Brakes
Discussion in '1st Gen Tundras (2000-2006)' started by 715GoBlue, Mar 5, 2019.
  1. Mar 5, 2019 at 9:46 PM
    715GoBlue
    715GoBlue [OP] New Member
    2006 v6 Tundra
    Brakes are touchy? Only way i can describe is, grabby, sensitive. I touch brakes and truck suddenly stops. The wheels dont lock brakes just feel off? Any ideas?
  2. Mar 6, 2019 at 12:31 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    My brakes are grabby and sensitive when I first pull out of the garage, but I think it's due to the truck not getting driven frequently enough. Brake rotors are cast iron, and rust easily. Left in a humid environment, you'll get a rust film on your rotors. Until friction burns that off, your brakes may be sensitive.
    Clarify: They do stop grabbing when you let off the brake pedal, right?
  3. Mar 6, 2019 at 12:35 PM
    715GoBlue
    2006 v6 Tundra
    Thanks for reply, yes they stop grabbing when I let off the brake. My brother read might be a problem with brake line, collapsed rubber line?
  4. Mar 6, 2019 at 12:43 PM
    JohnLakeman
    That's not the problem on my truck, since it's not even two years old yet.
    I owned a First Gen 4Runner for 31 years and never replaced the rubber brake hoses, ever. Of course, that was a Japan manufactured truck where these were born in the USA. Toyota's manufacturing QC standards seem to be nearly as stringent today as they were 30 years ago.
    715GoBlue[OP] likes this.
  5. Mar 6, 2019 at 12:48 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    If your brakes are grabbing when you press on it, there is no problem. You can adjust the bias thats above the rear axle. Lowering goes more front. Raising goes to rear.
    Or move the seat back.
  6. Mar 7, 2019 at 6:28 PM
    715GoBlue
    2006 v6 Tundra
    Thanks
  7. Mar 7, 2019 at 6:36 PM
    trdprobped17
    trdprobped17 New Member
    The 1st and 2nd generation Tundras has been known for those types of brake issues. Here is something about the 2nd gen Tundra that might be of interest to you.
    https://tundraheadquarters.com/2007-12-toyota-tundra-front-brake-vibration-tsb/
    Owners of Toyota Tundra trucks might have heard about the front brake vibration problem. It was originally a problem with first generation Tundras and mismatched brake calipers. Newer truck owners for years have assumed the issue didn’t apply to them. However, if you have a Tundra manufactured between 2007 and 2012, a new Toyota Service Bulletin, TSB 0131-12, has been released regarding front brake vibration possibly occurring at high speeds.
  8. Mar 7, 2019 at 7:07 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's nice but
    bmf4069 and 715GoBlue[OP] like this.
  9. Mar 7, 2019 at 7:58 PM
    trdprobped17
    https://www.consumerreports.org/cars/toyota/tundra/2006/reliability
    SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
    Mar 29 2007
    LOSS OF BRAKE FLUID CAN RESULT IN POOR BRAKING PERFORMANCE, POSSIBLY RESULTING IN A VEHICLE CRASH.
    Summary:
    CERTAIN CARDONE MASTER CYLINDERS WITH PART NUMBERS 10-2925, 10-2987, 10-2987MZA, 10-3083, 11-3015, 11-3042, 11-3044, 11-3045, 11-3047, 11-3064, AND 11-3156, AND WITH DATE CODES LOWER THAN DCA7078 SOLD AS REPLACEMENT EQUIPMENT FOR USE ON THE VEHICLES LISTED ABOVE. THE SEAL ON MASTER CYLINDER CAN FAIL AND LEAK BRAKE FLUID.
    What should you do:
    CARDONE WILL NOTIFY OWNERS AND OFFER TO REPURCHASE ANY DEFECTIVE MASTER CYLINDERS. THE RECALL BEGAN DURING APRIL 2007. OWNERS CAN CONTACT CARDONE AT 1-800-777-4780.
    For more information:
    THIS RECALL ONLY PERTAINS TO AFTERMARKET CARDONE MASTER CYLINDERS AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON THE VEHICLES LISTED ABOVE.CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
    NHTSA CAMPAIGN ID Number: 07E023000
    Potential Number of Units Affected: 13128
    Hide Recall Details
  10. Mar 7, 2019 at 8:04 PM
    trdprobped17
  11. Mar 8, 2019 at 4:51 AM
    bmf4069 Captain wtf
    I got 99 problems but a 2nd gen ain't one. :D
    Darkness likes this.
