2014 frequent wheel lean
Discussion in 'Wheels & Tires' started by CraKem2016, Feb 16, 2019.
  1. Feb 16, 2019 at 12:10 PM
    CraKem2016
    CraKem2016 [OP] New Member
    Andrew
    Illinois
    2014 Tundra SR5
    In progress
    I did a 3/1 level, new wheels and tires, then an alignment. Seems like its been 5 months since alignment and suddenly it seems that my front wheels are both leaning out again \--/ again. I get some minor pull to the right and sometimes vibration but mostly it seems fine while driving. Research has yielded a number of possibilities
    -Toe/Camber issue
    -Potholes (Illinois winters )
    -Bad UCA
    -Bad ball joints
    -Something is bent in suspension
    Curious if I would be better off long run getting a full suspension lift over the Low range offroad level that I put on. I dont need or want a crazy expensive suspension package nor do I want the ride to get worse. Id just like to get this thing driving true and without reoccuring issues. Appreciate any feedback!
  2. Feb 16, 2019 at 12:12 PM
    15whtrd
    15whtrd Mr. Blonde
    If it was straight and now it’s not, something came loose. I bet you they didn’t tighten the lower control arm cam eccentrics enough. 207 ftlbs
    CraKem2016[OP] likes this.
  3. Feb 16, 2019 at 12:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I would take it back and make them go over it properly. Let them know you’re not happy with that. Or get your money back and take it somewhere else.
