Lowered Tundra Strut Replacement question
Discussion in 'Suspension' started by d44boy, Mar 4, 2019.
  1. Mar 4, 2019 at 11:08 PM
    d44boy
    d44boy [OP] New Member
    Hi guys,
    Before you bash me for having a lowered Tundra, it was a deal I couldn't refuse. Next truck I def wanna go higher. But anyway, I have a 2010 CM and it was lowered with a Tundra Racing 1"/3.25" drop. https://sosperformance.com/products/2-front-slash-4-rear-lowering-kit-fits-2007-16-tundra
    That's the actual drop. I have no idea about suspension but I need to replace my struts as my shock is leaking. Can you take a look at the kit I have from that link, and let me know if I can just buy replacement struts for a Tundra that is stock height? The drop apparently used the same shocks and springs for the factory, and I still have the stock ones. Does aftermarket struts run same standard sizes? Do I just shop for a stock Tundra height?
    Sorry for newb question but I need to replace and I watched enough videos to make myself think it's easy of an enough job. Thanks in advance.
