Running rough at idle - 2003 V6 3.4 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra03, Jan 16, 2019.
  1. Jan 16, 2019 at 9:08 AM
    Tundra03
    Tundra03 [OP] New Member
    Peter
    2003 Tundra White
    Hi Folks,
    First time post here. 2003 V6 3.4 Tundra is the rig.
    Original issue: Started running rough, check engine light came on. I took it to my shop and they diagnosed valve cover gasket leak (causing it to misfire). Ran my OBD scanner and found the P0306 error code.
    Fix: I replaced valve cover gasket, o rings, spark plugs, plug wires and ignition coils (w/ NGK). I originally replaced only the 5/6 cylinder coil (cheap bastard) but still had the error code. I moved the new coil down to the 3/4 cylinder to see if the error code followed the coil or remained for 6. It stayed at 6. I put in two more new coils so I had all new coils (V6 3.4 has only 3)
    Currently, check engine light is gone and no trouble code however it still feels like it is running rough and misfiring. When I fire it up initially a little rough but smoothes out for idling. After driving around it usually is intermittently rough at stop signs etc.
    Any thoughts on what may still be going on / how to get it back to that sweet purring state.
    Thanks guys
  2. Jan 16, 2019 at 10:53 AM
    Eugene406
    Eugene406 New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    Hey Bud,
    I had the same issue on my '99 4Runner (same engine), turned out to be an injector issue. I decided to replace all of the injectors and sure enough, it fixed the issue. The procedure is pretty easy, I was able to do it outside in Montana winter. There are plenty of youtube videos showing you how to go about replacing the injectors and if you are looking to save some money you could just replace cylinder six.
    Let us know how it goes,
  3. Jan 16, 2019 at 1:50 PM
    I don't know as much about the 3.4L but the common advice here is that it's a good idea to clean the MAF sensor and replace the PCV valve. You've already done a lot of the things that I can think of. You could try cleaning the throttle body as well. Try these things and let us know if you are still having issues.
    YotaManSD11 likes this.
  4. Jan 18, 2019 at 2:14 PM
    Tundra03
    Peter
    2003 Tundra White
    Thanks guys, great insight. I just ordered a set of refurbished denso injectors to switch out and hopefully that cleans it up. I'll check out the situation situation with MAF and PCV valve as well.
    Thanks again! Will post update when I get to changing out the injectors.
  5. Feb 16, 2019 at 7:04 PM
    Tundra03
    Peter
    2003 Tundra White
    Hey guys,
    Posting a quick update - New injectors in took care of misfire and rough running issue. However, a new problem has come up where it is not starting properly. It sputters to life only when I give it some gas, but runs great going down the road. Making a new post on the forum.
    NewImprovedRon likes this.
  6. Feb 16, 2019 at 7:19 PM
    Eugene406
    Montana
    Bone Stock.
    Glad to hear you were able to resolve the misfire. After you get it started does it idle fine?
  7. Feb 16, 2019 at 7:32 PM
    Tundra03
    Peter
    2003 Tundra White
    Yeah it idles great (for the most part) and goes down the road fine pretty much just the initial fire up (even if i start, let run for a few minutes and then restart).
  8. Feb 17, 2019 at 4:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Your new rebuilt injectors the proper part#?
  9. Feb 17, 2019 at 11:27 AM
    Eugene406
    Montana
    Bone Stock.
    I too have encountered this problem on that engine. Try cleaning your IAC valve (Idle Air Control).
  10. Feb 21, 2019 at 5:53 PM
    Tundra03
    Peter
    2003 Tundra White
    From what I've read and encountered I don't think my throttle body has an IAC valve (or at least one like the previous 3.4 versions). I've attached some pictures for reference. I was planning on cleaning it when I pulled the throttle body off but was somewhat surprised by what I found.
  11. Feb 21, 2019 at 6:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You’re correct. No IAC on a “drive-by-wire” throttle body.
    I responded in your other thread.
  12. Feb 21, 2019 at 6:18 PM
    Eugene406
    Montana
    Bone Stock.
    I stand corrected. I assumed your 3.4L was the same as others I have worked on in 3rd gen 4Runners.
    landphil[QUOTED] likes this.
  13. Feb 21, 2019 at 7:02 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Hey, I would have thought the same until he posted the pic of the servo controlled throttle body. :thumbsup:
