  1. Feb 20, 2019 at 12:34 PM
    #4321
    I've been studying these pics. You've got me wanting to hop on the D.D train as well. Just so I'm clear, the fuel rails(in blue below) have to be completely removed right? Seems like a hot of hoses in the way on the driver side.
  2. Feb 20, 2019 at 1:08 PM
    #4322
    Professional Hand Model
    Fred
    Hand Protectors
    The rail(s) does come out only AFTER the injectors are pulled off. I removed them to examine and oil and fit each injector in to make sure of proper fitment, then removed them and re-installed the rail and while holding the rail elevated inserted the injectors one at a time carefully. This is where the hand yoga takes place.
    Once all the injectors are in place, then the slow and precise drop down into the manifold holes making sure things line up before pushing down hard into place and screwing down the 10mm bolts.
    To your point about the hoses, it would be difficult to explain but once the job gets underway you’ll understand where to peel them back and whats the best temporary stationing area for each.
  3. Feb 20, 2019 at 1:12 PM
    #4323
    Fred
    Hand Protectors
    Yeah buddy. Delivery.
    Probs won’t install till the weekend as the rain has set in.
    Filthyphil and bmf4069 like this.
  4. Feb 20, 2019 at 1:51 PM
    #4324
    Fred
    Hand Protectors
    Yeah buddy. New Headlight/Side marker assys also came today. They sent an entire package of assys to redo the whole front lights when I only needed one replacement side marker that leaked.
    This means I have a free refresher back-up set to install in 4-5 more years.
  5. Feb 20, 2019 at 2:45 PM
    #4325
    Outbound
    Aaron
    Northern Alberta
    I need new headlight assemblies *hint hint* :D
  6. Feb 20, 2019 at 2:57 PM
    #4326
    Fred
    Hand Protectors
    There is a way around this Canada tax law. I read the law a few months ago and you can recieve gifts from out of country to skirt the tax code. Shipped right to your door. Only thing is: You have to trust the person sending your gift with your money first.
    Outbound[QUOTED] and Sunnier like this.
  7. Feb 20, 2019 at 4:04 PM
    #4327
    Outbound
    Aaron
    Northern Alberta
    The taxes arent really an issue for me. Duty and tax on the SEMA wheels I got was $80 ish and I still saved hundreds even after exchange vs buying in Canada.
    My issue is most US retailers wont ship to Canada or have outrageous shipping prices. I generally have to wait for the one time I year I go back to my hometown which is on the border. I have stuff shipped to Sumas, Wash and go pick it up then.
    Living 12+ hours one way from the border sucks sometimes.
  8. Feb 20, 2019 at 4:35 PM
    #4328
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
  9. Feb 20, 2019 at 6:26 PM
    #4329
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wellll. Pulled the door panel
    Off on the driver side to see why the window won’t roll down all the way.
    Seems the door has sustained damage a while ago. The inside of the door is bent up and be window track is broken clean off the door skin, sooo now I’ll be looking for a used door. (New is like 700 bucks for me... no thank you)
  10. Feb 20, 2019 at 8:59 PM
    #4330
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
  11. Feb 20, 2019 at 9:37 PM
    #4331
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Had a dream that my gas tank was empty after driving 70 miles.
    Glad it was still 3/4 when I hopped in to drive to work. :D
  12. Feb 20, 2019 at 10:54 PM
    #4332
    because_wumbo-truck
    Jon
    Houston, Texas
    You do over nights as well?
    Brown Bear likes this.
  13. Feb 20, 2019 at 11:04 PM
    #4333
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not anymore, happened this morning but I forgot lol
  14. Feb 21, 2019 at 4:19 AM
    #4334
    Fred
    Hand Protectors
    Taking a trip in a 2018 Tundra today. I’ll report back on any interior squeaks/noises and technology complaints. He is already asking me about a red rear swaybar.
    because_wumbo-truck likes this.
  15. Feb 21, 2019 at 5:22 AM
    #4335
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Not covered in ice - must be a photoshop. ;-)
    Tundra got me home fine. Got me up the driveway fine. I got out & fell down on the ice trying to stand up the wiper arms.
    I wonder if Falken makes winter boots. Sheeesh. Ice, ice, ice everywhere - oh & more ice.
    bmf4069, Darkness, Outbound and 2 others like this.
  16. Feb 21, 2019 at 5:44 AM
    #4336
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Sorry to bring it back to pink milkshake, but there were a few misconceptions from people.
    The pink milkshake is caused by the radiator leaking internally, not the external trans cooler on tow package trucks. Replace the radiator and problem solved.
    When the truck is cold and not runnng, coolant leaks into the trans, overfilling it. When the truck heats up and is running, the pressure from the transmission pump pushes atf into the cooling system.
    When this happens, if caught early enough, you can save your trans. It happened to my dad’s 02 a few years ago, and we got lucky. Flushed 5 gallons of atf through the trans, flushed the cooling system, replaced the radiator, and we were good to go.
    the red, speedtre, Filthyphil and 2 others like this.
  17. Feb 21, 2019 at 5:56 AM
    #4337
    because_wumbo-truck
    Jon
    Houston, Texas
    Ice isn't typically an issue in South East Texas. Lol
    NUDRAT[QUOTED] likes this.
  18. Feb 21, 2019 at 6:00 AM
    #4338
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Then how do you get away w/ doing donuts in the parking lot at work? :rofl:
    Darkness likes this.
  19. Feb 21, 2019 at 7:41 AM
    #4339
    lsaami
    lsaami Let ‘er buck
    Minnesota
    new rear tires every 1500 miles. ;)
  20. Feb 21, 2019 at 9:55 PM
    #4340
    empty_lord
    05 rollover special
    Slowly getting my garage ready for the tundra to have the bed removed... my freebie 4runner has be be stripped clean first though...
    (Anyone know what’ll swap into a 1st gen tundra from these?)
  21. Feb 21, 2019 at 10:27 PM
    #4341
    because_wumbo-truck
    Jon
    Houston, Texas
    Engine, trans, front suspensions. That's all I know
  22. Feb 21, 2019 at 10:33 PM
    #4342
    Casper421
    In the woods
    06 DC
    What year 3rd gen?
  23. Feb 21, 2019 at 10:35 PM
    #4343
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    Revived my faided paint and fixed my chrome trim. Turned out especially well with the paint in my mind it use to look matte.
    A lot of elbow grease and time can make a big difference.
    potoghi, Brown Bear, abcinv and 5 others like this.
  24. Feb 21, 2019 at 10:35 PM
    #4344
    Sunnier
    Sunny
    San Diego, CA
    @BestGen
  25. Feb 21, 2019 at 10:38 PM
    #4345
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Jon got it.
  26. Feb 21, 2019 at 11:26 PM
    #4346
    empty_lord
    05 rollover special
    97
  27. Feb 22, 2019 at 3:18 AM
    #4347
    What did you use on the chrome trim? It looks new again! I haven't been successful in reviving mine.
  28. Feb 22, 2019 at 5:05 AM
    #4348
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Wow, good work.
    What did you do w/ the chrome insert on the trim strip?
    Don't forget the mudflaps! LOL.
    Nice job. Nice truck in my favorite color.
  29. Feb 22, 2019 at 5:08 AM
    #4349
    Fred
    Hand Protectors
    That is good work right there.
  30. Feb 22, 2019 at 5:10 AM
    #4350
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I don't know, but I'd think a bunch of interior parts would. Seats, seat belts, bulbs, something like a courtesy light in the ceiling or door....
