Readylift kit help
Discussion in 'Suspension' started by Nap1970, Dec 22, 2018.
  1. Dec 22, 2018 at 6:08 AM
    Nap1970
    Nap1970 [OP] New Member
    2018 Tundra TRD off road
    I am still trying to figure out what to do on my truck as someone who has never leveled or lifted a truck before. I was hoping to get some feedback and information. Based on my research and limited understanding of this stuff, it seems that a Readylift 3/1 kit is likely the way to go for me.
    I understand the difference between a suspension lift vs a body lift but what’s the difference between a suspension lift and Readylift 3/1 kit? Readylift 3/1 kit is something called a smart suspension technology lift and a sort of middle ground between a leveling kit and suspension lift. Would greatly appreciate any information offered to help clarify this for me as well as if anyone could post pictures of their trucks if they have any of the following:
    Readylift 3/1 kit installed with stock 275/65R/18 tires?
    Readylift 3/1 kit with 33” tires on either 18” or 20” wheels?
    Readylift 3/1 kit with 35” tires on either 18” or 20” wheels?
    Thanks for all and any helpful feedback and happy holidays.
  2. Dec 22, 2018 at 8:08 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    My Ready Lift 3/1 with 18” wheels and 275/70 KO2s:
  3. Dec 26, 2018 at 4:49 PM
    Nap1970
    Nice! Approximately how much additional ground clearance did the Ready lift 3/1 kit add?
  4. Dec 26, 2018 at 4:53 PM
    Blueknights75
    Ron
    Clayton, NC
  5. Dec 26, 2018 at 5:15 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Getting mine installed tomorrow morning. I’ll post pics and give you my thoughts tomorrow.
  6. Dec 26, 2018 at 5:33 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I have no experience with Ready Lift, but it looks like their 3/1 kit uses a front spacer and a rear block. Technically it’s a suspension lift in that it pushes the front control arm assembly down to achieve lift by using a what appears to be a metal spacer. I just don’t know if it’s the kind of spacer that fits in between the top of the coil spring and mounting bracket or if it fits on top of the mounting bracket. For the rear it looks like it raises the leaf pack up by using a block on the axle’s leaf spring perch.
    It doesn’t necessarily add any kind of improved suspension performance since it still uses the stock front coilovers and stock rear leaf pack and shocks. It does change the suspension’s geometric angles a bit, though, especially up front. Not sure if the kit comes with new upper control arms, but if you have trouble aligning it, you may need some aftermarket ones to help with that. Some also suggest a front differential drop (diff drop) that uses a spacer to help re-angle the differential and CV axles to run more parallel. Others seem to do fine without that, though.
  7. Dec 30, 2018 at 12:11 PM
    Steve89gt
    2018 Limited CM
    Im not sure; didn’t do a ton of homework/research before I bought the kit. There’s a guy I work with who I know to be a mechanical anally retentive person; he has a Tundra, and he used a Ready Lift kit. Just followed his advice and went with the same thing he used...
  8. Dec 30, 2018 at 12:58 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I’d go with a coilover lift over spacer lift any day.
    Before some butthurt members chime in, it’s YOUR money, YOUR truck, you do what you want.
    But if you’re going to be on trails, or pothole laden roads, your truck, your ass and your wallet will thank you in the long run if you get coilovers. Buy once, cry once.
    T-Rex266 and GNTundra like this.
  9. Dec 30, 2018 at 1:07 PM
    Steve89gt
    2018 Limited CM
    Yeah, knowing what I know now, I would have done something different; Bilstein 5100s or maybe something sexier. When my current shocks wear out in a few years I’ll revisit the issue.
    Phantastic81 and Law323[QUOTED] like this.
  10. Dec 30, 2018 at 1:12 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Did the same. Got spacers and within 6 months of teeth chatter, butt cheek bruises and a sore tailbone, not to mention constantly checking to see if everything was coapacetic under the wheel well, I went for the BOSS kit. Haven’t looked back once.
  11. Dec 30, 2018 at 1:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not to bust balls, but if you have blocks on the rear suspension with stock suspension, I would check them out. Had my 12 for 2 years and blocks for 8 months, when I got aftermarket rear shocks, I realized I could compress and depress my rears by hand. Realized it was because of my 1” block forcing my rears to operate outside of manufactured capabilities, eventually they quit.
