  1. Feb 11, 2019 at 7:47 PM
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    I've been considering it.... not sure yet though....
  2. Feb 11, 2019 at 7:54 PM
    Pat
    Pat Sorta-new Member
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    x2 on wanting to know where you had those made.
    3mxdivr[QUOTED] likes this.
  3. Feb 11, 2019 at 9:09 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Katzkin with heated seats 775FF99A-D0EA-491A-89A1-CD7CB4B97786.jpg400EACF6-A6F8-4053-91AB-3B4B3A7EF914.jpg161A0C2F-B95B-458B-8C16-D55E0F6D97CC.jpg
    snarkscarbine, Nebz, JoshuaA and 10 others like this.
  4. Feb 11, 2019 at 9:24 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    You can run them higher if you're constantly carrying/ loaded.
    For normal riding/ comfort, 5-10 psi is all you need.
    IMO though, they're not the best for pulling/hauling heavy loads. If anything, I would go with a load-equalizing hitch.
    For adding height and ride comfort tho, you can't beat 'em!
    15whtrd[QUOTED] likes this.
  5. Feb 11, 2019 at 9:37 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Watt maker likes this.
  6. Feb 12, 2019 at 3:22 AM
    KenSeltzer
    KenSeltzer New Member
    What is added to these off road packages? Im considering getting a SR5 off road or a Limited off road. They are close in price but i like the leather.
  7. Feb 12, 2019 at 4:42 AM
    coreyk85
    coreyk85 2019 Tundra Limited Cement
    Indiana
    I like that trd shifter knob cover
    mgm16trdpro likes this.
  8. Feb 12, 2019 at 6:03 AM
    CCarr
    CCarr New Member
    The off road package adds two skid plates, bilstein "off road" shocks, and 18" wheels. I think that's it on the Tundras. Wish it included a locker but might not be enough demand for that.
  9. Feb 12, 2019 at 6:15 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    TRD Off Road on the SR5 adds different wheels and tires, upgraded shocks, skid plates, LED headlights, TRD floor mats and bedside stickers. Typically it would also require the SR5 Upgrade package be added, which adds the 38gal fuel tank, front console vs. bench seat and some other small things related to that.
    On the Limited the TRD Off Road will only add what is not already part of the Limited package, for instance most of the SR5 Upgrade items are already part of the Limited, and the Limited already has alloy wheels, so there is no cost to upgrade to the TRD wheels. (Limited is 20" wheels and TRD Off Road is 18" wheels)
    JoshuaA and 040Tundra like this.
  10. Feb 12, 2019 at 8:50 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Waaayyyyyy Cool!
    Disfigurative likes this.
  11. Feb 12, 2019 at 9:50 AM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    X3 on wanting to know where you got them. Those look great!
  12. Feb 12, 2019 at 6:45 PM
    Disfigurative
    Disfigurative New Member
    james
    18 black TRD sport
    *** Update, do not do this MOD. this product is garbage and it peels and cracks right off.
    Rust-oleum peel coat lens tint. I didn’t want to use VHT because it’s permenant and I was concerned I would screw it up. So I gave this a try. It turned out ok, they have a weird milky haze to them. I will keep them as is for a little while and see how they hold up. The instructions say no more than 4 coats, but that did absolutely nothing. I ended up using about 1.25 cans. You will need to buy the clear coat as well because it was super dull without it. I couldn’t get a good picture installed, because it is dark out.
  13. Feb 12, 2019 at 6:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks good. I used some rustoleum peel coat on some parts, gloss black solid stuff, not the tint. I wasnt impressed compared to plastidip. I wonder is plastidip makes a tint, I'd try that with maybe some glossifier over it.
    Disfigurative[QUOTED] likes this.
  14. Feb 12, 2019 at 6:59 PM
    Disfigurative
    james
    18 black TRD sport
    Yea, overall I think the rustoleum peel coat is miles behind plastidip. Plastidip is so easy to use, very forgiving, and super durable. Unfortunately plasti dip does not make a tint product. I’ve seen people use the plastidip “smoke” with clear coat but I think it looked like garbage.
    Pudge[QUOTED] likes this.
  15. Feb 12, 2019 at 7:05 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Speaking of plastidip, not that this has anything at all to do with the current topic... When I sprayed my shift surround pieces I didn't have a big enough piece of cardboard and had overspray on the concrete in front of the garage. That stuff is still there after a Wisconsin fall and half winter with plenty of soap run-off from washing cars and dirt bikes. I don't have a good pressure washer to spray it off, but for it being advertised as being easily removable I'm honestly surprised at it's durability.
