  1. Mar 7, 2019 at 11:01 PM
    #4861
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    No. Plug and play. You just have to trim the top tab of the bulb
    Same wattage. They’re HIR bulbs. They have a special coating to keep the heat inside the bulb in turn making them burn way brighter
  2. Mar 8, 2019 at 1:46 AM
    #4862
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Got a link?
  3. Mar 8, 2019 at 4:12 AM
    #4863
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    If you get it to work let me know codes you used I have tried 4 and no luck it comes up blank. Only thing I didn't do was remove pin 7 I believe in the port.
    2005 Toyota changed the protocol so you could get it but 2004 down was none.
  4. Mar 8, 2019 at 4:25 AM
    #4864
    because_wumbo-truck
    Jon
    Houston, Texas
    Yours a v6 or v8?
  5. Mar 8, 2019 at 5:10 AM
    #4865
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    First off, take your time in deciding. Don’t rush anything.
    I have no problems with Toytec. I had a buddy on his 3rd gen run their “coilovers” for a while and didn’t pretty well. But like what was said before, but once, cry once... if you ever plan on upgrading “eventually” just wait a few more months and save some extra cash and upgrade now. It’ll save time and $$$.
    I would not do a 700# with no extra weight up front. Unless you plan on going with a heavy bumper / winch / skids etc...
    My bumper is on the lighter side 70#s or so plus a winch / skids / sliders and I’m still running 650# springs. I’m very pleased with my ride right now. Springs on the Coilovers are there to hold up the weight of the front end of the truck. There is a happy spot to be found. Too heavy and you’ll never use your shock to actually do it’s job, too little of a spring and you’ll be like jello jiggling all over lol
    I ran an add a leaf (from Icon) for over a year. It did great. It gave me about 1-1.5” of lift. With icon shocks gave me some more travel in the rear. I have now upgraded to a Deaver Leaf pack...
    My best advice is just take your time in deciding.
    PM me if you have any other questions. I’m happy to help
  6. Mar 8, 2019 at 5:35 AM
    #4866
    Mike Tread lightly.
    south carolina
    2uzfe.
  7. Mar 8, 2019 at 5:56 AM
    #4867
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine works
  8. Mar 8, 2019 at 6:02 AM
    #4868
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Hellwig has made some real product improvements since 2003, this is my Hellwig on a 2002 4WD.
    NUDRAT likes this.
  9. Mar 8, 2019 at 6:07 AM
    #4869
    Rex Kramer
    Georgia
    I ran a couple service calls, checked the oil and filled up the tank.
  10. Mar 8, 2019 at 6:17 AM
    #4870
    because_wumbo-truck
    Jon
    Houston, Texas
    Word. So I should be able to do mine today. Do you recall any details about which setting I need to be on?
  11. Mar 8, 2019 at 6:43 AM
    #4871
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My truck is 03, I set the code up maybe 9 years ago but I'll see if I can find it.
    because_wumbo-truck likes this.
  12. Mar 8, 2019 at 7:22 AM
    #4872
    @Professional Hand Model and @sakana does it just bolt in place? No drilling required?
  13. Mar 8, 2019 at 7:38 AM
    #4873
    empty_lord
    05 rollover special
  14. Mar 8, 2019 at 7:46 AM
    #4874
    because_wumbo-truck
    Jon
    Houston, Texas
  15. Mar 8, 2019 at 8:03 AM
    #4875
    Mike Tread lightly.
    south carolina
    :thumbsup:
  16. Mar 8, 2019 at 4:48 PM
    #4876
    RE_P
    RE_P New Member
    Prince Edward Island
    2004 4.7 Tundra SR5 DC
    Do you know the location of the transfer case breather hose?
  17. Mar 8, 2019 at 6:08 PM
    #4877
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Mike these should work.
    @because_v8 I don't think these work on the 5 speed trans.
    For us Farenheit loving Muricans
    TXD: 686AF101B4
    RXF: 044105B40000
    RXD: 2808
    MTH: 00090005FFD8
    For our Canadian buddies who like Celsius
    TXD – 686AF101B4
    RXF – 044105B40000
    RXD – 2808
    MTH – 000100010000
  18. Mar 8, 2019 at 7:10 PM
    #4878
    empty_lord
    05 rollover special
    Found the build sheet for my truck up in the headliner tonight.
