  1. Feb 25, 2019 at 8:52 PM
    #3601
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    they go over, so its much simpler. im debating getting the heated seat kit before i go ahead and install them
    Rica25 and Coldjustin[QUOTED] like this.
  2. Feb 26, 2019 at 4:45 AM
    #3602
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Thanks guys,
    They're the perforated leather option and I got them at Clazzio.com using the Valentine's sale code that they had. The covers were a VD present from my wife. She just didn't know that she bought them for me :rolleyes::D:p
    They do fit over the existing upholstery unlike the Katzkins that are really a complete re-upholstery. Install wasn't as bad as thought it was going to be in terms of a wrestling match. But you do need access to the back of the rear seats. So if you have a DC and have not done the rear seat mod yet, you will need to unbolt them so you can lift the seat back off the securing hangers.
    I skipped the heated seats. Rumor is that the ones supplied by Clazzio aren't that good. Now that I know what I'm doing, it wouldn't be too difficult to pull the front seats and re-install with a third party unit in the future.
    Coldjustin and Trooper2 like this.
  3. Feb 26, 2019 at 3:12 PM
    #3603
    kgb4187
    kgb4187 New Member
    Tried putting in a 12 radio in my 07 to get bluetooth, but that's not how it works apparently. Plugged in and the radio worked fine, but got an error message saying "no BT player found"
    CaptSpaulding likes this.
  4. Feb 26, 2019 at 3:12 PM
    #3604
    kgb4187
    kgb4187 New Member
    Also put in my AJT knobs
    52755238_10218703319882011_8476546038046_2e1b000894d8e2fcc42243ed5abe0bc1fc0fc8da.jpg
  5. Feb 26, 2019 at 3:44 PM
    #3605
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Moved that rear breather finally....yes I cleaned up the thread lock. Not many more 1 armed mods I can do!
    Trooper2 and Mountun Goat like this.
  6. Feb 26, 2019 at 3:48 PM
    #3606
    CaptSpaulding
    Jake
    2010 White DC 4x4
    They look so good!
    kgb4187[QUOTED] and TheBeast like this.
  7. Feb 26, 2019 at 4:20 PM
    #3607
    TheBeast
    TheBeast The Beach
    link ?
  8. Feb 26, 2019 at 4:21 PM
    #3608
    TheBeast
    TheBeast The Beach
    cut the exhaust to clear at full droop dem Deavers + bypasses.
    before: leaf pack resting on exhaust at full droop..
    after:
  9. Feb 26, 2019 at 7:38 PM
    #3609
    kgb4187
    kgb4187 New Member
    TheBeast[QUOTED] likes this.
  10. Feb 26, 2019 at 7:43 PM
    #3610
    JoshJones1980
    JoshJones1980 New Member
    Joshua
    Bartlesville, OK
    2013 TSS Off-Road CrewMax SR5
    Well, I didn't install it yet - but I did just order my 8" Standard kit from Dirty Deeds Industries.
    I can't wait!
    Rica25 and CaptSpaulding like this.
  11. Feb 27, 2019 at 6:06 AM
    #3611
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Installed the ECGS front clamshell bushing. No more 15-45mph 2wd grumble! I did need a 39mm 12pt for a axle nut. I bought their removal tool which worked great but cheaped out on the install tool so it was a little challenging to get it started straight then pounded in fine. I would recommend freezing your new bushing but I forgot that step. After it was done I had a squeaking sound around 20 mph, put it in 4wd and the squeak went away, back to 2wd and it's still gone, must have needed to get the gear oil all mixed around. The worst part of the install was my frame was just coated so I ruined a shirt rubbing my arms against that sticky CRC.
    Prostar 190 and Trooper2 like this.
  12. Feb 27, 2019 at 7:02 AM
    #3612
    oogabooga289
    oogabooga289 New Member
    Did you need to remove the axle nut (and I'm assuming the whole CV axle) to pull it out of the diff? I thought people were able to undo the two LCA-to-spindle bolts and swing the whole wheel/hub assembly out far enough to pull the CV axle out of the diff?
  13. Feb 27, 2019 at 8:58 AM
    #3613
    Comfort
    Comfort New Member
    Trinidad
    2013 Toyota tundra 4x4 Crew Max 4.6l
    6" Lift 24" rims small music upgrade tray cover fender flare Chrome grill
    Just some of the upgrade I made to my 2013 4.6l Tundra.
    Started to get rid of some of the chrome.......next I`m looking to change the rims and tires.....
    I`m from Trinidad so everything is ordered online........
