Will it settle
Discussion in 'Suspension' started by TOYOTRD8, Jan 20, 2019.
  1. Jan 23, 2019 at 7:57 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    You'll get it right, just don't try to re-invent this. Make it as simple as possible:thumbsup:
    TOYOTRD8[QUOTED][OP] likes this.
  2. Jan 23, 2019 at 8:00 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Process:
    Phase 1
    Park truck on level ground.
    Measure fender height at all 4 corners. (set base-line).
    Optional: lay level on ground. compare to level when on bedrail.
    determine rake. does front need to come down? If so how much?
    Phase 2:
    Jack truck up place jack-stands in appropriate locations
    Remove front wheels
    Measure thread height on body document current setting.
    clean threads and lubricate threads above collar
    Loosen allen screw on coilover lock collar.
    Use shock coilover adjustment tool or buy a 1/4 extension and cut square end off.
    Insert tool in collar holes and rotate.
    move collar 1/2 the distance of desired rake adjustment.
    The shock mount on LCA is located in the middle between pivot points.
    monaco730, Hbjeff and TOYOTRD8[OP] like this.
  3. Jan 23, 2019 at 8:28 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    I happen to have a 1” BDS shackle in the for sale thread somewhere, just FYI. $125 shipped. Best of luck either way!
    TOYOTRD8[OP] likes this.
  4. Feb 27, 2019 at 10:24 AM
    kdugal30
    kdugal30 New Member
    ken
    Shackle or AAL in rear. That kit doesn’t provide any rear lift, just new shocks. I’d go at least 1.5” aal in the rear.
