Paint Matched Grill Surround
Discussion in 'General Tundra Discussion' started by DCB500, Mar 5, 2019.
  1. Mar 5, 2019 at 9:06 PM
    DCB500
    DCB500 [OP] New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Hello All,
    I am looking to get a new grill surround and hood bulge that way s painted to match the body (magnetic gray) but my truck has the TSS and I like the grill center that’s in the truck already but it’s too much chrome up front. Can you get just the surround and hood bulge and then remove the existing center from the chrome and place in the new surround....or is that just too much work? 2019 Tundra Double Cab SR5
  2. Mar 5, 2019 at 9:17 PM
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    you can buy the hood bulge approx, $200. you can buy a grill with the magnetic gray surround for your truck for about $350ish
    @Roman or sparksparts.com can help you
    AGia15 and GODZILLA like this.
  3. Mar 5, 2019 at 9:39 PM
    DCB500
    Oklahoma City
    Thanks for the info...I have seen plenty of info about the bulge and grills that are paint matched but I guess you am not sure which one I need to get that will work with the TSS module....I don’t mind the Toyota round logo but kinda like Toyota letters as well but I want to keep the honeycomb black insert for sure.
  4. Mar 6, 2019 at 4:23 AM
    atl1glf
    atl1glf New Member
    Too many TRD parts
    If you like the honeycomb and the round emblem, you can order the mag gray from a TRD Sport and it’s just swapping out grilles. You could more than likely post on Craigslist or find someone on this site that would take your old grille off hand. Expect to pay around $350ish.
    If you like the grille on the ‘19 TRD Pro that has Toyota spelled across then you can order the Pro grille but you would have to get the surround painted. Also, the ‘19 Pro grille requires the cover for the sensor which cost just as much as the grille. (Some Buy aftermarket sensor cover for about $100ish)
    Expect to pay around $$500-800ish if you go this route depending on sensor cover and paint.
    Depending on when you plan to do a grille swap the ‘20 TRD Pro is supposed to be in mag gray and you could wait about 7-8 months and probably purchase one with the matching surround. Again, more than likely would need the sensor cover. It may drop in price like the Tacoma did over time or may still be high.
    Another option is the ‘14-17 TRD Pro grille without the honeycomb in mag gray and you do a grille swap. That is what I did. (Cost of grille $250) you just have to swap surround. In my case, I have the limited grille so it was best for me.
    BravoDeltaRomeo, Rudy*1L15 and sdde4n like this.
  5. Mar 6, 2019 at 2:32 PM
    DCB500
    Oklahoma City
    Cool I think that narrows it down to the TRD sport as to the look I want and also easiest to swap out with the TSS sensor as well....that’s what I wasn’t sure about. Thank you!
    GODZILLA and atl1glf like this.
  6. Mar 6, 2019 at 5:38 PM
    atl1glf
    atl1glf New Member
    Too many TRD parts
  7. Mar 6, 2019 at 7:11 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    This is the TRD Sport color matched insert.
    Part Number Part Name Price Quantity Total
    76180-0C030-B1 Hood bulge - Magnetic Gray - 1G3 $195.76 1
    53101-0C040-B1 Grille Assembly - Magnetic Gray (1G3) $328.19 1
    Subtotal: $523.95
    The Dude, mZiggy, GoForthMGM and 3 others like this.
  8. Mar 6, 2019 at 7:16 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    He broke the plastic pins trying to get the push nuts off. Just use a flat screwdriver and small hammer. Rap the push nut edge and it will raise the opposite edge. Use pliers as if to unscrew it. It will pop off and you can hammer it flat for reinstallation.
    TRD-tv likes this.
  9. Mar 6, 2019 at 9:03 PM
    DCB500
    Oklahoma City
    Yeah I had watched that video before but just wasn’t sure it would fit the 2019 and also if that emblem would come off without breaking the tabs like he did in the video. Appreciate both of you for the information and also appreciate that pic @ShreveportTSS....I had been tying to find a front end pic with the paint matched grill/bulge with the chrome bumper end caps remaining, was thinking about deleting all the chrome in front but doesn’t look bad at all with that remaining.
    Thanks again!
    ShreveportTSS likes this.
