Gun rack
Discussion in 'Guns & Hunting' started by Nodlenor, Sep 8, 2016.
  1. Sep 8, 2016 at 12:48 PM
    Nodlenor
    Nodlenor [OP] New Member
    Ronald
    2010 Black Tundra TRD SR5
    I'd like to see what kind of gun racks you use in your Tundras.
  2. Sep 8, 2016 at 1:04 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Bought this a few years ago at Cabelas. They call it a Hunters Tackleback.
    aperezsh, ColoradoTJ and Mountun Goat like this.
  3. Sep 8, 2016 at 1:08 PM
    Nodlenor
    Ronald
    I just ordered one like that. Didn't know if I should have waited. How do you like it?
  4. Sep 8, 2016 at 1:12 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    It's been a pretty good little holder, especially for $18.
  5. Sep 8, 2016 at 1:26 PM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    People would lose their minds if we ran around with a gun in a rack here in Connecticut.
  6. Sep 8, 2016 at 1:29 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Oh there are parts of Colorado where that's the case. Fortunately I live in the non-retarded part of the state.
    ColoradoTJ, TheBeast, DeanO and 3 others like this.
  7. Sep 8, 2016 at 1:35 PM
    TRDFaux
    unfortunately that part of CT doesn't exist. If my shirt lifts at the grocery store and someone thinks they maybe, might have, possibly, perhaps, conceivably seen a gun they call the cops.
  8. Sep 8, 2016 at 1:37 PM
    Nodlenor
    Ronald
    I live out in the middle of nowhere here in Missouri and it is very common to have guns in your truck.
  9. Sep 8, 2016 at 1:40 PM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    There's some Rural areas here where people still ride around with the old school back window rack.
    *** Florida
    Rex Kramer and Ancient1 like this.
  10. Sep 8, 2016 at 2:17 PM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    If you have a DC, the Du-Ha underseat storage w/ gun racks works pretty good.
    equin and buckeyes1975 like this.
  11. Sep 8, 2016 at 2:18 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Well for you people that do not have retards in your state, you are lucky. because we must have most of them here in massachusetts..
  12. Sep 8, 2016 at 3:34 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Not quite a rack but this is my in bed "tool box". Holds three shotguns in padded cases.
  13. Sep 8, 2016 at 4:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That's bad ass. Is it welded to the bed?
  14. Sep 8, 2016 at 4:22 PM
    pbryant44
    pbryant44 New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    In Maine you didn't need a gun rack just put it beside you with ammo on the center console and open carry was almost mandatory.
    aperezsh and zcarpenter92 like this.
  15. Sep 8, 2016 at 5:29 PM
    Over the LINE
    New Orleans
    It is bolted in. I removed the bed track and bolted it across the top with the bed track bolts, they were plenty long enough. At the tailgate bottom I drilled and through bolted. It is easy to get to the back side from underneath. The front bottom I was going to bolt using the bed tie down hole but it did not quite work out. So far I am not missing the front bolt.
    aperezsh likes this.
  16. Sep 8, 2016 at 8:26 PM
    Nodlenor
    Ronald
    Mike, I have a DC and I looked at the Du-Ha. I might invest in one of those later. I like the fact that they are out of sight.
  17. Sep 8, 2016 at 8:29 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Couldn't resist.
    HbbTundra08 and Mountun Goat like this.
  18. Apr 19, 2019 at 5:31 AM
    Ironjaw
    Ironjaw Taxation is theft
    Kurtis
    Pendleton IN
    '19 Quicksand Tundra TRD
    Anybody have any racks that go overhead?
    If so, pics, and manufacturer?
    Rex Kramer likes this.
  19. Apr 19, 2019 at 5:38 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I dont think it would be appropriate to show pics of that..;)
  20. Apr 19, 2019 at 8:30 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Very nice gun rack.
    I'm also curious how you mounted your Hi-Lift.
    I never thought to mount it where you have yours.
    I looked at some mounts on the internet, but it is a bit overwhelming.
    What type of mounts did you use?
    Thanks.
  21. Apr 19, 2019 at 1:21 PM
    Over the LINE
    New Orleans
    I used T-slot nuts in the bed track, eye bolts and washers. My build thread link in my signature has some other pictures. If you can't see what you need, I can take a few more pictures next week.
  22. Apr 19, 2019 at 2:32 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    Perfect, thanks so much.
  23. Apr 19, 2019 at 2:35 PM
    saybng
    Gary
    Ventura CA
    @Over the LINE ,is your side mount case diy?.. I'm really liking that..
  24. Apr 20, 2019 at 12:21 PM
    Over the LINE
    New Orleans
    It's DIY in that I designed it, had a fabricator make it, painted it with rattle can touch up paint and mounted it. I actually had it made for the Nissan Titan I had before this truck and had it modified a little to fit this one. It could have been a little taller for the Tundra but I don't know that height will make any difference for shotguns or number of shotguns.
    saybng[QUOTED] likes this.
  25. Apr 20, 2019 at 12:23 PM
    Over the LINE
    New Orleans
    Something I forgot to mention is that my box is carrying some of the jack weight. Not sure if it makes any difference, just thought I would mention it.
  26. May 5, 2019 at 11:11 PM
    ertlonggun
    ertlonggun New Member
    2013 Dbl cab grey TRD
    TRD air filter TRD air flow accelerator Dirty Deeds budget SS Exhaust Worx wheels Roadmaster active suspension (rear) P-3 brake controller 3” Toyotec lift w/ shackles 35” Nitto Ridge Grapplers
    I made this rifle caddy for when I go to central Oregon sage rat hunting. It holds 6 rifles, and sits high enough to lay several underneath. I may have a problem!
    midnightyota12, equin and aperezsh like this.
