2003 V6 Cold Air Intake
Discussion in '1st Gen Tundras (2000-2006)' started by ry3737, Feb 27, 2019.
  1. Feb 27, 2019 at 8:23 AM
    ry3737
    ry3737 [OP] New Member
    2003 Tundra V6
    N/A
    Is it worth it?
  2. Feb 27, 2019 at 8:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Toyota does a pretty good job with the stock intake. Not much to gain. Not to familiar with the V-6 airbox but I would assume it’s similar. Just put in a better flowing air filter and call it a day.
  3. Feb 27, 2019 at 8:30 AM
    ry3737
    2003 Tundra V6
    N/A
    Thanks for the reply!
  4. Feb 27, 2019 at 2:45 PM
    Aerindel
    Aerindel New Member
    Montana
    Do you mean a real cold Air intake or a Short Ram intake?
    Most of the things that people call a cold air intake are actually short ram intakes which actually pull in WARM air from under your hood.
    Most stock air systems pull cold Air from outside your vehicle. In tests the warm air of the short ram intake usually cancels out its benefits.
    ry3737[OP] and 15whtrd like this.
