ScanGuage II
Discussion in '2.5 Gen Tundras (2014-2021)' started by blaserdude, Feb 16, 2019.
  1. Feb 16, 2019 at 1:12 PM
    blaserdude
    blaserdude [OP] New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Hello,
    I want to try my ScanGuageII on my 2019 Limited. It worked great on my 08. Kind of scared I might smoke my ECU. ScanGuage only lists compatibility through 017. Have any of you tried one on something newer? I also have TorqueII and a Bluetooth dongle.
    Thanks,
    ebc
  2. Feb 16, 2019 at 1:38 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    I have plugged in my scangauge II on my 2018 for a few hours. no issues.
    Can't determine a permanent mount location yet.
    There should be no reason why it would smoke your ECU
  3. Feb 16, 2019 at 1:47 PM
    timsp8
    NY
    I’ve used it on 2018. No issue. I don’t think it really writes anything to ecu, just clears codes. If it messes it up, unplug battery. If that doesn’t work, go to dealer for warranty and say your wife drove it and now it’s acting weird.
    Darkness likes this.
  4. Feb 16, 2019 at 1:53 PM
    blaserdude
    Eugene
    none
    Thanks.
  5. Feb 16, 2019 at 2:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    All it does is read the output, should not be harmful.
  6. Feb 16, 2019 at 4:01 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I have mine semi-permament mounted in my 2018, used velcro to the left of the steering wheel on the flat spot above the mirror controls and switches. Display trans and torque converter temps, voltage and engine temp.
  7. Feb 16, 2019 at 4:09 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I got this mount on Amazon. Looks like the price has since gone up.
