Popping noise up front
Discussion in 'Suspension' started by DM 2018 Tundra, Feb 28, 2019.
  1. Feb 28, 2019 at 4:36 AM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    My 18 has A 6 inch lift RC. 1000 miles on lift. Took it to the shop and let them check everything and they stated that they didn’t know what it was. The person I normally talk to was off. Any ideas? Nothing was loose. Does it turning right in a dip or going side ways in a dip. The dip is like at stop signs or turning on to another road. Thanks for the help.
  2. Feb 28, 2019 at 4:41 AM
    Mnorris1206
    08 tundra
    Make sure they defiantly go completely threw it .Torque everything back down .I had this same thing not long after we did mine .Went threw it all again .And it stoped. I think some of it was coming from. The drop its self .At the top. Also have them check the tie rod ends making sure they are really tight .
    Black Wolf likes this.
  3. Feb 28, 2019 at 4:46 AM
    DM 2018 Tundra
    2018 Limted Tundra
    They went back Thur and torqued everything. I was in the shop watching them. I can feel in it my floor board. After I put my grab bar on one my friends was trying to make it do it in my driveway but couldn’t. I call them today and see what they say. Thanks dude!! I was just wondering if you or others had any issues. @Prostar 190 any issues?
    Black Wolf and Prostar 190 like this.
  4. Feb 28, 2019 at 4:48 AM
    Mnorris1206
    08 tundra
    I expect some noises off road but not on .But I know for sure my tie rod ends where a little loose also .Floor board still sounds lile on of the drop brackets a little loose .
  5. Feb 28, 2019 at 4:54 AM
    I have over 35,000 thousand miles on mine no issues whatsoever. Just throwing something out there could you have a bad sway bar link.
    Black Wolf and Mnorris1206 like this.
  6. Feb 28, 2019 at 4:59 AM
    DM 2018 Tundra
    2018 Limted Tundra
    Thanks guys!! I will run this by them when I call.
  7. Feb 28, 2019 at 5:46 AM
    Check your UBJ
    TheBeast and Prostar 190 like this.
  8. Feb 28, 2019 at 5:46 AM
  9. Feb 28, 2019 at 6:30 AM
  10. Feb 28, 2019 at 6:35 AM
    Mnorris1206
    08 tundra
    I can't wait to hear from this guy again lol @ARamirez73
    Prostar 190 likes this.
  11. Feb 28, 2019 at 8:44 AM
    DM 2018 Tundra
    2018 Limted Tundra
    Talked to the shop said to bring it by. I will when I get off work and do an update. Thanks guys
  12. Feb 28, 2019 at 9:19 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Interested in this. I have something similar with my 08, but haven't been able to pinpoint it. I thought it might have been the upper or lower ball joints, but both of those look good. Doesn't do it every time, and is definitely coming from the passenger side.
  13. Feb 28, 2019 at 2:44 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Ok shop has to cut the nibble off the bump stop on A arm. 47CA7028-5E2A-4B66-B925-29EC174F15CD.jpg
    Mnorris1206 and Prostar 190 like this.
  14. Mar 1, 2019 at 4:44 AM
    Mnorris1206
    08 tundra
    Off of that steering stop ? Or ? Not seeing what they are going to cut.
  15. Mar 1, 2019 at 7:41 AM
    DM 2018 Tundra
    2018 Limted Tundra
    If you can zoom in the clear coat is wore off. It’s the steering stop.
  16. Mar 1, 2019 at 7:44 AM
    DM 2018 Tundra
    2018 Limted Tundra
    In the middle of the red circle this is before the cut some of it off C9DC3BF7-0C7F-4247-BCE6-3D3E161B1E19.jpg