    20190209_161258.jpg 20190119_175515.jpg 20190208_165326.jpg 20190223_064415.jpg 20180211_175306.jpg
  14. Feb 27, 2019 at 9:31 AM
    #3614
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Clean truck
  15. Feb 27, 2019 at 9:55 AM
    #3615
    blackoutt
    Indy
    OEM+
    Maybe it's possible to swing all that junk aside but it's tight quarters to drive the new bushing in so I opted to undo the one 39mm axle nut and the axle slid right out allowing me to undo two lower ball joint bracket bolts and swing the entire spindle towards the front of the wheel well.
  16. Feb 27, 2019 at 9:59 AM
    #3616
    FXFormat
    FXFormat New Member
    Picked up a used topper today with roof rack, sweet score for $500. Like new condition, plan is to bedline it in black and wrap the truck white.
    Along with my decked setup, this would make a sweet weekendlander rig no? queen mattress fit back there and i can fit 2 thicc chicks with me.
    kparrow, Tor, Part_time and 7 others like this.
  17. Feb 27, 2019 at 11:54 AM
    #3617
    Comfort
    Comfort New Member
    Trinidad
    Thanks....
    It`s a weekend driven....
    CaptSpaulding[QUOTED] likes this.
  18. Feb 27, 2019 at 12:09 PM
    #3618
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    lol fuck yeah! i've been looking for a deal like that for a minute. craigslist out here just aint producing
    Prostar 190 likes this.
  19. Feb 27, 2019 at 12:46 PM
    #3619
    nice find but if you wrap the truck and white you're going to lose 50 horsepower!
    Tor and NE_WARRIOR like this.
  20. Feb 27, 2019 at 12:51 PM
    #3620
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Dang! He went there. :cool:
  21. Feb 27, 2019 at 1:33 PM
    #3621
    FXFormat
    FXFormat New Member
    I found it on FB marketplace, seller was asking $800, after some haggling and some BS on my part (told him i can drive a little further and get this for $450 and im getting ond today so let me know) after some silence the dude say okay when can you come get it. The rack alone is worth money, overall in great shape, didn't see any scratches or chips. Keep trolling C list and FB market you'll land one bro.
    speckmon[QUOTED] likes this.
  22. Feb 27, 2019 at 1:34 PM
    #3622
    speckmon
    Thornton, CO
    If i could wrap my truck any color I'd probably pick something other than white. I'd probably go with something to blend into the trees with so nobody would bug me, ESPECIALLY if it'll be off-road and have me and my girl sleeping in it. i don't like being near people, much less seen by them, when i'm out camping.
    nice i'll have to get on there and take a look, not much a of a facebooker but i could be for a deal!
  23. Feb 27, 2019 at 1:36 PM
    #3623
    TheBeast
    TheBeast The Beach
    that's all you need really..haha !
  24. Feb 27, 2019 at 1:36 PM
    #3624
    Trooper2
    JR
    Houston, TX (Suburban South)
    Looking at these on-line. Are yours Black or Gray?
  25. Feb 27, 2019 at 1:36 PM
    #3625
    FXFormat
    FXFormat New Member
    Just trying to match my stable of vehicles :D
    speckmon likes this.
  26. Feb 27, 2019 at 1:41 PM
    #3626
    FXFormat
    FXFormat New Member
    Tried to go through a carwash, the kid busted out a measuring tape and say nope, you're too big sir. So they ended up power washing the mud off infront of the entrance, only charged me $10 and i tipped them an extra 10. Truck still dirty, but manageable and i can get it detailed later.
    CaptSpaulding, TheBeast and Trooper2 like this.
  27. Feb 27, 2019 at 2:45 PM
    #3627
    radon222
    Ed
    NW Arkansas
    Stock for now
    They are Black with Black stitching. What they usually listed as In Stock. Any other color is generally a custom order and potentially a really long wait.
    Trooper2[QUOTED] likes this.
  28. Feb 27, 2019 at 3:12 PM
    #3628
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Without the context of the previous sentence, it'd make a person think ya caught the clap recently :eek::rofl:
    Trooper2 likes this.
  29. Feb 27, 2019 at 3:15 PM
    #3629
    zcarpenter92
    Zach
    NE Colorado
    In sig
    If I was gonna buy a hunting truck, that'd be it right there! Diggin how your ride looks with a topper buddy.
    FXFormat[QUOTED] likes this.
  30. Feb 27, 2019 at 3:55 PM
    #3630
    FXFormat
    FXFormat New Member
    It rides a little different now, i wanna say it's more stable since the rear end is heavier, but also feels a little slower. can't wait to finish building a sleeping area back there, this is my cross country roadtrip vehicle.
