Billstein help
Discussion in 'Suspension' started by OkcthunderGuy, Feb 25, 2019.
  1. Feb 25, 2019 at 5:13 PM
    OkcthunderGuy
    OkcthunderGuy [OP] New Member
    Dustin
    OKC
    14 Tundra TSS
    the fun is just beginning
    hey guys. Needing some clarification. I want to install a set of 5100’s on the front of my ‘14 SR5 2wd to level it. Is there a specific 5100 I need (part number? Series) anything else I might need to specify exactly what I need? Also, do I need anything besides the shocks?
  2. Feb 25, 2019 at 5:18 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  3. Feb 25, 2019 at 5:18 PM
    Middle setting
    Bilstein 5100 0.87-2.28″ Front Lift Adjustable shocks for 2007+ Toyota Tundra (PT# 24-232173)
    SKU: 24-232173
    www.xkstensiveoffroad.com
    https://www.xkstensiveoffroad.com/s...(Free_Shipping_Lower_48)_(PT#_24-232173).html
    $196 for the pair shipped
  4. Feb 25, 2019 at 5:20 PM
    Berdine
    Frank
    Binghamton, NY
    This ^^^^^^
  5. Feb 26, 2019 at 5:53 AM
    OkcthunderGuy
    Dustin
    OKC
    14 Tundra TSS
    ordering today. is it a pretty straight forward swap? or is there anything to look out for? havent been under my truck yet, but ive changed all my own suspension on past cars
  6. Feb 26, 2019 at 6:18 AM
    15whtrd
    15whtrd Mr. Blonde
    There are some good and bad YouTube vids out there. If you’re not buying them assembled with springs, that will have to be done. Either use your stock or new ones.
    Here is instructions for my pro shock installation. Same rules apply.
    https://www.dropbox.com/s/sxjguie9rkx4dti/PTR13-34140inst.pdf?dl=0
    Berdine likes this.
  7. Feb 26, 2019 at 6:26 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This is the method I used the second time. Pretty simple. It took me two hours https://www.youtube.com/watch?v=iH7FQUjmu20 I used the method @15whtrd posted here; took too long and unnecessary to remove all those bolts and loosen the a-arm cams; took me three hours. Go to Auto Zone and get spring compressors via their "Loan-A-Tool" program https://www.autozone.com/loan-a-tools/loaner-strut-spring-compressor . Take you time and wear safety goggles. Then go get an alignment.
    Berdine and 15whtrd[QUOTED] like this.
  8. Feb 26, 2019 at 6:44 AM
    15whtrd
    15whtrd Mr. Blonde
    It was my first time. But some of the parts/bolts removal seemed unnecessary. But that’s what was recommended and I wasn’t about to make shit up as I went lol. I’m very methodical and ocd. So I like to do it the recommended way the first time. Then make my own shortcuts.
  9. Feb 26, 2019 at 6:50 AM
    r1-superstar
    DB
    UTAH
    Yeah, I hear you. When I did it the second time, I was like "WTF?" Sat there drinking my beer thinking about all the time I saved the second time around. haha I had a super hard time getting those two bolts back in that attaches to the bottom of the lower ball joint assy
    15whtrd[QUOTED] likes this.
  10. Feb 26, 2019 at 9:54 AM
    OkcthunderGuy
    Dustin
    OKC
    14 Tundra TSS
    Thats exactly what i was looking for. Thanks guys for the quick responses. this'll be next on the project list.
    if my rear shocks (oem's) are still good, is there any point in replacing those at the same time?
  11. Feb 26, 2019 at 10:07 AM
    15whtrd
    15whtrd Mr. Blonde
    Not necessarily. But I think I would want the rear to match. Some people change out the rears to 5160s I think it is.
  12. Feb 26, 2019 at 12:06 PM
    r1-superstar
    DB
    UTAH
    I wouldn't change the rears if they are still good and function for your needs. I only changed mine because I lifted the rear.
  13. Feb 27, 2019 at 2:00 PM
    mortiz21
    mortiz21 New Member
    Marissa
    2015 Tundra CrewMax Limited Attitude Black
    275/60/20 Nitto Ridge Grapplers on Fuel Mavericks 5100 Bilsteins in the front EAG Raptor Grill Insert
    Thats all I am having done. Just 5100 Bilstein in the front to level it out to fit the new wheels and tire. Did not see the need to mess with the rear.
