How to identify a 38 gallon tank in a salvage yard?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rod67, Mar 4, 2019.
  1. Mar 4, 2019 at 8:12 PM
    Rod67
    Rod67 [OP] New Member
    Rod
    2019 SR5
    To save $ I was thinking about looking through the local salvage yards for a 38 gallon tank.
    Anyone know an easy way to spot one? How early were they offered? Any particular year/models that they came standard on?
    Thanks!
  2. Mar 4, 2019 at 8:16 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    It's longer than the one you have.
  3. Mar 4, 2019 at 8:20 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    It really doesn't get any easier than that.
  4. Mar 4, 2019 at 8:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    2016+, must have bucket seats, aka not a bench front seat, I think at least an sr5 package, maybe even TRD. And yes its longer than your current tank.
  5. Mar 4, 2019 at 8:28 PM
    Rod67
    Rod
    2019 SR5
    Yeah I figured, but I won't be able to do a side by side comparison while crawling around the yards. Just hate to mess up and bring home the same as I already have!
    Was hoping for a quick visual clue.
    Thanks!
  6. Mar 4, 2019 at 8:32 PM
    Pudge
    CT
    Bring a tape measure for sure. Or even just cut a piece of wood or cardboard the length of your tank. Also you could run the VIN number through Toyota and it should let you know tank size
    15whtrd, Joe Dirt and HappyGilmore like this.
  7. Mar 4, 2019 at 8:46 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I think all tow packages have it. If it has a hitch and trailer plug in the bumper, should be it.
    That's pretty sweet if you can find a 2016+ truck in your yards. Around here you're lucky to even see a freakin Yota pickup in a yard, let alone anything newer. So many on the road still, people know their worth. Not many scrapped.
  8. Mar 4, 2019 at 8:52 PM
    Rod67
    Rod
    2019 SR5
  9. Mar 4, 2019 at 8:54 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    nope not mine sr5 with tow, small tank.
  10. Mar 4, 2019 at 8:54 PM
    Rod67
    Rod
    2019 SR5
    Found this pic on the site.
    My 2019 SR5 has the tow package but not the 38.
    Do all the higher end packages come with 38s?
    Inquiringone likes this.
  11. Mar 4, 2019 at 8:58 PM
    HappyGilmore
    Trent
    Lakewood CA
    Hmm guess I'm wrong. :hattip:Not sure then. Sorry I didn't help. Good luck.:)
  12. Mar 4, 2019 at 9:00 PM
    Rod67
    Rod
    2019 SR5
    No problem - thanks for the input!
  13. Mar 4, 2019 at 10:09 PM
    Sunnier
    Sunny
    San Diego, CA
    No, the 38 gallon tank is part of the TRD package. Along with the 2 front seats with center console.
  14. Mar 4, 2019 at 10:36 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    She's right. All TRD packages I've seen have the 38g. 2016 and up.
    Sunnier[QUOTED] likes this.
  15. Mar 5, 2019 at 3:47 AM
    Rod67
    Rod
    2019 SR5
    Ok, thanks - anyone know if they are standard on the Platinum, PRO and 1794 non TRD?
  16. Mar 5, 2019 at 5:35 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    No she is not. The larger tank isn't part of the TRD package, its part of the SR5 upgrade package which is what gets you the captain seats and center console instead of the front bench and column shifter.
    All the 2016+ TRD's have had the larger tank because you can't get the TRD package without the SR5 upgrade package but you can get the SR5 upgrade package without the TRD package.
  17. Mar 5, 2019 at 5:35 AM
    tundraty
    tundraty New Member
    Fort Worth, TX
    2022 Celestial Silver SR5 CM 4x4 TSS Off-Road
    I believe on the SR5's you have to get the SR5 upgrade package which includes the 38 gallon tank and a few other extras. I could be wrong but from what I've seen on local dealer's listings every TRD Off-road seems to include the SR5 upgrade package so I think it's a mandatory add-on to the TRD. I would imagine it's standard on the Platinum, 1794 and PRO
    JohnLakeman likes this.
