Cam Leak FIRE!
Discussion in '2nd Gen Tundras (2007-2013)' started by kazbeh, Feb 22, 2019.
  1. Feb 22, 2019 at 3:55 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Welcome from Utah, sorry for your loss.
  2. Feb 22, 2019 at 3:57 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Glad no one was hurt. I check my engine about once a week, im going to start checking it more often. Do you have any idea if it was a small leak or big leak?
  3. Feb 22, 2019 at 3:59 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  4. Feb 22, 2019 at 4:04 PM
    Welcome. Sorry to see my man.
  5. Feb 22, 2019 at 4:08 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Sas[QUOTED] and Sunnier like this.
  6. Feb 22, 2019 at 4:18 PM
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    Welcome and sorry to hear about your truck. I wonder if the fire department may have overlooked something else.... something electronical? It's crazy a fire would start from a truck that's still warming up.
    landphil likes this.
  7. Feb 22, 2019 at 4:27 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    WOW! Welcome from CO and sorry.
  8. Feb 22, 2019 at 4:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Fire investigators determine point of origin based on forensic clues, typically indicating where the fire was hottest. Sometimes the way a fire burns indicates what type of accelerant, if any, was used, which may point to arson. If the origin was the cam tower, and no other likely causes in that immediate area, it'd be the obvious conclusion.
    Mwray8909, BTBAKER and equin like this.
  9. Feb 22, 2019 at 4:42 PM
    koditten
    Kirk
    Midland of the Mitten
    Sorry about the truck.
    Color me sceptical.
    Let the inspector call it an oil leak fire if you want, but I find it difficult to buy.
    Sorry to be that guy.
  10. Feb 22, 2019 at 4:46 PM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Man that is sickening, glad no one got hurt.
  11. Feb 22, 2019 at 4:56 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Welcome, I question first posts like this, but....
    I worry about the oil leaking directly on the header. Toyota should too.
    I'll use my used motor oil to get a fire going in the backyard on occasion, usually home late and want to hang out outside. I will also pour some on some hot coals to get it going again after I add some more wood. It'll fire right up within 3 seconds. I like using used oil because it's predictable and burns for a few minutes to catch the wood.
    Petroleum and chemicals are unpredictable. I'm sure a chemical engineer will beat me up over flash points and volatility. But I've seen JP8, oil, gasoline, and kerosene do things that shouldn't have happened.
    NewImprovedRon and Sunnier like this.
  12. Feb 22, 2019 at 5:07 PM
    Glad to hear nobody was hurt or the house didn't catch fire.
    Welcome from NY.
  13. Feb 22, 2019 at 5:24 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    Man that thing sure went up. Glad no one was hurt. Can you post up the findings from the fire people? That would be interesting to read, and nice to be able to forward.
  14. Feb 22, 2019 at 5:38 PM
    War Machine
    War Machine SSEM # 5 3MW
    Did you not read the label?
    landphil, Watt maker and RangerBP like this.
  15. Feb 22, 2019 at 5:39 PM
    kazbeh
    kazbeh [OP] New Member
    2011 Tundra , 2014 Tundra
    Wheels and tires, Subs, fender chrome
    That was a small kitchen fire extinguisher. I had a larger one and the handle broke off! They wouldn't specify cam tower leak just small leak on exhaust manifold. But from the looks of it I don't know how they could make anything out. But I had talked with a Honda specialist on fires (that's his position with Honda) and it's crazy but they can figure out the smallest of details in order to go to court with proof of what started the fire.
    equin likes this.
  16. Feb 22, 2019 at 5:42 PM
    kazbeh
    I'm still waiting on the final report to be sent to me but that's a great idea to post for all to see. Hint, Hint TOYOTA!!!!!
  17. Feb 22, 2019 at 5:59 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Oh, I must have misunderstood the first post. For some reason I thought there was an official finding that it was a cam tower leak that caused it. I can see circumstantial evidence to infer that, though, if they found it was a small leak on the exhaust manifold. But I’m guessing maybe a valve cover leak could also be a possibility?
    Rex Kramer likes this.
  18. Feb 22, 2019 at 6:17 PM
    kazbeh
    Yes your right it could have been a valve cover leak. But in any case Progressive said they couldn't go after Toyota due to the age and miles. I must say though this makes me a nervous wreck with my 2014 possibly doing the same thing. I went to YouTube and seen the fix and it's a doozie! But I'm betting it will leak all over again.
    woodcan likes this.
  19. Feb 22, 2019 at 6:24 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    How many miles did the truck have?
  20. Feb 22, 2019 at 6:32 PM
    #50
    RonW
    RonW New Member
    Is this the first fire ever attributed to a small cam leak?
    Like I know you can never predict what fire will do once it starts, but it seems like there isnt anything to burn right there. Like if you took a cup of oil and set it on fire right there what would it burn? Gas, wires...just wondering. Seems like it would smolder off as it dropped down unless it was a big leak.
    Flash point of oil is like 450. And I know exhaust gets way hotter than that.
    I guess what I'm thinking is that this type of thing should be happening all the time given how many cam leaks there are.
    ColoradoTJ and OBXTundra like this.
  21. Feb 22, 2019 at 7:05 PM
    #51
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    8AE29256-7D78-4572-BC78-11A76C622802.jpg 2EB42779-40B1-43F2-8335-638D760DF203.jpg So sorry to hear glad everyone is safe and ok just got my back last Friday night they had it for 8 days doing both sides it was leaking onto the exhaust headers they had my whole engine tore apart. C535748D-EE43-429A-BD90-96D0EA7598C4.jpg
  22. Feb 22, 2019 at 7:08 PM
    #52
    kazbeh
    The truck had 74,000 miles on it. I have seen three fires on the net exactly like mine when I was searching. And all of them said the same thing, Leaking oil on the exhaust manifolds! If I had to guess I'm kind of thinking the spark plug wires would light up first then any wires/insulation etc?
    equin likes this.
  23. Feb 22, 2019 at 7:10 PM
    #53
    15whtrd
    15whtrd Mr. Blonde
    Has me thinking about mounting my fire extinguisher permanently. I only bring it when I go trailing.
    ColoradoTJ and Rex Kramer like this.
  24. Feb 22, 2019 at 7:14 PM
    #54
    Trooper2
    JR
    Houston, TX (Suburban South)
    I have some doubts as well..........
    Mediumrarepls and Krezz like this.
  25. Feb 22, 2019 at 7:20 PM
    #55
    Trooper2
    JR
    Curious, How long had the truck been running before the fire was detected? Cold or warm start?
    RonW likes this.
  26. Feb 22, 2019 at 7:34 PM
    #56
    kazbeh
    Cold start and ran for 10 minutes to melt the ice off the windshield (for my wife to drive) then shut off. I left for work in my Seqouia. The roads where to icy so I drove around another way back to my house and saw fire coming from under the windshield when I pulled up. I was gone about 7 to 10 minutes.
    equin likes this.
  27. Feb 22, 2019 at 7:42 PM
    #57
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yeah that's how it's supposed to work, but I don't think the OP has conclusive proof yet.
    Patriot likes this.
  28. Feb 22, 2019 at 7:45 PM
    #58
    TheBeast
    TheBeast The Beach
    feel like I read that story before. did you post it on other forums few weeks ago ?
  29. Feb 22, 2019 at 7:48 PM
    #59
    kazbeh
    No I've never been on a Tundra forum before. Wonder if that might be one of the others I saw when looking for fires?
    NewImprovedRon likes this.
  30. Feb 22, 2019 at 7:49 PM
    #60
    kazbeh
    But my wife may have said something to our friends a few months ago on Facebook.
