TracRac SR or G2 Anyone?
Discussion in 'Tonneau Covers, Caps and Shells' started by Mater, Mar 1, 2019.
  1. Mar 1, 2019 at 9:16 PM
    Mater
    Mater [OP] New Member
    SD
    2016 MGM Platinum
    I've searched the forum high and low and could not find a member with a TracRac SR or G2 (sliding rail) setup. Does anybody have this setup?
    Found a cheap set of rails that fit an F150 and thinking about grabbing them to see if I can retrofit them to work with a crewmax. If that works out then the hope is to grab a TracOne setup and swap the sliders on the bottom with SR/G2 sliders.
    If I make it that far and the rack setup work outs then the plan would be to add a GatorTrax or Retrax with it.
    Final step would be to add the UWS under tonneau tool box.
    So, it'd look like this but not be an F150. If this is a crazy thought I'd appreciate it if someone would let me know sooner than later.
  2. Mar 1, 2019 at 9:37 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    CG4X4, Jbva757 and 1UPPER like this.
  3. Mar 1, 2019 at 10:32 PM
    Mater
    SD
    2016 MGM Platinum
    What website did you purchase your SR from? Is there a rail sku # for crewmax? It seems whenever I punch in 2016 tundra it defaults to a 6.5’ bed for some reason. Thanks in advance for the help
  4. Mar 2, 2019 at 6:16 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I purchased from Mory @ Tonneau Factory. He was great to deal with and gave me an awesome deal on both the TracRac SR and the X2 as a package.
    This is what I got and it fits perfectly.
    And in case you're wondering, it doesn't come black, I had the whole rack powder coated matte black before I assembled it. It looks so much better. Cost to powder was ~$400
  5. Mar 2, 2019 at 12:01 PM
    Mater
    SD
    2016 MGM Platinum
    Dang that looks sweet! Appreciate the info
    Toyotoholic likes this.
  6. Mar 8, 2019 at 5:30 AM
    Jbva757
    Jbva757 New Member
    2016 Midnight Black Tundra Limited
    What was the number for the two together? Because This is the exact same setup I want on my truck but maybe with the X4 depending on the deal.
    Toyotoholic[QUOTED] likes this.