    Bed bounce is a TON better now.
  12. Dec 30, 2018 at 1:32 PM
    Steve89gt
    2018 Limited CM
    What setup do you have now?
  13. Dec 30, 2018 at 1:36 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Very simple setup.
    Toytec BOSS - dialed to 3” even
    Toytec BOSS rear with resi
    1” Toytec Block in rear
    275/70r18 toyo AT’s (next will be 295/70r18)
    Upcoming method roosts in bronze (should be a week or two before they’re delivered/mounted)
    Patriot likes this.
  14. Dec 30, 2018 at 1:39 PM
    If you’re going to go with spacer because u don’t want, it cannot purchase a c/o setup, then at least go with an in-coil spacer kit, or Bilisteins all around.
    Law323 likes this.
  15. Dec 30, 2018 at 1:50 PM
    Steve89gt
    2018 Limited CM
    So would you (Law and Trex) say that 5100s are the most basic lift setup that you would consider? I’m starting to feel like maybe I’ve gone cheap at the expense of quality. All opinions welcome, no butt-hurtedness will occur...
  16. Dec 30, 2018 at 1:59 PM
    5100’s all around is an affordable option, yes.
  17. Feb 2, 2019 at 3:11 PM
    Steve89gt
    2018 Limited CM
    Took the Ready Lift out yesterday, now rolling 5100s. Ride is MUCH better
    r1-superstar and Patriot like this.
  18. Feb 2, 2019 at 3:22 PM
    fliberto38
    fliberto38 New Member
    Frank
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    On my old 12 Tundra I did 5100's all around. With the front on the highest setting and a 1" block in the rear. I have seen a bunch of the ready lift kits. It's a spacer on top of the front shock mount. Probably one of the better spacer kits. But I would do the 5100's at minimum. Way better ride and as stated above, the rear block will kill your rear shock before you know it.
    Steve89gt likes this.
  19. Feb 27, 2019 at 4:29 PM
    Nap1970
    Decided to go with a 3/1 ready lift leveling kit. Can’t decide between 35” or 33” tires and I am considering keeping my 18” stock TRD wheels as I have never been one too impressed with fancy rims. Anyone have any pictures they can post with 3/1 ready lift kit with 18” and 20” wheels with different size tires? Also, any suggestions are welcome.
  20. Feb 27, 2019 at 5:06 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Toytec Boss yes!
    Read lift nope.
  21. Feb 27, 2019 at 5:12 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    33’s are too small for a 3/1.
  22. Feb 27, 2019 at 7:52 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    It's what ever tickles your fancy. My truck specs are listed below and I got 305/65-18 approx. 33.6" They are plenty big. I didn't want/need 34"+ tires. 35" tires will kill your gas mileage. But again, get what you want and will suit your needs and make you happy.
  23. Feb 28, 2019 at 9:02 AM
    robc
    robc New Member
    2017 Crewmax Limited 4x4
    Measure your front rake before you decide. I did the 3/1 without doing that and I ended up with the front up an inch over the back. Had to change out the back 1" block to a 2". This is the final result with stock 20" wheels.
  24. Feb 28, 2019 at 9:31 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    Here is my 3/1 ready lift with 35sF549E267-F172-4896-8CFF-521C61A81300.jpg
    equin and TOYOTAGUYS like this.
  25. Feb 28, 2019 at 9:39 AM
    DiegoC
    Diego
    equin, Texas Bandit and TOYOTAGUYS like this.
  26. Feb 28, 2019 at 9:39 AM
    DiegoC
    Diego
    Side
    TOYOTAGUYS likes this.
  27. Feb 28, 2019 at 12:40 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I had the same issue. Every truck is different
  28. Feb 28, 2019 at 1:09 PM
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    That looks great! Care to share your wheel/tire specs?
  29. Feb 28, 2019 at 6:44 PM
    r1-superstar
    DB
    UTAH
    Are you getting aftermarket rims/tires?
  30. Mar 2, 2019 at 11:22 AM
    DiegoC
    Diego
    Sure! Method 305 NV
    Rims: 18x9 +25 off set
    Tires: Toyo MT 35x12.50
