  1. Feb 17, 2019 at 9:06 PM
    #4231
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    You use the regular or synthetic?
  2. Feb 17, 2019 at 9:08 PM
    #4232
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Regular one. Kazuma LSD doesn't like synthetic fluids.
  3. Feb 17, 2019 at 9:42 PM
    #4233
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    is the factory LSD a kazuma unit? i want to do all the fluids in the truck.. diffs being the biggest one (diff was replaced at 67k but its at 190k now.. sooo probably due)
    if so what recommended? i usually run mobil gear oil in my taco and other taco...
  4. Feb 17, 2019 at 9:50 PM
    #4234
    empty_lord
    05 rollover special
  5. Feb 17, 2019 at 11:30 PM
    #4235
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Can we revisit the LSD discussion once again? What are the two mechanical brands that our trucks have and how do we find out which we have/what fluid to use?
  6. Feb 18, 2019 at 4:07 AM
    #4236
    Professional Hand Model
    Fred
    Hand Protectors
    2002 4x4 Tundra SR5 with true LSD (Kazuma by Eaton) use:
    Lucas Heavy Duty for LS 80-90w (dino) in the rear diff (trust me on this)
    Mobil1 75-90w Synthetic for LS works fine in the transfer case and front diff
    because_wumbo-truck likes this.
  7. Feb 18, 2019 at 4:14 AM
    #4237
    Fred
    Hand Protectors
    Let us know when you find out. My grease gun does all 6 zerks on the rear prop, but doesn’t fit the two on the front 4x4 prop.
  8. Feb 18, 2019 at 4:44 AM
    #4238
    because_wumbo-truck
    Jon
    Houston, Texas
    I need to crawl under and grease all mine probably
  9. Feb 18, 2019 at 6:25 AM
    #4239
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Feb 18, 2019 at 8:09 AM
    #4240
    Just to muddy the water. I used Royal Purple 75W90 full synthetic all the way around without issue. I also have the LSD in my 02. I got the idea from the old Tundra forum. Many others reported using the same thing.
  11. Feb 18, 2019 at 8:21 AM
    #4241
    Fred
    Hand Protectors
    The rear diff on ours is spec’d at straight 90w, but its not available anywhere.
    The stealer uses 75w-90. If it works then thats good!
  12. Feb 18, 2019 at 9:00 AM
    #4242
    because_wumbo-truck
    Jon
    Houston, Texas
    :woot:
  13. Feb 18, 2019 at 9:12 AM
    #4243
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Is the tip on your gun adjustable? The one on my Lincoln can be twisted to make a tighter fit.
  14. Feb 18, 2019 at 9:21 AM
    #4244
    Fred
    Hand Protectors
    Yes. Its adjustable. The problem is the tip is too big, or the angle of attack wrong, on the front two zerks.
    It also looks like those u-joints are different on the front prop (though they are Koyo like the rears). Its like its a whole different animal and I justify by waiting in greasing them due to not much use on the 4x4.
    I’d be nice to know exactly what tip to buy as I’d buy it fast. Just don’t feel like experimenting on this.
  15. Feb 18, 2019 at 12:12 PM
    #4245
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Alignment is done. The alignment tech noticed my ABS light was on and saw the sensor on the passenger side wasn't bolted down all the way. Problem solved.
    Might find the time today to put my skidplate back on, but I now have a better-than-ever driveable truck again.
    :benchpress:
    Sunnier, Rheywood456, the red and 5 others like this.
  16. Feb 18, 2019 at 12:14 PM
    #4246
    I had dinner with some friends last night. A guy joined that I had never met before and it turns out he is an engineer for Denso. Specifically, his plant makes alternators and starters. I made a comment about Denso making good products and he didn't waste any time telling me that Denso's quality isn't nearly as good as people perceive it to be. He really didn't have anything positive to say.
    This didn't instill confidence as I'm about to order a replacement Denso radiator....:rolleyes:
    MyFj08, Sangre Kid, Darkness and 2 others like this.
  17. Feb 18, 2019 at 12:15 PM
    #4247
    Fred
    Hand Protectors
    Nice! Can you notice the difference with your new wheel bearings? Were they making noise before?
  18. Feb 18, 2019 at 12:18 PM
    #4248
    Fred
    Hand Protectors
    Let me go look at my radiator and snap a pic because you asked about that a few weeks ago. Its been about 4 years since install and my mechanics said this was a good one and half price of Denso? Foggy memory.
    Filthyphil likes this.
  19. Feb 18, 2019 at 12:19 PM
    #4249
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I bought a replacement radiator at advanced Auto with a lifetime warranty
  20. Feb 18, 2019 at 12:20 PM
    #4250
    Fred
    Hand Protectors
    Wow. Free for life! Amazing.
  21. Feb 18, 2019 at 12:30 PM
    #4251
    Fred
    Hand Protectors
    Cryomax Radiators.
  22. Feb 18, 2019 at 3:17 PM
    #4252
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Night and day. Even the wife noticed "hey that grinding sound is gone".
    The truck still seems to be "figuring itself out" since all I have done is cruise around town slowly. I need to get some freeway miles on it and get the SG2 calibrated now.
  23. Feb 18, 2019 at 4:14 PM
    #4253
    because_wumbo-truck
    Jon
    Houston, Texas
    I've owned my tundra for 6 months now and I still haven't programed the ATF° xgauge lol I don't even remember how to edit xgauges. I did em in my taco back in the day
  24. Feb 18, 2019 at 6:36 PM
    #4254
    empty_lord
    05 rollover special
    so are there any frame reinforcement plates for the tundras. pretty sure im going to have to pull the rear of the frame straight... would like to reinforce0 it when im done
    oh and i might have a line on a bed, tailgate, lights and rear bumper for 550 bucks... looks pretty clean. its just white.
  25. Feb 18, 2019 at 7:04 PM
    #4255
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I haven't seen any pre fabricated plates but I have seen a few guys box sections of the back half. They made cardboard templates and cut to fit.
  26. Feb 18, 2019 at 7:20 PM
    #4256
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Check out DMZ Fab. They might have some..
  27. Feb 18, 2019 at 7:21 PM
    #4257
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Is anyone running the OWL Dash Cam?
    Thinking about ordering one...
    Casper421 likes this.
  28. Feb 18, 2019 at 7:28 PM
    #4258
    Casper421
    In the woods
    06 DC
    I like it except it plugs into the OBD port and my ultra gauge is plugged in.
    Rheywood456[QUOTED] likes this.
  29. Feb 18, 2019 at 7:33 PM
    #4259
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    You have one?
    They have the splitter for the OBD which would allow you to plug in both?
  30. Feb 18, 2019 at 7:40 PM
    #4260
    Casper421
    In the woods
    06 DC
    Sorry, no I don’t but I really like it. I wasn’t aware there was a splitter. I may have to look into this more.
