders shipped to me but it looks like I'm not going to have sliders on my rig. I also wanted to get the Brute Force bumpers but same deal shipping it too expensive.
    Right now I have to replace the Cam bolts since they are seized and it can't be aligned. I ordered the Moog cam bolts that have grease fittings and some new LCA OEM bushings.
    lsaami likes this.
