Tri-Fold cover for the Pro
Discussion in 'Tonneau Covers, Caps and Shells' started by ScarWars, Feb 8, 2019.
  1. Feb 26, 2019 at 1:57 PM
    #61
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Did you miss where I put the Amazon prices on last night? The premium is not 80 more. The one I have is 684 right now and the one with led lights is 711.
    tundra403[QUOTED] likes this.
  2. Feb 26, 2019 at 2:07 PM
    #62
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    @Hammy68 ill go back and look. I have not checked Amazon yet.. unfortunately they collect tax for MS now.. so If i can, i try to reach out to other out of state vendors and get their best deal.. right now i was given two prices.. EH-TUN5514 - $645 out the door - HC-TUN5514 - $725 out the door.. (no tax & free shipping) so thats where i got my $80 difference from.. non the less, if i go RC ill be getting the E-Series
  3. Feb 26, 2019 at 2:45 PM
    #63
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    @tundra403 Here are some photos of the clamps etc. on the E Series Rugged Liner. The forward and rear clamps have the track slides that come with the kit. These tighten into the OEM track and provide a lip for the aluminum clamp to lock into. I found that by adding a large nut as a spacer to bring the plastic twist grip down, I could get the clamp into the truck’s track, which is much sturdier and easier to use. In the pics I just haven’t removed the track slide that came with the kit. 9477BCD1-2AB3-4A1F-B662-19D77FEE088F.jpg509DB298-73CA-4565-A7C0-656F3B1ED66A.jpg CEA5D25F-A4B9-4CDC-A395-3A2561443A1E.jpgBA3A7CF7-3024-407C-A683-96034E7E3D7F.jpg F1C47BAA-E1F5-40D8-B421-53C42B7E73AF.jpg46DA9B8D-2CB4-49B7-8164-A8D9352D2FE9.jpg
    tundra403 likes this.
  4. Feb 26, 2019 at 2:50 PM
    #64
    tundra403
    KG
    @Hammy68 thanks for the Pix man! Truck looks great. Snow looks cold. Unfortunately i do not have the cargo rails, so id just be clamping to the actual bed. thanks agian.
    Hammy68 likes this.
  5. Feb 26, 2019 at 2:58 PM
    #65
    ScarWars
    ScarWars [OP] New Member
    2019 Toyota Tundra TRD PRO Super White
    Only thing I can say that kind of a negative about the RC is the rear clamps. If you haul something large and it happens to roll around it could break one of those rear plastic clamps. That’s the only thing I worry about. Just have to pay attention and you’ll be fine
  6. Feb 26, 2019 at 3:03 PM
    #66
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    That’s true, but at least they provided an extensive replacement parts list if that did happen. I’ve had so much stuff piled in the back that I’ve only been able to lock one side, and that held good also.
  7. Feb 26, 2019 at 3:09 PM
    #67
    ScarWars
    Yeah I saw that replacement parts list in the box. They would probably send you one at no charge if you called them and explain how it broke.
    Hammy68 likes this.
  8. Feb 26, 2019 at 3:16 PM
    #68
    SDNY
    SDNY New Member
    Castleton NY
    2024 Sequoia Sonic Red
    Just my cents, check out TYGER covers. I have one on my 14 Tundra, install was easy, price was around $250 and have not had a leak. Been on the truck for 3 years and still looks like new. Planning on buying another one for my Crewmax. Check them out.
    ScarWars[OP] likes this.
  9. Feb 26, 2019 at 3:21 PM
    #69
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Did look at those, but is it a hard Tri Fold?
  10. Feb 27, 2019 at 1:36 AM
    #70
    SDNY
    SDNY New Member
    Castleton NY
    Yes, they are a tri-fold. I have one on my DC that I am selling. Picking up a Crewmax. Tyger also has a semi hard tri- fold cover as well. That is the one i am looking at. All the other hard covers are nice, but way to expensive.
