Discussion in 'New Member Introductions' started by Cbetancourt76, Mar 8, 2019.
  1. Mar 8, 2019 at 4:21 PM
    Cbetancourt76
    Cbetancourt76 [OP] New Member
    Carlos
    2011 Tundra 4x4
    does anyboday know the cause of this? One day I turned on truck and drive out of gas station then I felt the traction control kick on and made my truck drive slow so I turned off then same happened again. After that truck started and turned off took two more tries then I started driving and all those lights came. 4 wheel won’t engage unless I turn truck on first then put into 4hi/lo. Also when I’m first driving before the 4hi/lo lights come on the speedometer doesn’t register correct speed. Only after lights for 4 hi/lo start flashing on and off. I have 2011 4.6 Texas Editon. Please help
    OR18TRD likes this.
  2. Mar 8, 2019 at 6:51 PM
    Is it possible a wheel speed sensor froze?
    TXRailRoadBandit73 likes this.
  3. Mar 8, 2019 at 6:56 PM
    Cbetancourt76
    Carlos
    2011 Tundra 4x4
    U know what I just got code for rear driver wheel speed sensor error
  4. Mar 8, 2019 at 7:59 PM
    BoTheTundra
    BoTheTundra New Member
    Thomas
    2007 tundra TRD sr5
    Lift with rims and tires, exhaust mirrors skid plate, whole interior sound system and head unit
    bad design on toyotas part, only way is to insulte your wheel speed sensor for winter, anything below 5 degreeish will set it off until the truck warms up. i just wait till my truck is at operating temp and shut it off then turn it back on, all lights go away and im good to go.
