Engine noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota707, Feb 24, 2019.
  1. Feb 24, 2019 at 7:50 PM
    Yota707
    Yota707 [OP] New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    so I have a 15 Tundra 5.7 CM with 75k on it. All routine service done. The past few weeks when I start the truck it sounds like a belt noise or maybe a pulley going bad. How would I determine the exact location? It’s hard to tell from just starting it and looking into the engine bay. The power steering pump is full of fluid and doesn’t seem to have any problem with the power steering. Want to try to troubleshoot before going to the dealership. Any advice will be helpful thanks!
  2. Feb 25, 2019 at 8:50 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Turn the a/c on and off and listen for the sound to go away. If it does it’s likely the a/c compressor pulley.
    15whtrd likes this.
  3. Feb 25, 2019 at 8:51 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    If you look at the pulleys while it’s running you can sometimes see a wobble in the affected pulley.
    You can also pop the belt off and turn the pulleys independantly of one another. Feel for a lack of smoothness like a slight wobble or a grind.
  4. Feb 25, 2019 at 9:16 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    How does your serpentine belt look ?
    Your below the recommended miles for when you should is change it but sometimes environmental conditions can fatigue the belt early. 90k is the recommended timing.
    Yota707[OP] likes this.
  5. Feb 25, 2019 at 12:58 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Serpentine belt looks in good condition. I’ll try the A/C recommendation see if this can narrow it down. Thanks for the advice!
