spacers for 35" on stock 18" steel wheels 2007 tundra SR5
Discussion in 'Wheels & Tires' started by Gatorbisquit, Mar 3, 2019.
  1. Mar 3, 2019 at 10:04 AM
    Gatorbisquit
    Gatorbisquit [OP] New Member
    Frank
    WNY
    2007 black SR5 Tundra
    None yet, just got it. Working in customizing it
    anyone know what size spacer to run with the factory 18x9 steel wheels to use for 35" tires,, 35 x 11.5 x 18. Thanks for any help
  2. Mar 3, 2019 at 12:29 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Depends how far you want them to stick out, are you lifted? Are you trying to avoid cutting?
  3. Mar 3, 2019 at 12:37 PM
    Gatorbisquit
    Frank
    WNY
    I'm doing a 3" leveling kit. My concern is rubbing behind the tire, I've read that with 3" level/lift 35's would fit no problem. But I'd like to keep the stock 18" wheels 18x9 with the +60mm offset.
  4. Mar 3, 2019 at 12:49 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    Buddy of mine has a set of 1.5” Bora hub centric ones he just took off. Used them to fit 35s on TRD Pro wheels. With those spacers, it would put you at roughly a +22mm offset, which is pretty good for fitting that size tire without a BMC.
    Probably get em to you for a deal if you’re interested. Send me a PM if you want em.
  5. Mar 3, 2019 at 12:52 PM
    Berdine
    Frank
    Binghamton, NY
    Yeah, 1.25" - 1.5" would be best bet. I run 2" spacers with mine. Had to bmc. On my 07 I ran 1.5" and 35x12.50, rubbed mount at full lock, but didn't bother me.
    the_midwesterner likes this.
  6. Mar 3, 2019 at 12:59 PM
    Quebec
    Quebec New Member
    This will work with 285/75R18 with that offset. You will need to remove the small front bumper flaps and trim or replace the skid however.
  7. Mar 3, 2019 at 3:12 PM
    Gatorbisquit
    Frank
    WNY
    What is BMC?
  8. Mar 3, 2019 at 3:24 PM
    Voyagermike
    Voyagermike New Member
    California
    (BMC)Body mount chop
    (CMC)cab mount chop
  9. Mar 3, 2019 at 4:47 PM
    Gatorbisquit
    Frank
    WNY
    Ahhhh oh makes sense lol so 1.5" or 2" spacers for the 35's?
  10. Mar 3, 2019 at 5:19 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    At 11.5 wide do you even need spacers? Won't that width fit on stock 60+mm 8" wide rims?
    Berdine likes this.
  11. Mar 3, 2019 at 5:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Sometimes the tall tires will kiss the frame under full lock turn
    Berdine likes this.
  12. Mar 3, 2019 at 5:59 PM
    Gatorbisquit
    Frank
    WNY
    If I don't fully turn as far as they'll go I should be ok??? I mean how often do you really crank it all the way
  13. Mar 3, 2019 at 6:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    More often than you think