    Also, have to custom fab mounts for sequoia visors... i'll make it happen. just gotta figure out how
  19. Mar 8, 2019 at 9:12 PM
    #4879
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    I didn't do the install myself, but yes - it bolts on. No drilling required.
    These links mount to the frame through an existing hole.
  20. Mar 9, 2019 at 5:44 AM
    #4880
    Mike Tread lightly.
    south carolina
    I will be home tomorrow I will give it a shot... Thanks man I will report back..
  21. Mar 9, 2019 at 6:01 AM
    #4881
    Let me know what you find out. If the Scanguage won't tell me my transmission temp I'll get something else.
  22. Mar 9, 2019 at 6:36 AM
    #4882
    the red
    the red the threat is real
    New Brunswick, Canada
    Gave one a test drive last night. An '03 V8 AC. The frame wasn't bad considering my location, and the body was pretty good. Having worked late, and it being dark when I looked at it, I wasn't catching everything. I didn't realize it was RWD until I thought to myself that I should see how the 4WD works on it... :facepalm:
    So, I won't be putting money down for this one. It did feel pretty tight overall, but had a vibration that really started getting pronounced above 90 kph (55 mph). My first thought was lower balls joints. Also, while the steering felt pretty tight, it did seem soft to me. Do these trucks have a healthy amount of power assist that makes it feel this way?
  23. Mar 9, 2019 at 6:54 AM
    #4883
    Mike Tread lightly.
    south carolina
    I read somewhere about the protocol 04 and below as crap for stuff like this .. I need to pull out my snap on verus d10 on the truck see if I can get into transmission that way.
  24. Mar 9, 2019 at 8:04 AM
    #4884
    Fred
    Hand Protectors
    I’ve been trusting the warning light to tell me if there is a problem all these years. The light works, but not sure if the sensor does because its never activated during towing/hauling heavy loads.
    I checked the manual to see what temp would activate if there was a problem, but to no avail.
  25. Mar 9, 2019 at 8:10 AM
    #4885
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Typically (not sure in a Toyotas case) but typically the light won't come on until it's severely overheated like 220+. Ideally you want to stay under 200 while towing.
    Personally I don't tow long or heavy enough to really worry about it and do a drain and fill every summer.
    NUDRAT likes this.
  26. Mar 9, 2019 at 8:22 AM
    #4886
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah, most of those idiot lights don't come on until you're already in trouble.
    because_wumbo-truck and Mike like this.
  27. Mar 9, 2019 at 8:28 AM
    #4887
    Mike Tread lightly.
    south carolina
    Or the damage is already done..
    Why they call them idiot lights:rofl:for idiots.
  28. Mar 9, 2019 at 9:14 AM
    #4888
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah lol in my GTI the temp light went off after my coolant dumped out on the highway. I can laugh now but at the time it wasn't funny.
    :annoyed:
    NUDRAT, Sunnier and Mike[QUOTED] like this.
  29. Mar 9, 2019 at 10:31 AM
    #4889
    Sunnier
    Sunny
    San Diego, CA
    Yeah, don't buy this one. Not only because you want 4x4 but no, there's nothing "normal" about any vibration. Unless it's a bitchin' deal and you KNOW the cause and can fix it on the cheap.
    the red[QUOTED] likes this.
  30. Mar 9, 2019 at 11:20 AM
    #4890
    Outbound
    Aaron
    Northern Alberta
    I went to truck accessory shops today, Canopy West and Cap-It, to price out caps for my truck. An ARE CX outfitted how I want will run me $3200 + tax and install. A Leer 100R similarly outfitted would be about $3400 + tax and install.
    The Cap-It guy then presented another option. A Truxedo tonneau cover paired with a Thule TracRac SR. He just needs to call Thule on Monday to confirm part numbers and that we can make this set up with my truck. This set up would do 90% of what I need and save me around $1000, which I'll then put into more truck parts. :D
    the red and Darkness like this.
