  1. Mar 9, 2019 at 4:09 PM
    #4891
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Update on the truck. Left rear axle shaft is bent, now to hunt a used one (new is too much money.) she’ll be parked till I find one now
    So left inner tie rod and a left read axle shaft...
    Then Ball joints and probably control arms just because mileage And accident.
    Filthyphil, Sunnier and Darkness like this.
  2. Mar 10, 2019 at 7:32 AM
    #4892
    Damn, how do you bend an axle? Those things are thick.
  3. Mar 10, 2019 at 8:31 AM
    #4893
    Casper421
    In the woods
    06 DC
    A bent axle was part of the “rollover special” package. Special order.
  4. Mar 10, 2019 at 8:40 AM
    #4894
    Ahhhhhh, I see. Yup, that'll do it.
  5. Mar 10, 2019 at 8:50 AM
    #4895
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Idiot light "check engine" came on today. Oil pressure is good, charge is good, temp is good.
    Any guesses?
    I'm thinking some oxygen sensor.
  6. Mar 10, 2019 at 8:52 AM
    #4896
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Could be a million things, most likely O2 sensor tho... go get it read
  7. Mar 10, 2019 at 8:58 AM
    #4897
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A bluetooth OBD reader is worth the money for just this occasion.
    the red and lc69hunter like this.
  8. Mar 10, 2019 at 10:25 AM
    #4898
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Got rid of the ugly method center caps, they stick out way to much.
  9. Mar 10, 2019 at 10:25 AM
    #4899
    empty_lord
    05 rollover special
    well i mean it may not be bent bent. but im not pressing on a wheel bearing to find out its bent and i just wasted money on a bearing. ran the truck up on the lift because of noise and i saw the wheel moving. took the wheel off and the drums moving. no play i can feel so im pretty sure its a bent shaft. i had to replace one before on a FJ cruiser because it hit a curb pretty hard. mine ended up on 3 flat tires and a damaged wheel. so good chance its bent... ever so slightly but its likely bent.
  10. Mar 10, 2019 at 11:01 AM
    #4900
    I will say this, after I changed my axle seal and diff juice, I put the axles back it and turned the truck on and let it run in drive for awhile to check if I did the seals right. The hubs dont run straight on either side. I think it's normal with no load on them as there's a little wiggle room in the diff.
  11. Mar 10, 2019 at 11:25 AM
    #4901
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    It's likely a sensor. Check the code.
  12. Mar 10, 2019 at 11:47 AM
    #4902
    empty_lord
    05 rollover special
    [​IMG] In other news. All the engine maintenance is going to happen now
  13. Mar 10, 2019 at 1:28 PM
    #4903
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    It's working.. I could have swore I tried that code and it didn't work . thanks man..
  14. Mar 10, 2019 at 2:46 PM
    #4904
    Casper421
    In the woods
    06 DC
    Stretched her legs out a little.
  15. Mar 10, 2019 at 3:05 PM
    #4905
    because_wumbo-truck
    Jon
    Houston, Texas
    Damn that's the same one I had in there already from my 03 taco. I guess the 5 speed is different. The search continues.
  16. Mar 10, 2019 at 3:23 PM
    #4906
    empty_lord
    05 rollover special
    The 5 speed I believe is a learning trans. Totally different from the a340 of old.
  17. Mar 10, 2019 at 4:25 PM
    #4907
    Went out to tighten down the VC bolts and did this. I told yall I can fuck some shit up. But at least he got a bath today!
  18. Mar 10, 2019 at 4:46 PM
    #4908
    the red
    the red the threat is real
    New Brunswick, Canada
    Agreed. I plan on picking up a BlueDriver soon. Very highly rated and sounds like $100 well spent to me.
    Edit: Make that: I just ordered a BlueDriver myself. haha
    NUDRAT and Festerw[QUOTED] like this.
  19. Mar 10, 2019 at 5:55 PM
    #4909
    because_wumbo-truck
    Jon
    Houston, Texas
    yeah I've tried every xgauge I can find and can't find one that works.
  20. Mar 10, 2019 at 8:32 PM
    #4910
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Took me awhile to learn it is cheaper for me to pay the pros. I do that sort of thing all the time.
    When I finally get it all fixed I'm so P.O.'d there is just no satisfaction from the job.
    At least I don't throw tools any more.:anonymous:
    Casper421 likes this.
  21. Mar 10, 2019 at 9:06 PM
    #4911
    empty_lord
    05 rollover special
    As a mechanic. I can tell you I throw tools almost daily over usually being annoyed by poor design choices or a service writer what pisses me off.
    Lol
    Darkness, NUDRAT[QUOTED] and Sunnier like this.
  22. Mar 10, 2019 at 11:26 PM
    #4912
    carpartcountry
    carpartcountry New Member
    2005 Toyota Tundra TRD
    3 inch life, tinted windows,
    Got my Tundra washed and ready to go. I’ve been thinking about putting on a bush guard, bug guard and window wind shields. Do you guys have any suggestions? This is my first post and I’m enjoying looking at all the awesome Tundras!
    pm07, Darkness, Brown Bear and 2 others like this.
  23. Mar 10, 2019 at 11:35 PM
    #4913
    Eh, it is what it is. I was being dumb with a torque wrench and got what I deserved. I'll fix it and move on the the next item on the list.
    Darkness and NUDRAT[QUOTED] like this.
  24. Mar 11, 2019 at 1:04 AM
    #4914
    empty_lord
    05 rollover special
    Left handed drill bill will probably bring it right out
    bmf4069[QUOTED] likes this.
  25. Mar 11, 2019 at 4:45 AM
    #4915
    because_wumbo-truck
    Jon
    Houston, Texas
    Great looking truck welcome to the site!
    Where you from Jason?
  26. Mar 11, 2019 at 5:28 AM
    #4916
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Welcome. nice rig.
    As for window vents, I'm going to love them in the spring & summer, but I've found them noisier than expected. Perhaps a slim fit brand would be quieter?
  27. Mar 11, 2019 at 5:52 AM
    #4917
    Mike Tread lightly.
    south carolina
    You might want to remove that butt connection and replace it with a solider and heat tubing.. heat gets to that butt connection..
    As for the bolt remove valve cover and use a easy out or left hand drill bit.
    Darkness, NUDRAT and bmf4069[QUOTED] like this.
  28. Mar 11, 2019 at 7:12 AM
    #4918
    Greased the U Joints one more time yesterday to see if I can get by for a while before replacing them. Also got some mud on the tires. Felt an instant boost in testosterone.
  29. Mar 11, 2019 at 1:24 PM
    #4919
    @Casper421 you guys have me considering the Icon's now.
    This may be a stupid question but are the coilovers not sold as a pair? Everywhere I check, it says (1), even Icon's website.
  30. Mar 11, 2019 at 1:31 PM
    #4920
    Casper421
    In the woods
    06 DC
    They’re sold in pairs. Quantity 1 pair.
