Leveling question....
Discussion in 'Suspension' started by Mikeylud, Feb 26, 2019.
  1. Feb 26, 2019 at 5:38 PM
    Mikeylud
    Mikeylud [OP] New Member
    Carson City, Nv
    2013 White Tundra Dbl Cab
    6" pro comp lift, 37x13.5r20 nitto ridge grapplers, mayhem wheels, custom exhaust, s&b intake, bullydog tuner, wrapped roof, chrome delete, debadged, aftermarket headlights & tail lights, remote start, aftermarket grille.
    I recently bought a tundra that has a level on it. But they put 2" blocks in the back as well so I still have that rake look. Is it possible to get the back 2" blocks switched out for 1" blocks? Do they even make those? Ha. I'd appreciate any feedback..
    Prostar 190 likes this.
  2. Feb 26, 2019 at 5:39 PM
    Yes they make a 1" block.
  3. Feb 26, 2019 at 5:40 PM
    Mikeylud
    Carson City, Nv
    Ok. It might sound petty. But I just hate that rake look. Thank you!
  4. Feb 26, 2019 at 5:40 PM
    Mnorris1206
    08 tundra
    I'm not for sure if you took the 2" out . would it be level ?
  5. Feb 26, 2019 at 6:01 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    You can also swap the blocks out for a rear shackle lift which come in various heights and multi-height versions too. Toytec, Coachbuilder, etc...
  6. Feb 27, 2019 at 4:16 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I would go the coachbuilder #2 shackle route. Gives 1.25” of rear lift. Helps with bed bounce and will make the ride not as hard
