SPC UCA initial caster setting
Discussion in 'Suspension' started by niscur38, Feb 14, 2019.
  1. Feb 14, 2019 at 4:23 AM
    niscur38
    niscur38 [OP] New Member
    Getting ready to install my lift this weekend and have been reading about alignments post lift and the possibility of UCA's needed to get everything back to stock specs and have better road manners. Rather then have to take everything back apart again to add arms I decided to get the SPC UCA's off Amazon but am undecided on whether to install them on the C or D setting.
    All the alignment specs I could find on the forum for 3" lifts show the caster as being at or a little under 1* but for simplicity lets call it 1* on average. However the D setting on the UCA only adds 1* of caster and if adding to the "average" after the lift this would only get up to around 2*.
    So my gut tells me to set it in the C setting which would hopefully get closer to 3* overall. I'm trying to be a little proactive and set it before taking it in vice relying on the shop to make the adjustments etc. Thoughts?
    For reference I'll be running:
    FBG Coils @ 3" of lift
    2" Blocks with Zone Shocks
    35x11.5x20
    20x9 +18 wheels
    2019 Truck
  2. Feb 14, 2019 at 6:31 AM
    neirbot
    neirbot New Member
    I was told to start at the D setting, but I'm only lifting 2.4"
  3. Feb 14, 2019 at 3:11 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m at 4” in front and I believe mine are set to D as well.
  4. Feb 17, 2019 at 4:28 AM
    niscur38
    Well I just wrapped up the fronts yesterday....Went with the D setting. Have to say the install on these were rather simple overall.
    Black Wolf likes this.
  5. Feb 17, 2019 at 4:39 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Make sure you bring it to a shop that is truly knowledgeable to get your alignment. First place fucked mine up after my lift. I had to bring it to a local 4wd shop who then sent me to a place that does nothing but chassis and suspension work. They got my alignment so damn good the truck drives and tracks straight better than it did stock
    revtune and Black Wolf like this.
  6. Feb 17, 2019 at 5:30 AM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    I'm in the same boat, report back what setting they ended up and the alignment spec they were able to achieve. Would be much appreciated. Good luck!
  7. Feb 18, 2019 at 1:47 PM
    niscur38
    Here's the results of the alignment at the dealer. After 4.5 hours getting the TPMS swapped/wheels&tires mounted/alignment I was just happy everything was in the green. I dunno if the C setting would have been better being at the higher end of the range. Honestly it doesn't look like they did much except correct toe.
  8. Feb 18, 2019 at 2:32 PM
    conlons26
    Raleighwood, NC
    They should be able to do much better with the camber.
  9. Feb 18, 2019 at 2:44 PM
    Danman34
    Danman34 New Member
    Danny
    Too much negative camber. Inside of your tires will start wearing pretty quick like that Total toe should be around .15.
  10. Feb 18, 2019 at 3:25 PM
    neirbot
    neirbot New Member
    I just got back from the shop that did my alignment and here are the numbers they got. Needless to say I'm thrilled with the results, which are exactly what I requested.
    I'm at 2.5" lift (6112's) with SPC uppers. I installed them at setting D with the ball joints at the most outer camber position. The shop didn't move them from those settings at all
  11. Feb 18, 2019 at 4:09 PM
    conlons26
    Raleighwood, NC
    That's looks great!
  12. Feb 18, 2019 at 4:09 PM
    Danman34
    Danman34 New Member
    Danny
    Too much toe. Your tires will be fighting each other. Everything else looks good.
  13. Feb 18, 2019 at 4:22 PM
    neirbot
    neirbot New Member
