Need suggestion for Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by gdiep, Sep 14, 2016.
  1. Sep 14, 2016 at 5:56 PM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Hello everyone,
    I just bought a used 2014 Tundra CM for my wife to drive. She loves it so far and I'm impressed with the room inside.
    The Tundra has the factory deck rail system and I have been reading the threads about tonneau covers.
    Is there a cover that can be installed without relocating or removing the deck rail system?
    Thanks for your help.
  2. Sep 14, 2016 at 6:13 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    Sounds like me. I also had a Access Original Cover on my old Taco. Worked flawlessly. 11yrs. I have one on my Tundra now with a bed rail system. they have special clamps to accommodate bed rails. Be sure to specify you have the system. Regular application of armor all and it will last as long as you own the truck.
  3. Sep 14, 2016 at 6:15 PM
    bobbilly
    bobbilly New Member
    Depends on what kind of tonneau cover you are looking for. (Soft roll up or hard fold) I just installed the low pro truxedo on mine with the deck rails. Only complaint is it makes the rails a little difficult to use to tie down anything.