  16. Feb 12, 2019 at 9:25 PM
    RelentlessFabrication
    RelentlessFabrication relentlessfabrication.com Vendor
    Sparks, NV
    Nice! :thumbsup:
    SullyMoto19[QUOTED] likes this.
  17. Feb 12, 2019 at 10:37 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    Picked up a new shift knob today (actually two, one will be up for sale soon), popped in the illuminated ignition module, and finally got my rear sway bar installed.
    B277CBC0-C327-4699-801F-0D9C8BBF17AF.jpg F75DEA37-7F35-420C-924A-F933DC353AF4.jpg AABDD288-1DDE-4124-B956-BB4F19297CDB.jpg
    Will hopefully have time tomorrow to get her shined up and put on a new exhaust tip.
    JoshuaA, Roflo5, 5.7TRDProm and 5 others like this.
  18. Feb 12, 2019 at 10:45 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    @dmiller Did you need air tools for the install of the sway bar?
  19. Feb 12, 2019 at 10:53 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    Nope. Used a breaker bar to loosen the two bolts on the hitch mount. Took a minute to break it free, made me feel like I probably need to spend a little time in a gym. Air tool would probably have been easier, but it's not necessary.
    It really is an easy install, if you have the necessary tools. I didn't, so it took me about 2 hours, including a trip to Wally World.
    Major[QUOTED] likes this.
  20. Feb 13, 2019 at 5:33 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    While at the PA Sportsman show last week, I ordered something to put this sticker on. Pretty decent deals during the show and better then I could get online at the moment.
    dmiller, equin and mgm16trdpro like this.
  21. Feb 13, 2019 at 10:35 AM
    CAJUN_TRANSPLANT
    CAJUN_TRANSPLANT New Member
    Cape Coral, FL
    2018 Grey Tundra DC TRD Off-Road 4x4
    OCD console organizer
  22. Feb 13, 2019 at 12:23 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Got this in on Monday, but finally got it working right and tuned today
    Wireless CarPlay is pretty badass, and the sound is a huge improvement over the stock HU. Pro tip: don't forget to hook up the freaking amp turn on lead... I tied the lead from the new unit into my front camera and forgot to include the stock amp... Let's just say the dash speakers and rear tweeters sound like shit on their own.
  23. Feb 13, 2019 at 12:46 PM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    Minus forgetting the stock amp, how difficult was this install? Strongly considering doing this one too
  24. Feb 13, 2019 at 12:54 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The head unit itself was pretty easy. Crutchfield gave me most of the wiring harness I needed, except for the adapters to retain the factory satellite radio and GPS antennas, but I was able to order those on Amazon Prime and get them the same day the HU arrived. The hardest parts were routing the cables for the handsfree mic (replaced the stock one in the overhead light unit) and the front camera (the RCA cable end is slightly larger than the tube that goes through the grommet on the firewall). One other thing that'll piss you off if you aren't paying attention, the plug for the mic likes to pop out pretty easily, so make sure that's attached and working BEFORE you put all the trim pieces back on...
    Here's how the wiring harness ends up looking, to give you an idea of how fun it is to try to shove in the dash:
    JoshuaA, buckeyeinlv and Watt maker like this.
  25. Feb 13, 2019 at 1:24 PM
    Jomani99
    Jomani99 New Member
    Jonathon
    2018 Barcelona Red Tundra Limited
    By any chance would you be willing to sell the matte black handles? I'm trying to buy some to paint them Barcelona Red.
    cantle[QUOTED] likes this.
  26. Feb 13, 2019 at 1:34 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I want that shift knob!
    5.7TRDProm likes this.
  27. Feb 13, 2019 at 1:45 PM
    cantle
    cantle New Member
    Durango, CO
    sorry man, traded them for the gloss black. If your going to paint, check with the shop though as they may prefer a smooth starting surface vs. the textured (and having to sand them).
    Jomani99[QUOTED] likes this.
  28. Feb 13, 2019 at 1:58 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I dont think the matt would take paint very well.
  29. Feb 13, 2019 at 2:07 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    I have mine as a new take off when I went to the all black knob...you interested?
    Erichudgins[QUOTED] likes this.
  30. Feb 13, 2019 at 2:08 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    pro shift knob??
