Nice article on painting plastic chrome trim
Discussion in 'Detailing' started by trd4life, Feb 23, 2019.
  1. Feb 23, 2019 at 11:30 AM
    trd4life
    trd4life [OP] New Member
    2015 Black Limited CC 4x4 5.7
    2” lift 285/65/20 Nitto Terra Grapplers
  2. Feb 25, 2019 at 7:10 AM
    gdog_Tundra
    gdog_Tundra New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
    Thanks for sharing!
    G
  3. Feb 25, 2019 at 8:27 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    If anyone is going to do this painting, I'd suggest taking it up one notch. Get out the pressure washer and knock off all that chrome, down to the plastic. Once you get it started, it comes off pretty easily (as long as you have a gas powered pressure washer). Then give it a light sanding followed by adhesion promoter and then paint. Also, not a shot at duplicolor, but I've had great paint in the past from automotivetouchup.com.
  4. Feb 25, 2019 at 8:42 AM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    x2 for taking it up a notch, much better to start with bare plastic than painting over chrome. if the pressure washer does not work you can go the chemistry method, 2:1 hydrogen peroxide : muriatic acid bath for about 2.5-3 hours will pull it right off the plastic. i have used touchupdirect.com for color match rattle cans, they have a great match for quicksand.
  5. Feb 25, 2019 at 9:04 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Does that work for chrome bumper ends?
  6. Feb 25, 2019 at 9:15 AM
    conlons26
    Raleighwood, NC
    Negative, you cannot strip the chrome from the metal, you either have to take it to a chrome plater and have them strip it off or sand/media blast it off...not so much a DYI project for those if you want to take them down the substrate.
    JoshuaA[QUOTED] likes this.
