Anyone have a honeycomb TRD Sport grille?
Discussion in '2.5 Gen Tundras (2014-2021)' started by meller215, Feb 15, 2019.
  1. Feb 15, 2019 at 6:19 PM
    meller215
    meller215 [OP] New Member
    I'm looking to upgrade my 2016 SR5 to the new(ish) honeycomb grille insert to replace the original chrome slatted grille. If I get the grille insert is it an easy install? Also, what years would fit my 2016?
    Does anyone have this insert for sale or know where I can find one? Thanks in advance!
  2. Feb 15, 2019 at 7:09 PM
    Welcome from NY.
    Where are you from?
    @Roman is our parts guy.
    Roman likes this.
  3. Feb 15, 2019 at 7:19 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
  4. Feb 15, 2019 at 7:35 PM
    meller215
    Northwestern PA
    Thank you!
  5. Feb 18, 2019 at 7:33 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. Feb 18, 2019 at 9:02 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    2016. Very easy to change. Get from Roman.
    Before:
    After:
    Roman likes this.
  7. Feb 18, 2019 at 9:15 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Just did mine over the weekend... The whole grill replacement is easier than just the insert. If you do the insert, be really carful when messing with the tabs. There are 4 screws and about 8-10 tabs that hold the insert to the surround. The insert is an absolute pain in the ass to get separated from the shell and if you don't have patience, you'll break all the tabs and the surround will not hold. So take your time with it and you'll be good. You'll definitely love the look!
