Hid conversion
Discussion in 'Lighting' started by ccam, Feb 25, 2019.
  1. Feb 25, 2019 at 6:51 PM
    ccam
    ccam [OP] New Member
    chris
    Fishers IN
    2011 Tundra Crewmax TRD
    1 in spacer lift on top of the coilovers and in rear, k&n cold air intake, toytec tunebcs coilovers up front, toytec boss 3in lift rear shocks, trd rear sway bar, straights from the cat. back (She purrs a little)
    2011 crew max Trd
    Stock headlamps.
    I am looking for a bright driving setup. I know nothing about what I need to upgrade properly to HID. Any advice would be appreciated
  2. Feb 25, 2019 at 7:08 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Proper hid upgrade is by retrofitting hid projectors into your housings. Adding just hid bulbs and ballasts is a no no. Too much glare for oncoming traffic and lots of unusable light
  3. Feb 25, 2019 at 7:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    MotoTundra and SouthBoundSteve like this.
  4. Feb 25, 2019 at 7:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks @831Tun !
    I agree with @Pudge
    If a retrofit is too much work, @Baja Designs should be coming out with an SAE/DOT approved fog light within the next few months. A great set of fogs may do the trick.
    831Tun likes this.
  5. Feb 26, 2019 at 3:26 AM
    ccam
    chris
    Fishers IN
    Ok u talked me out of it. Can I just purchase new instead of trying the crazy conversion stuff
