***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Mar 4, 2019 at 10:24 AM
    #601
    jack_yaj
    jack_yaj New Member
    Jack
    2019 Midnight Black Limited DC TRD Off-Road
    For that price that sh!t better be good hahaha. I was aiming at the HD 900/5 but I have the non-JBL system and needed a DSP. As the price added up it was the same as the VXi800/8. I got a really good deal on the JL Audio stealthbox. Thought about the VXi1000/1 but the stealthbox is wired to 4ohms :sadviolin:and it made more sense getting the HD750/1. The plan is to bridge the full range L3SE, front mid bass at 2ohms and rear mid bass at 4ohms.
  2. Mar 4, 2019 at 2:39 PM
    #602
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Does the vxi have an amp pass thru?
  3. Mar 4, 2019 at 3:14 PM
    #603
    jack_yaj
    jack_yaj New Member
    Jack
    It does.
  4. Mar 4, 2019 at 3:31 PM
    #604
    Adam New Member
    I did the noico deadening inside each door two strips of 6”x 27(or whatever the overall length is). On bottom I oriented toward speaker side, on top toward handle side..... Then I did two pieces to cover what the oem plastic sheet did. Put a few small strips on door panel and window switch panel. I also did a .25” strip under the wood from the 12v speaker pack. I almost used a 36 sq ft pack for that. Have a second pack to do floor and back wall when I get amp in. So far I can tell a difference just with doors.
    JoshuaA, Pudge[OP] and Major like this.
  5. Mar 4, 2019 at 5:08 PM
    #605
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    I used Noico on the door and parts of the plastic panel, in the snow, while it was snowing. Exponential difference, no rattle and cleaner sound and I was only able to get the front doors done, will do the rears this weekend and take pics.
    Pretty much what he said...
    JoshuaA and Pudge[OP] like this.
  6. Mar 4, 2019 at 8:06 PM
    #606
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I put some(10sq ft) on the door panels when I replced my speakers last week. I already had it on the inner and outer metal door skins. Ideally you'll do both the metal of the door and some on the plastic panel itself. It's designed for the metal door skins, inside and out to make the doors more solid and keep the sound inside the cab, so if you do only one surface I'd do the door itself. Once you get the door panels off you'll realize it's really easy and won't mind pulling them again later and do more work in them when it warms up. You could possibly use a cheaper self stick foam material on the door panels to reduce the plastic rattles and vibrations but the noico isnt cheap so I'd use it on the metal. The doors sound and feel so much more solid as a result
  7. Mar 5, 2019 at 1:27 PM
    #607
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Thanks for the clarification. In your previous posts I didn't realize you had the metal covered already.
    Pudge[QUOTED][OP] likes this.
  8. Mar 5, 2019 at 1:31 PM
    #608
    Pudge
    CT
    I did a lot of sound deadening over the summer. Trust me once you get the door panels off you'll see it's not so bad, maybe 3 minutes per door to remove and reinstall.
  9. Mar 5, 2019 at 7:47 PM
    #609
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I moved my front tweeters on the speaker mount kick panel side. Figured the dash mids and highs were enough. E31BDCAA-7178-4A5A-AA2A-BBF3B96FE3C8.jpg
  10. Mar 5, 2019 at 7:50 PM
    #610
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Instead of drilling in your sails? I take it you don't have tweeters in your sail already.
  11. Mar 5, 2019 at 7:53 PM
    #611
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Yes. SR5 non jbl. If you have the tweeters in the sail panels, you can leave them in and add the new tweeters to the system. There is no need to remove them from the system. Most of the distortion comes from the factory 6x9
  12. Mar 5, 2019 at 8:00 PM
    #612
    Pudge
    CT
    That's a good idea
    D3Tundra likes this.
  13. Mar 6, 2019 at 7:06 PM
    #613
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Does anyone know when the last batch of Speakers will ship out? I already got the sound matting that I ordered from James, but no speakers yet.
  14. Mar 6, 2019 at 7:14 PM
    #614
    Mine will be here tomorrow. Ordered about two weeks ago
  15. Mar 6, 2019 at 7:30 PM
    #615
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    I ordered them on the 27th and haven’t received a shipping notice either. It has been looking like 1-2 weeks for shipment on them.