  10. Mar 16, 2019 at 1:00 PM
    DCB500
    Oklahoma City
    Getting ready to start the mods to the front grill/hood bulge. Anyone interested in purchasing the chrome parts? 2019 SR5 with honeycomb center grill.
  11. Mar 17, 2019 at 7:07 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    let your local body shops know you have it. Someone will want to save a little here and there to keep from covering the deductible. Or I can sell you mine and you can have two sitting around.:boink:
    willy and GODZILLA like this.
  12. Mar 18, 2019 at 6:26 PM
    DCB500
    Oklahoma City
  13. Mar 18, 2019 at 6:27 PM
    DCB500
    Oklahoma City
  14. Mar 18, 2019 at 6:45 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    Maybe...where you at? Not worth shipping too much $$
  15. Mar 18, 2019 at 7:14 PM
    DCB500
    Oklahoma City
    Oklahoma City
  16. Mar 29, 2019 at 5:12 PM
    Rudy*1L15
    Rudy*1L15 One Love
    Rudy
    2018 MGM Tundra CM
    TRD exhaust TRD drop in w/ air accelerator Some De-badged and blackout Pop lock tailgate Tonneau cover Full tent Color match bumpers and grill Full LED upgrade Flip key fob TacoTunes system 3/1 Toytec level kit 1.25 Spidertrax spacers Horn Blasters Outlaw setup
    If you don’t mind, how did you swap out the insert? I have the same pro grill and want to swap but don’t want to break any of the tabs.
  17. Mar 30, 2019 at 7:08 PM
    atl1glf
    atl1glf New Member
    Too many TRD parts
    Once you take the grille off (plenty of you tube videos on this) then comes removing the inserts. It takes a lot of patience and some pry tools.
    Here is link to a video when I did mine
    https://youtu.be/kb4iBLYoq9M
    willy, 17inferno, JOEKEN and 4 others like this.
  18. Mar 31, 2019 at 6:21 AM
    conlons26
    Raleighwood, NC
    That looks real nice, about to do the same with mine, decided to order the pro grill and swap the limited insert.
    gjbsupCM and atl1glf[QUOTED] like this.
  19. Apr 1, 2019 at 3:32 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I broke mine off too (they are somewhat brittle). I simply used a belt sander to sand down the ends to just below flush (to the grille), drilled and tapped on center for M4 screws and re-attached with small fender washers to make a secure mount. Eezee peezee.
  20. May 15, 2019 at 8:35 PM
    Tmcush75
    Tmcush75 New Member
    Thomas
    19 Cement limited
    Great video! Will definitely help me on my swap
  21. Sep 30, 2019 at 6:58 PM
    Edier08
    Edier08 New Member
    Are these the part #'s ordering from a dealership? I have a 2019 I'd like to do this too but leave the honeycomb grill on thanks
  22. Sep 30, 2019 at 7:17 PM
    atl1glf
    atl1glf New Member
    Too many TRD parts
    They are the part #’s for the mag gray. What color do you need?
  23. Oct 1, 2019 at 4:03 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    This is correct. They are for the magnetic grey metallic color.
  24. Oct 1, 2019 at 4:43 AM
    Edier08
    Edier08 New Member
    Magnetic Grey :) i just want the grill surround and hood bulge to get rid of the chrome
    BravoDeltaRomeo likes this.
  25. Oct 1, 2019 at 6:01 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Stupid question: Is there not a way to successfully de-chrome it using chemicals?
    - Remove from truck
    - separate parts
    - de-chrome using oven cleaner or autobody product or something similar
    - Paint (or just put back on black)
  26. Oct 1, 2019 at 6:13 AM
    atl1glf
    atl1glf New Member
    Too many TRD parts
  27. Oct 1, 2019 at 6:17 AM
    atl1glf
    atl1glf New Member
    Too many TRD parts
    Not sure Howe it would turn out with it being plastic. I would imagine it would be the yellow/beige plastic underneath
  28. Oct 1, 2019 at 5:44 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Unfortunately they don’t sell the grill and surround separately.
    willy likes this.
  29. Oct 1, 2019 at 5:54 PM
    Edier08
    Edier08 New Member
    Huge let down
  30. Oct 1, 2019 at 6:19 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I originally thought the same but the MGM matching grill really looks good. I like it more than the black that came on it.
