A little help please
Discussion in '1st Gen Tundras (2000-2006)' started by tundra6175, Mar 9, 2019.
  1. Mar 9, 2019 at 6:29 PM
    tundra6175
    tundra6175 [OP] New Member
    james
    2002 tndra SR5
    MOSTLY STOCK
    hello everyone. I have a 2002 tundra sr5 and i am having an issue with the brakes. I have replaced the master cylinder, booster, calipers, and wheel cylinders. I have bled the system completely but the brake peddle feels weird . The brakes work but when i step on the brake peddle it kinda goes down too far and does not feel normal . it almost feels like there is a leak but there is not. With the engine off the brake pedal feels nice and firm but when it is running the pedal slowly goes almost to the floor with a hiss. any ideas ? thanks.
  2. Mar 9, 2019 at 6:34 PM
    maxcala
    maxcala New Member
    Max
    L.A.
    2014 Limited Crewmax
    Could be air still present.
    because_wumbo-truck likes this.
  3. Mar 9, 2019 at 7:11 PM
    Aerindel
    Aerindel New Member
    Montana
    Sounds like its not fully bled. There is another post here about someone with a similar problem.
    because_wumbo-truck and 15whtrd like this.
  4. Mar 9, 2019 at 8:46 PM
    Sunnier
    Sunny
    San Diego, CA
  5. Mar 9, 2019 at 10:03 PM
    15whtrd
    15whtrd Mr. Blonde
  6. Mar 9, 2019 at 10:09 PM
    Aerindel
    Aerindel New Member
    Montana
  7. Mar 10, 2019 at 7:57 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Did you bleed the brake proportion valve in the rear?
    Also, one thing I've never tried is bleeding the actual master cylinder. There is a bleeder on it but I've never seen mention of using it. Since you've opened the whole system up that may be worth a try, it's a high point where I could imagine air getting trapped.
    15whtrd and Casper421 like this.
  8. Mar 10, 2019 at 8:20 AM
    Casper421
    In the woods
    06 DC
    All of this.
    15whtrd likes this.
  9. Mar 10, 2019 at 8:24 AM
    bmf4069 Captain wtf
    My fix in that other thread was actually having the rear brakes adjusted. I had the adjuster in all the way so the rears weren't catching.
    15whtrd, Darkness and Casper421 like this.
  10. Mar 10, 2019 at 8:57 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Unless the master cylinder fluid level had gotten too low there wouldn't be any air in it. Brake systems are different in that the air won't migrate to the highest point it has to be forced out through a bleeder.
    OP did you bench bleed the master before installing it? That would be a concern because the will hold a lot of air if you don't.
    15whtrd likes this.
  11. Mar 10, 2019 at 9:10 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He replaced everything, that's why I would consider bleeding the master.
    Aerindel and 15whtrd like this.
