2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Feb 12, 2019 at 8:45 PM
    #481
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    LKSR5,
    I feel your pain, it’s a huge inconvenience . I also live in a cold and snow covered area and I need my headlights to work on demand.
    I’m sure if you contact ihacker he can help you out.
    As you know his harness’ look like they came from Toyota. High quality connectors.
  2. Feb 12, 2019 at 8:47 PM
    #482
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    I do have his harness got it back in March 2018 and no issues until tonight. But he had that time only with motocontrol
  3. Feb 12, 2019 at 8:50 PM
    #483
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Anyone have photos of the light output? Like to see if there flamethrowers.
    easleycrawler likes this.
  4. Feb 12, 2019 at 8:53 PM
    #484
    Buildn
    Medina, Ohio
    LKSR5,
    The pic I attached is the new version. The 2 short connectors are for the turn signals. The bundle is the fuse tap. And the 2 longer length ones with white connectors are for the headlights with a 2nd wire and grey connector that connects to the fuse tap for your led drl’s
    No moto control required and way better than the first version.
    Plus when you turn on your hi beams the low beams stay on.
    My old set up with moto control had the low beams that Would turn off.
    LKSR5-14 likes this.
  5. Feb 12, 2019 at 9:35 PM
    #485
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    PMed
    LKSR5-14[QUOTED] likes this.
  6. Feb 13, 2019 at 5:04 AM
    #486
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks a lot iHacker for quick response.
  7. Feb 13, 2019 at 5:10 AM
    #487
    War Machine
    War Machine SSEM # 5 3MW
    I’ll try and remember to get some pics tonight or in the morning. I won’t say they are flamethrowers, but definitely better than my stock halogens or Spyders were.
    Watt maker likes this.
  8. Feb 13, 2019 at 6:09 AM
    #488
    Azblue
    The Dirty T ( ^_^)_且
    You guys have me worried now. Although mine is working fine, I have never trusted the Motocontrol. I don't trust anything that is related to a HID kit, I had one in the wife's Venza and tons of trouble with it. Luckily that car has projectors so I was able to just swap the HID kit for Vleds Micro LEDs.
    So my question is about switching to the new version harness. Specifically the harness that controls the DRL with a relay. Is that harness left in place with the new version headlight harness, because when I installed the dimming harness I had a bitch of a time de-pinning the grey wire in the cab and broke it. I can't put it back to stock in the cab.
  9. Feb 13, 2019 at 3:13 PM
    #489
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Would like to update all that soon as I touched low beam connector light came on. I didn't find any corrosion or moisture in there. Probably it's just bit loose wire or something.
    Not sure what to do to prevent it from happening again.
    Anyway was quite quickly fix
    I would like to thank iHacker for very quick response and support. Will always refer you iHacker
  10. Feb 13, 2019 at 5:41 PM
    #490
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    I want to give a special thanks to iHacker for continuing to provide Tundras.com members his awesome harness. To all who has inquired about my PNP harness, I no longer make offer this harness and recommend iHackers PNP harness. Solid guy, solid product and solid member. :benchpress:
  11. Feb 13, 2019 at 5:50 PM
    #491
    Buildn
    Medina, Ohio
    Azblue,
    When I got the new harness from ihacker that eliminated the moto control all I had to do is restore the turn signal pinning to stock or original and yes the skinny grey wire under the dash can stay cut or de pinned.
    The fuse tap that ihacker provided in the kit will become your drl.
    Azblue likes this.
  12. Feb 13, 2019 at 5:55 PM
    #492
    alpinepro4
    Pat
    That would be great!
  13. Feb 13, 2019 at 6:32 PM
    #493
    iHacker
    Mario
    Thank you bro,
    Nice to hear back from you, my condolences to you and your family for your loss, that’s something extremely hard to comprehend and overcome. I know something like this will never be forgotten but remember now you have gained an angel in heaven who takes care of you forever.
    Keep up the good work bro!
  14. Feb 13, 2019 at 9:36 PM
    #494
    ruizf
    ruizf New Member
    2019 QuickSand Tundra 4x4 Crewmax
    Installation was flawless thank you very much @iHacker. Now my truck looks way better matching led with my bumper!
    Buildn, War Machine and iHacker[OP] like this.