  11. Feb 27, 2019 at 8:01 AM
    #71
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    I second the Tyger tri-fold. Just put mine on yesterday in about 10 minutes. Looks good and appears to seal good. I'll check for leaks after the gullywasher we are expecting tomorrow.
  12. Feb 27, 2019 at 3:58 PM
    #72
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Ive been looking for tri-fold covers too. That Tyger hard cover tri looks very interesting at a good price. I see it for 539 on their website but looks to be out of stock. I had been loking at the Rugged Cover E tri and the Extang 2.0. Not sure which one Ill go with...soo many choices!
  13. Feb 27, 2019 at 4:44 PM
    #73
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    The Tyger hardcover looks virtually identical to the Rugged Cover I have. Same clamps, same build, same aluminum panels and pattern. Wonder if Truck Hero makes these for Tyger now. Tyger didn’t have the total hardcover yet when I was looking in October or I would probably have grabbed one at this price.
  14. Feb 27, 2019 at 6:15 PM
    #74
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    These tri-fold covers that don't fold up the last third of the cover would not allow much access to the bed for tall stuff. At least the Bak-Flip and Undercover Flex covers will fold up against the cab for full bed access. That Lomax cover would be my pick if it folded up to the bed.
  15. Feb 27, 2019 at 6:21 PM
    #75
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    True, they don’t fold up out of the way, but for the occasional situation where I need the whole bed space, it’s not a big deal to remove the Rugged Cover....it comes off in about 30 seconds- and my back window view or powered down window isn’t blocked.
    RickC likes this.
  16. Feb 27, 2019 at 7:27 PM
    #76
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I've used both the sit on top and the flush mount ones a bunch on a few different trucks. The sit on top ones tend to be a little better waterproof, but you do lose the ability to fold up and use the entire bed at any time. The flush ones tend to not be as good of a seal at the tailgate, even the one where you have to close the tailgate before closing the cover. The biggest difference is unlocking them though - and it all comes down to personal choice. I like the cord unlocking both sides for the flush ones, they take no work to close (just slam it down) and I can be standing in the middle of the tailgate and open the cover.
  17. Mar 1, 2019 at 8:08 AM
    #77
    tundra403
    KG
    I think i am going with Lomax.. i have a great offer on it now for the tune of 675... i like how its low profile.. comes off quick... havent read any shitty reviews on it yet.. so might as well give it a shot... if not.. ill go rugged cover 2.
  18. Mar 1, 2019 at 9:24 AM
    #78
    RickC
    Rick
    Knoxville TN
    I am thinking about the Lomax as well. Best price I have seen is 953.70 from every website that sells them. Like posted previously, I think the manufacturer must set these prices. Where are you finding it for 675?
  19. Mar 1, 2019 at 5:40 PM
    #79
    Bill_2018_Tundra
    Bill_2018_Tundra New Member
    2018 Tundra Limited Crewmax TRD Off Road
    Line-X Premium AMP Powersteps
    Rick, check out autoanything.com. They have a 20% code ssmk20 on their checkout page that brings the price on the Lomax down to $706 and change. I think @eccracer104 can get us special forum pricing at autoanything.com as well. I will likely hit him up after my taxes are done if I have any $$ leftover. I think the Lomax is at the top of my list now.
    Edit, I see you have a DC. The $706 is for the Crewmax with deck rail system. The DC is a little more $ ($762).
    eccracer104 likes this.
  20. Mar 1, 2019 at 7:11 PM
    #80
    RickC
    Rick
    Knoxville TN
    I will check it out. Thanks for the info!!
  21. Mar 2, 2019 at 4:04 PM
    #81
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Yep the Lomax does look sleek. I did come across this fwiw.
    https://m.youtube.com/watch?v=hwrwaqQPHnc
    Now i know they had some problems with the seems early on and I think they fixed the issues. But I'm not sure how old the video is.
    Bill_2018_Tundra likes this.
