2005 Tundra starting issues
Discussion in '1st Gen Tundras (2000-2006)' started by gsalazar, Feb 21, 2019.
  1. Feb 21, 2019 at 3:21 PM
    gsalazar
    gsalazar [OP] New Member
    Gilbert
    2005 Toyota Tundra 4X4
    Strange issue. Truck has been running great until yesterday. Drove to a jobsite and when leaving truck would not start. It turns over coughs and sputters but does not start. Spark not getting to the driver side bank of cylinders (odd side). Towed the truck home, wrecker dropped it off, and it started right up. Turned it off tried to restart it, no go. Replaced the crank sensor based on the computer readout. Still nothing. Removed a coil from the drivers side, grounded it to see if it would spark, and the truck started right up on 7 cylinders. Happened again today, did the same trick grounding a coil and started again. Could it be the cam sensor on that side of the engine. Anyone else ever experience this. Any help would greatly appreciated.
