What jack are you bringing?
Discussion in 'Recovery & Gear' started by SpeshulED, Feb 18, 2019.
  1. Feb 18, 2019 at 9:30 AM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    so I’m torn between buying a hi-lift jack or a 1.5 ton aluminum jack and mounting it in the bed.
    My only concern with the hi-lift is that I don’t have sliders so lifting points are minimal.
    BestGen likes this.
  2. Feb 18, 2019 at 9:59 AM
    15whtrd
    15whtrd Mr. Blonde
    I think you would have to get and adapter to hook onto the rim but you couldn’t change a tire that way LOL might be able to lift it up by the trailer hitch but that seems inefficient. Might be somewhat useful in recovery but pretty useless if you don’t have sliders or heavy duty bumpers. Which is why I haven’t gotten one yet.
  3. Feb 18, 2019 at 10:19 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Practice using the Hi-Lift before hand. If you don't know what you're doing they can be dangerous.
    OR18TRD, joonbug, Bprose and 5 others like this.
  4. Feb 19, 2019 at 1:43 AM
    SpeshulED
    Thank you for the input. I may just go with a HF 1.5 ton jack and mount it in the bed
    ColoradoTJ, BestGen and Watt maker like this.
  5. Mar 5, 2019 at 4:02 PM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    I'm surprise nobody is rocking the pro eagle jack :muscleflexing:
  6. Mar 5, 2019 at 5:04 PM
    Sunnier
    Sunny
    San Diego, CA
    Why you say?
  7. Mar 5, 2019 at 5:10 PM
    Yotatundraaah
    Southern CA
    I've heard alot of off roaders talking about hi-lift jack but never about pro eagles. I was just curious since it is kinda dangerous using those jacks.
  8. Mar 5, 2019 at 5:13 PM
    Casper421
    In the woods
    06 DC
    Price point might be a reason. Hi-lift is proven, cheap and multifunction.
  9. Mar 5, 2019 at 5:14 PM
    Outbound
    Aaron
    Northern Alberta
    I've love one even just for at home, but they're a little out of my budget. I also don't offroad hard enough to need a full size jack. I won't be doing much other than changing a tire off road. A 5 ton bottle jack and wood blocks does the trick for me.
  10. Mar 5, 2019 at 6:07 PM
    TheBeast
    TheBeast The Beach
    I use this one:
    Powerbuilt 3 Ton All in One Bottle Jack and Jack Stand - 640912
    found on Amazon.
    OR18TRD and SpeshulED[OP] like this.
  11. Mar 6, 2019 at 9:06 AM
    BestGen
    BestGen New Member
    Paul
    A good, cheap alternative is a scissor jack. I got one from a yard sale for $10 bucks. It was from a 69 Cadillac so you know it was beefy! :benchpress:
    Luckydog, 15whtrd and Casper421 like this.
  12. Mar 9, 2019 at 11:47 AM
    BestGen
    BestGen New Member
    Paul
  13. Mar 9, 2019 at 11:52 AM
    BestGen
    BestGen New Member
    Paul
    I would love a Pro Eagle! A bit pricey but 4WP has em cheaper than anywhere else.
    Casper421 and Sunnier like this.
  14. Mar 9, 2019 at 12:19 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    I just got this bad boy!!!!
  15. May 18, 2019 at 9:34 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    With the hi-lift mate you can lift the truck up by the wheel, block the truck with your stand, remove the hi-lift jack and mate, and then work on your tire, right?
    You can also invest in some limited recovery equipment and it functions as a limited winch until we can upgrade bumpers and get real winches. ;)
    Smiley, 15whtrd[QUOTED] and Casper421 like this.
  16. May 19, 2019 at 12:37 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    Daniels...duh...:facepalm:
