Tires
Discussion in 'Wheels & Tires' started by 19Tundra4x4, Feb 9, 2019.
  1. Feb 9, 2019 at 1:31 PM
    19Tundra4x4
    19Tundra4x4 [OP] New Member
    2019 Cavalry Tundra
    ARE cap
    Read through many threads and came across one where someone put 305/55/R20 on stock wheels. No rubbing or cutting. Is that correct? New to forum
  2. Feb 9, 2019 at 2:09 PM
    Can't answer your question but Welcome from Ohio.
  3. Feb 10, 2019 at 3:35 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If you read it on here then someone probably did do it. People doing all kinds of stuff, doesn't mean it's ok though.
    Welcome from Sin City
  4. Feb 13, 2019 at 3:55 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Welcome from KC, MO that is. I know your struggle. I read countless threads on here about tire fitment before getting mine. Bottom line is every truck is different, and there are so many factors involved that affect what works and what doesn't for all of them, it's not safe to make a general statement on the subject, especially when you're talking an otherwise stock setup. If you were lifted 6", then you could make some assumptions lol. That said, the best you can do is learn the differences between your current and planned tire sizes, check your existing clearances with your tires turned at all angles, and look up the actual dimensions of the tire you want directly on the manufacturer's website. Then, divide equally on both sides of the wheel, the differences in diameter and width between tire sizes and subtract those numbers from your existing clearances. It's a lot of math, but it'll settle your mind a lot more than making assumption about what worked for others.
    ... Or, if you happen to have a friend with a tundra who has the setup you're after, you could always see if he/she would do a test swap for you. :p
  5. Feb 18, 2019 at 8:23 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