  18. Mar 5, 2019 at 1:32 PM
    jawjatek
    jawjatek New Member
    N GA
    2019 Tundra DC TRD
    Yep, all the SR5 TRD off-road pack Tundras I looked at during my recent buy (including the one I bought) also had the SR5 upgrade which includes the big tank.
  19. Mar 5, 2019 at 1:35 PM
    Pudge
    CT
    I am 99% sure the answer to this is yes
  20. Mar 5, 2019 at 2:17 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    This is curious. The OP states he has a 2019 SR5 and the smaller tank. What gives? Or is there a difference between the "SR5" and "SR5 Upgrade Package"?
  21. Mar 5, 2019 at 2:35 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Its part of the sr5 upgrade package, and yes buckets and center console.
  22. Mar 5, 2019 at 2:39 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    bring 38 gallons of fuel with u. if 30 something fits u got it o_O
    landphil and HappyGilmore like this.
  23. Mar 5, 2019 at 2:55 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    True. The 38 gal tank IS included with the SR5 Upgrade package, but only if you also have the 5.7L engine.
    I have a 2017 SR5 TSS (TSS requires SR5 Upgrade package) w/4.6L...no 38gal tank.
  24. Mar 5, 2019 at 3:01 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    So is the SR5 and the SR5 "upgrade" two different things?
  25. Mar 5, 2019 at 3:08 PM
    JohnLakeman
    Yes. From my window sticker: SR5 Upgrade adds 38 gal tank (5.7L), front bucket seats w/power driver seat and power lumbar support, adds front center console with floor mounted urethane shift lever and knob, tilt and telescoping urethane steering wheel, 3 front cup holders, auto-dimming rearview mirror w/compass and Homelink Universal Transceiver, and an Anti-Theft System with Alarm and Engine Immobilizer.
  26. Mar 5, 2019 at 5:14 PM
    Sunnier
    Sunny
    San Diego, CA
    The window sticker isn't accurate. Gotta check the Toyota build page to know what each option, package includes. For instance, in the sticker described above, do I understand you found a truck with the front bucket seats and center console PAIRED WITH floor-mounted shifter?!
    A bunch of people on here want that and it's been nowhere to be found, and no ones found a mod. Have you got pics of that truck interior that sticker is describing?
  27. Mar 5, 2019 at 5:46 PM
    JohnLakeman
    What. You think I'm lying? OK...talking about 2017, not 2018, 2019 or any other year.
    The Gulf Coast Region in Houston (formerly the "port" for Japan manufactured trucks) supplies an extra-factory trim called the TSS (Truck Sport Series). The TSS qualifies as a "special package" under Toyota's corporate financing definitions. What I described on my window sticker is in fact an option specification, and I doubt that it is legal to provide ANYTHING but exactly what that window sticker specification says.
    In 2017, the SR5 Upgrade was Toyota option code "SP" and MSRP for that option, 4.6L sans 38 gal tank, was $1015. The TSS special package REQUIRES an SR5 Upgrade package as standard equipment (no SR5 upgrade, no TSS). I have observed that said upgrade includes all the items listed on my window sticker. The TSS package (Toyota option code "TS") ALSO includes (in 2017 at least) 20" tires (Goodyear Wrangler kevlar-belted) and machined face alloy wheels (very similar to some TRD wheels), 5" chrome oval tube steps, stainless steel exhaust tip, carpet floor mats, and TSS sport series bed decal (bfd).
    Want a TSS? Truck on down to Texas and get one...but all 5.7L will likely be flex-fuel with all those issues.
  28. Mar 5, 2019 at 6:05 PM
    zebian2
    zebian2 New Member
    Jamy
    Mine is a 2014 1794 with a 26.4 gallons tank.
    I’m about to upgrade to the 38 gallons
  29. Mar 5, 2019 at 6:41 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Damn, I will have to run my vin. I have all of that except the power lumbar and 38 gal tank.
  30. Mar 6, 2019 at 5:30 AM
    tundraty
    tundraty New Member
    Fort Worth, TX
    I think this is actually extremely common? Maybe I am wrong but I think every Tundra that has front bucket seats w/ center console has the floor mounted shifter from the factory. I can't imagine they would leave the column mounted shifter with this setup. Sounds like you meant to reference another setup possibly?