  16. Mar 6, 2019 at 7:34 PM
    #616
    TXTundra2722
    2015 Black Tundra
    Be patient young padawan .... the man is very busy on this group buy and I can assure you that he will take care of you. I've ordered the sub, amp and wiring from him. The sub came busted, (not his fault, but UPS) and he quickly handled the situation and had a replacement on the way that very next day. I paid nothing extra and he ate the shipping charge. I didn't have enough for the door speakers, but he'll definitely get my money still at the full price once I've recovered some funds.
    Migraine, jack_yaj and T-Rex266 like this.
  17. Mar 6, 2019 at 7:36 PM
    #617
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I received my orders yesterday, 2 weeks to the day from when I ordered, everything looks mint
  18. Mar 6, 2019 at 7:37 PM
    #618
    InfernoPRO
    Scott
    Sacramento
    I know he is busy, and I didn’t mean to sound impatient. I was just letting the previous poster know that he hasn’t been forgotten about and that it will take a few weeks to receive.
    Migraine likes this.
  19. Mar 6, 2019 at 7:46 PM
    #619
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Emailed James and he said shipping out tmr. Order last week on the 28th.
    InfernoPRO likes this.
  20. Mar 7, 2019 at 11:47 AM
    #620
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    Also ordered on the 28th and just got my shipping notification! :bananadance:
  21. Mar 7, 2019 at 1:23 PM
    #621
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    if anyone has not gotten their tracking yet its because Infinity did not have any 3.5s in stock and did not bother telling me they were out of them. I have a shipping girl that handles nothing but shipping orders and she is on top of all of it . They show tracking that they will be delivered to us on tuesday .At any time if you need an update you can email me tech12volt@gmail.com and you will get a response back from me. If you send a PM sometimes I do not get a notification that I have one in my box. sorry for any delay. The group buy pricing is still on our site as I have not had time to take it down yet. So if you still want in on that pricing get yours ordered asap . The amp is still on group buy also
  22. Mar 7, 2019 at 2:29 PM
    #622
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    As always, thanks for the heads up on things like this.
  23. Mar 9, 2019 at 11:05 AM
    #623
    Helppppp
    Tweeter wires go on howwww
  24. Mar 9, 2019 at 11:15 AM
    #624
    Can I just do this?
  25. Mar 9, 2019 at 11:17 AM
    #625
    Yes. It sounds weak, like faint but it’s there. That normal for front tweeters or?
  26. Mar 9, 2019 at 11:21 AM
    #626
    Thanks. I’m texting Pudge and emailing James atm
  27. Mar 9, 2019 at 11:29 AM
    #627
    Puba
    Puba Not New Anymore
    Blue Bell, PA
    MGM 2019 Crewmax LTD OffRoad
    RCI skid plates Curtis front hitch TracRac Ladder racks Truxedo Tonneau Cover BedRug bed liner Console Vault Tech 12volts complete audio system upgrade Bilstein 6112/5100 Coachbuilder Shackles Fuel Vector 18x9 Falkan Wildpeak 295/70/18 DirtyDeeds 8" Standard Husky XAct floor liners Color matched Bumper Shellz fronts Pop and Lock Tailgate SDHQ Hidden Winch Mount Smittybilt X20 Comp 12K RCI Rock Sliders Harrop SC - Stage 1
    Go to Tylers post - #335. Click on his build link and go to second page, scroll down for pics. I wired my tweeters by splicing into the Metra Harness that should have come with your shipment from James. The front doors are straight forward, the rear doors aren't as simple. I broke off the pc from the old tweeter like Tyler did for the rear doors. I think you have a 2019 with JBL, yes?
    My front door tweeters had really no sound at all until I installed the amp and wired all that in with the DSR1. Not sure what you ordered, I got everything but a new HU.
  28. Mar 9, 2019 at 11:53 AM
    #628
    I got one front done. Thanks to @Pudge and also the recommendation for sound material. No rattle on the front driver side!
  29. Mar 9, 2019 at 12:49 PM
    #629
    bard0117
    bard0117 New Member
    It’s funny that the back tweeters sounds almost perfect. Sitting in the backseat feels amazing! If the whole truck sounded like that, I wouldn’t of ordered the amp.
  30. Mar 9, 2019 at 2:03 PM
    #630
    Off topic, but related too.
    Soon :spending:
    tja1080, bard0117, BlueBottle and 3 others like this.
Thread Status:
