Spare wheel doesn't fit
Discussion in 'General Tundra Discussion' started by neirbot, Mar 2, 2019.
  1. Mar 2, 2019 at 6:47 AM
    neirbot
    neirbot [OP] New Member
    Stupid me. I bought a matching spare tire and wheel, and now I find that the carrier doesn't fit through the wheel hub bore. I should have known better.
    Any suggestions so I can keep it under the truck? Aftermarket solutions? Maybe need to fabricate something.
  2. Mar 2, 2019 at 7:55 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Um, are you sure it'll even mount on your Tundra?
  3. Mar 2, 2019 at 8:08 AM
    neirbot
    Yes it's an oem wheel.
    Pinay and Darkness like this.
  4. Mar 2, 2019 at 8:13 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    You may me able to trim the carrier down, hopefully not weaken it.
    Which OEM wheels are those?
    Sas likes this.
  5. Mar 2, 2019 at 8:19 AM
    Sas
    OKC, OK
    Hmm, I find it odd that OEM wheels wouldn't be compatible with an OEM carrier. What year are those wheels?
  6. Mar 2, 2019 at 8:30 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Do this.:sawzall:
  7. Mar 2, 2019 at 8:56 AM
    neirbot
    They were made for Toyota by BBS and included as part of the XSP package several years ago.
  8. Mar 2, 2019 at 9:04 AM
    Trooper2
    JR
    maybe get creative and cut the cable and insert a disconnect device or hook/loop etc
  9. Mar 2, 2019 at 9:04 AM
    neirbot
    That's a great idea.
  10. Mar 2, 2019 at 9:18 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You may be able to modify the OEM carrier. It appears that carrier spring won't clear the smaller center hole, and if did, the tabs that pilot into the OEM spare center hole would keep your alloy from sitting flat on the carrier. If you mod, make absolutely sure the spare can't escape off the carrier once the chain is tightened. The tabs keep the carrier from shifting too far in one direction if the chain loosens up...you'll need to duplicate that function for safety.