  15. Feb 14, 2019 at 4:31 AM
    #495
    War Machine
    Hopefully these will give you an idea. Mine are the 2019 TRD Pro headlights. There’s a bit of a gap on the lower left side you’ll notice. I believe this is because I also installed the TRD Pro fog lights, and they need to be adjusted outward a bit. They are slightly cross eyed at the moment.
    This is with the level control adjusted all the way up. I may need to adjust the headlights also
    84C3306F-4FE0-4381-81F3-8CCDAE6F4B70.jpg 80AD269E-4396-4992-9730-1A421DE6909E.jpg
  16. Feb 14, 2019 at 4:47 AM
    #496
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Are those pics high or low beam?
  17. Feb 14, 2019 at 4:51 AM
    #497
    War Machine
    Low. Here is high beam:
  18. Feb 14, 2019 at 5:20 AM
    #498
    Azblue
    Nice, thanks for the info. I might have to think about upgrading my harness and getting rid of the Motocontrol. One less thing that can go wrong.
    Buildn[QUOTED] likes this.
  19. Feb 14, 2019 at 6:40 AM
    #499
    alpinepro4
    Pat
    Thanks for showing me your light output. I installed LED bulbs from Headlight Revolution and comparing light output. Installed bulbs into 2017 OEM Pro Headlights. Looks like out put is comparable. Thinking of replacing with 19 headlights.
    Watt maker, Homar23 and iHacker[OP] like this.
  20. Feb 14, 2019 at 6:45 PM
    #500
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
  21. Feb 15, 2019 at 8:27 AM
    #501
    NJUplandTundra
    NJUplandTundra Toyota Fanatic
    Michael
    2015 Limited CrewMax
    6112-5100, SCS Ray10, 275/70/18 AT3 XLT, SPC UCAs, TRD CAI, TRD Pro Grill
    Looking to upgrade my 2015 Limited to 2019 Pro headlights. @iHacker, sent you a message. Thanks!
  22. Feb 21, 2019 at 9:15 PM
    #502
    LTPro
    LTPro New Member
    Luis
    2015 Tundra TRD Pro
    Stock trd pro suspension on 17' Method wheels wrapped up in 315/70/17 KO2's
    Thank you @iHacker for the amazing customer service and for the even better rusults. Definitely recommend it, money well spent
  23. Feb 22, 2019 at 1:36 PM
    #503
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    @iHacker just to make sure i read your OP correctly.. if i were to upgrade lights.. for 18 its exact plug and play? no major modifications or a need for a harness? I have a 2018 SR5 TSS Offroad, I first thought about upgrading to LED bulbs, but im thinking i like the idea of swapping out the whole unit.
  24. Feb 22, 2019 at 3:55 PM
    #504
    SonShine
    SonShine New Member
    I definitely need to upgrade my lights as well. I want to go from the standard 2015 TRD Pro lights to the 2019 TRD Pro lights. Will send a message iHacker - thanks in advance!
    iHacker[OP] likes this.
  25. Feb 22, 2019 at 5:03 PM
    #505
    iHacker
    Mario
    2018-19 SR5 still need a harness check the $100 option that’s what you need.
  26. Feb 28, 2019 at 11:05 AM
    #506
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    Watt maker and iHacker[OP] like this.
  27. Mar 1, 2019 at 8:09 AM
    #507
    Senorx
    Senorx New Member
    Ed
    South Texas
    2015 Tundra CM TRD 4x4
    I’m so lost even after reading through all 18 pages. So many options and I just don’t know what pertains to me. I also don’t get why you have to go through the firewall into the cab? I was watching a Head Light Revolution video about their harness and they don’t mention anything about the firewall.
    All I know is I want the 19 TRD Pro lights on my 2015 SR5 CM. What option do I need??B1D1BFD9-BDC1-4BAD-BAF6-547A52401903.jpg
    KELZ84 and iHacker[OP] like this.
  28. Mar 1, 2019 at 8:13 AM
    #508
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    @iHacker do you have any harnesses available for a 2019 sr5 with led strip daytime running lights and halogen headlights?
  29. Mar 1, 2019 at 9:09 AM
    #509
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    All you need is the main harness and the additional DRL harness. No need to go through firewall unless you want the drl strips to dim when the headlights come on.
    iHacker[OP] and Senorx like this.
  30. Mar 1, 2019 at 11:02 AM
    #510
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    @iHacker how is your supply of harnesses for 2016 1794 with LED DRLs conversion? I am looking at 2019 TRD pro headlights
